Old 02-07-2005, 08:04 PM   #21
Re: Overhead Console Install Instructions
When you installed the console on your 03 Regular Cab, where were the bolts you removed to pull down the console? I want to install LEDs to show the placement of the map lights and I don't know how to remove the console on my 2000 Silverado Ext. Cab LT series. Any and all help would be appreciated.
Thanks
Skidiver is offline
Old 02-09-2005, 11:53 AM   #22
Dragging Daily
There is a screw in the the front. unscrew and wiggle around to get the clips loose
Sick Boy is offline
Old 02-17-2005, 11:51 AM   #23
Full Sized Style
Williamts99's Avatar
Originally Posted by kirkrhughes
I’m going to take apart my Valentine One radar detector and see if I can mount the controls behind the cubby hole cover then put the rest of the detector in the garage door opener space.
If you ever do this, please be sure to take pics, I am thinking of doing this exact thing once I have the money to buy a console. Oh yea, and I send my V1 back to get updated.
97 K1500 Extended Cab, Short Bed, 5.7L Green/Tan Paint, Cloth Interior, TM and Speed Limit Removed, Tinted, Borla Cat-Back, Granatelli MAF, MSD coil, K&N Filter, Remote Start w/ Window Control
Williamts99 is offline
Old 02-26-2005, 07:36 PM   #24
formerly joker198268
96LoLyfe's Avatar
just put in my overhead console, looks great.......it was put in my 96 ecsb, had to cut the headliner out, so i went to the junk yard and got the console and half of the headliner out of a 99 burban to use as a template for $75, lined the headliner piece up and traced the cut outs and then cut it. got an anchor nut from ACE Hardware and glued it to the other side of the hole in the roof, slid the console in the slots for the back and tightened down the front......it's good to go......very easy to do......
FYI......there was another gray overhead console there if anybody is interested, i can get it for you?????? just trying to help my fellow FSC members out.....
96LoLyfe is offline
Old 05-19-2005, 08:24 PM   #25
Any what any luck getting the map lights to come on with the dome light?
I have a orange and white wire at the dome light. The overhead console has 3 wires. Orange and then 2 black wires, after the connection there is only 2 wires, one of the black wires stops at the connection and does not go through. I have tried everything i can think of, but i can only get the lights to work by pressing the map buttons.
any ideas????
99 GMC Sierra SL ext cab
4.8 vb 3.42
elk_hunter is offline
Old 06-03-2005, 01:53 AM   #26
Mr. Gadget
lowdown's Avatar
any ideas????
Anyone that wants to do this, it can be done but if you wire it to come on with your dome light you wont be able to turn it on unless your dome light is on. Also, they wont come on with the dome lights unless the switches are in the on position.
Dome lights work off of a reverse ground system, when you open your door you are not putting power to the light you are completing the ground circuit.
lowdown
1988 Chevy Silverado Stepside - 4/6 drop, Katzkin Leather
Click on signature for truck pics and specs.
http://www.koolcartoons.com
lowdown is offline
Old 06-03-2005, 01:42 PM   #27
Try connecting the two wires to the wires before they connect to the Map light switches. You have them connected after the switches. I hooked up an LED before the Map light switch and the LED is on all the time. I use it to mark where my Map lights are in the console at night. I hooked a potetiometer to the LED to be able to dim the brightness of the LED. It works great. Good Luck!
Skidiver is offline
Old 06-10-2005, 09:43 AM   #28
Thanks for the info guys.
I have the wires hooked up from the dome light to where the connector is at on the console, I cut of the connector(since i had to run wires from the light to the console). So this is before the map light switch.
I have the ground to the truck(not dome light) and then the + wire from the dome light to the + on the console wire harness.
I have seen other consoles on this board, and on the conosle wire harness there is 3 wires, on my there are only 2 wires, maybe that is the problem, can some look next time yours is down and see where the wires go to inside the console. one wire goes to the switch, and the other goes to the light ...
4.8 vb 3.42
Old 06-10-2005, 06:13 PM   #29
I LiKe MiNe WiTh No ShInE
i just got one for 20 bucks out of a surbuban in the junk yard . thers a couple more in there to im looking for a blue one though . but were mounting this one in my buddys s-10 . with a 5 inch tv in the cd part , make it flod all the way down . his bag switches where the a/c controls go . i think it will look nice once were done this weekend
05 Silverado SS - Fullyyy Loaded 2wd, 8k H.I.D.S
96 pro-street silverado- TOO MUCH
06 yamaha r6 raven - stretched 9 inches , fully bolted
08 trx-450r-normal track stuff
badasschevy is offline
Old 06-22-2005, 12:11 PM   #30
Where are you folks getting these overhead consoles? My 05 CC has a the short overhead and I want to replace it with the longer one.
TIA
Monte Carlo 406 700R4
05 Sierra 3500 SLE CC 4X4 Dually Duramax/Allison
Big Max is offline
Old 06-22-2005, 07:28 PM   #31
Grunmn's Avatar
TIA
junk/salvage yards or ebay
Grunmn
Grunmn is offline
Old 12-06-2005, 11:52 PM   #32
formerly known as project2005
i just did this and it came out ok. my only problem is finding a way to screw on the front. cant seem to find a screw skinny enough, yet fat enough to grab, and long enough at the same time :arg:
Otto is offline
Old 12-12-2005, 03:18 AM   #33
Originally Posted by b1u3m3th
Anyone else with a '98 1500 Silverado put an overhead console in? Everything is perfectly fine on mine, except that I can't find the wires to hook up to the lights to save my life! Am I the only one, or did they just decide to play a joke on the 98's?
I've got a '98 Silverado K1500, and I'm about to do the same project, kinda funny I came across this page, I thought I was one of the few who wanted to put in an overhead console. I'll let you know when I start cutting. If you can't find the wire, simply run a 16 - 18 guage wire up through the dash and along the trim, tucked under the front of the headliner and back to the connections of the OH console. All that is only needed if you can't splice into the dome light.
high_ryda is offline
Old 01-02-2006, 03:32 PM   #34
JoeliusZ28's Avatar
this is an excellent write-up, im definitely doing this in the future.
btw, if anyone ever comes across a blue console on ebay or something, i would appreciate an email: joeliusczar890@yahoo.com. I think blue is kinda rare, and I would like to have a factory piece as opposed to having to fab vinyl or use spray paint.
-Joel
'98 Z71 SLT ECSB
JoeliusZ28 is offline
Old 02-14-2006, 04:50 PM   #35
has no car payment!
TIMSPEED's Avatar
I would just like to know what's the point of all the compartments on the Overhead Console?
The front (blank spot) is supposed to be where Rear A/C on the Burb's is, right? Then, I don't know what, because the piece is missing on mine, then the garage door opener, right?
I have this in my tahoe (stock), I just need to find if GM has that piece for the first compartment, at the dealership...
-87 Corvette Z52 Coupe
*K&N Filter,Yank Torque Converter,Custom Cat-Back
-95 Tahoe 2-door 4x4
*Posi-Lok/G80, 285's, Custom Cat-Back, 3.73's
-98 Saturn SL2
*14" Konig JSpec's, Custom Cat-Back, SPS STB
TIMSPEED is offline
Old 02-14-2006, 05:33 PM   #36
Beaner/Cracker
Yes you can buy the blank panel.
Izzy is offline
Old 02-14-2006, 07:30 PM   #37
Mr. Gadget
lowdown's Avatar
There are three compartments, the first one is for your garage door opener or you can get a homelink panel with built in opener. The second one is a compartment for sunglasses or glasses. And the third one is for CDs.
Click here for picture
lowdown
lowdown is offline
Old 02-14-2006, 09:28 PM   #38
has no car payment!
TIMSPEED's Avatar
Can I buy the piece that covers the Sunglasses compartment? Mine's broken off...
-98 Saturn SL2
TIMSPEED is offline
Old 03-18-2006, 07:53 PM   #39
4x4 n00b
Thanks for the write-up. I know its old, but i just started working on my truck and this was my first mod. The only problem is that i wish i had the one with a larger deadspace in the front so i could actually mount something there. Mines basically too small to put anything in there. Pictures are in my gallery if u even care. Oh well, still adds to the interior big time.
'96 Chevy 4x4 Ex. Cab...
Just Started Workin' On It
djc0dy is offline
Old 04-22-2006, 07:08 PM   #40
dadngt's Avatar
I want an overhead console in my 02 Sierra Reg cab. My dome light is almost centered on the headliner,not in the rear trimlike on my old 89. Could I still be able to add the console, remove the dome light & wire the domelight wires to the consoles map lights? Thanks
2002 GMC Sierra Reg Cab 4.3 6er manual interior
89 Ford Mustang GT 5.0 302
dadngt is offline
HTML code is On
