04-28-2006, 11:08 AM
#41
You can call me pudro.
Re: Overhead Console Install Instructions
does someone have these pictures saved? All I am getting is red x's.
Thanks,
Chad
05-13-2006, 02:21 AM
#42
Nice mod *bump*
05-17-2006, 10:09 AM
#43
we need the pix fixed, Im about to do this install within the next few days and it would be nice to have something to go off of.
2002 silverado ext cab
4.8L Z71
05-17-2006, 11:10 AM
#44
Mr. Gadget
I don't have any pictures but here is a link to a site that I got my instructions from for installing in a regular cap.
http://www.lwm.cc/oh/
Hope this helps
lowdown
1988 Chevy Silverado Stepside - 4/6 drop, Katzkin Leather
Click on signature for truck pics and specs.
http://www.koolcartoons.com
05-17-2006, 11:30 AM
#45
I just installed my console last weekend. Basically just like what lowdown did. It definitely added style to the interior.
1992 Chevy Silverado
05-17-2006, 01:45 PM
#46
does anyone know how far it goes back in an extended cab, do you have to remove the dome light? also does anyone have pix with an extended cab that has it?
4.8L Z71
06-07-2006, 07:46 AM
#47
I just installed long overhead console in my 05 Extended Cab Silverado. It has the slots in the roof panel for the tabs to slide into. I did not have the piece to go into the hole in the front for the screw to go into. I carefully drilled a hole just in front of the square hole that is in the roof panel for this purpose. I then used a self tapping screw to secure the console ( make sure it is not so long as to hit the roof skin). I have not hooked up the map lights but after reading these posts I will make a connector to pull power off the dome light and the sheet metal will be my ground.
I want to install HOMELINK does anyone have any info how this will work and where to find one to fit in the garage door opener of this console. Thanks Roadking
06-07-2006, 07:54 AM
#48
Beaner/Cracker
You don't have to remove the dome lamp.
10-31-2006, 11:06 AM
#49
last activity of thread maker was in 05... unfortunately i doubt the pictures will be back anytime soon. I just snagged one on ebay so it would be nice. If i dont find anymore i can probably take some when i do mine.
-Joel
'98 Z71 SLT ECSB
10-31-2006, 11:08 AM
#50
secondly... does anyone know if there are any "plug and play" LEDs i can get for the dome lights? Id like to change those to white LEDs before I do the install.
-Joel
'98 Z71 SLT ECSB
11-22-2006, 12:10 AM
#51
i just started on mine today. Looks like my truck also does not have the wiring alredy in place. Im gonna have to splice into the dome light as well.
-Joel
'98 Z71 SLT ECSB
04-08-2007, 08:24 PM
#52
Does anybody have pics of this overhead console install? The pics are not coming up. Thanks.
#53
04-09-2007, 10:47 AM
#54
They work for me, so i'll save it and upload it later.
- B
04-26-2007, 03:55 PM
#55
I'm also interested in doing that. Anyone know if that is a seperate replaceable part from GM?
05-21-2007, 07:58 AM
#56
mine has homelink in it, however I still have not wired mine up since i installed it. Im waiting on a set of gauges im planning on putting in it before i bother. hopefully in a month or so ill have it all hooked up. Ill also take a bunch of pictures when i get around to it.
-Joel
'98 Z71 SLT ECSB
08-05-2007, 06:13 AM
#57
does anyone know how to make the reading lights come on with the dome light on a 2000?
11-22-2007, 10:37 AM
#58
Well i FINALLY finished my install last night. I think i had every difficulty i could have possibly run into. First of all my truck didnt have the wiring harness to clip into, so that meant i had to tap the dome light. next, my domelight didnt have the ground wire it was supposed to have, so i had to tap my own ground. next i had a short with the gauge that was killing the gauge fuse, and as a result the truck too. i think i ran into every stupid problem humanly possible. Im very happy with the end result though, even my homelink system appears to be working but i havent tested it yet (the light works on it). If i can find a spot to safely and easily mount a sender, i will be installing an oil temp gauge next the trans temp gauge - i already ran the wiring for it.
here are my final pictures:
*edit* - i guess this board doesnt resize 5mp pictures lol
http://www.joeldevriendt.com/files/p...e/IMG_6227.JPG
http://www.joeldevriendt.com/files/p...e/IMG_6228.JPG
http://www.joeldevriendt.com/files/p...e/IMG_6230.JPG
-Joel
'98 Z71 SLT ECSB
02-03-2008, 01:23 AM
#59
OK guys, I'm trying to install the short overhead console & my 2006 extended cab 1500 is not pre-wired for one. On the console itself, the wiring harness has 3 wires. They are gray/black, black, and orange. Does anyone know which one is for power, which one is for ground, & what the third one is for?
02-03-2008, 07:34 PM
#60
Does anyone know if the install for this on the NBS single cab is anything like the write-up for the OBS single cab? Looks to me like the dome light would have to be removed or relocated.. Has anyone done this to an 03-05 standard cab truck??
2004 Kawasaki Z1000 Kawi Green.
2008 Nissan Altima Coupe 2.5S Code Red
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
