Old 02-03-2008, 08:50 PM   #61
Can I help you?
ksukats57's Avatar
Re: Overhead Console Install Instructions
So heres my question-- on a 97 extended cab will the wires be there or will i need to splice into the dome light?
Thanks
2001 k1500HD Sierra ccsb SLT, Lq4, 4l80e, 14 bolt SF, dual Flows, BlackBear tune
67 C10,283v8, all original with 86000 miles!
ksukats57 is online now
Old 02-04-2008, 12:45 AM   #62
If you splice into the dome light, your maps light will only work when your dome light would work. I ended up running some speaker wire down the pillar & grounding one of the strands below the dash & spliced the other strand into accessory power down there. Works great!
Thanks
Desert Driver is offline
Old 02-04-2008, 01:08 AM   #63
Torque Engineer
SoCalZ28's Avatar
thats cause your dome light switches off a ground, so you can rob the 12+ from the dome light and then ground off one of the two screws that hold the plastic light up. or run from the dash like you did, either work great.
94 Z71 350 6" lift w/* keys, enclosed CAI, spacers, PCM4LESS, MSD ignition, headers w/custom exhaust & cutout
90 Ford Festiva L Plus 1.3L 5spd K&N
RIP SoCalZ28
SoCalZ28 is offline
Old 02-05-2008, 06:24 PM   #64
SCAMMER
thegreeny1 is offline
Old 02-07-2008, 10:21 PM   #65
Supporting Member
hillbilly2084's Avatar
JoeliusZ28, I like what you did with the gauge. I have been thinking of puting some of those gauges in my truck but wanted something different then the Pillar. What size gauges did you use?
'98 K1500, 5.7L, 3"BL., 315/75/16 Destination A/T's, 1.5" Wheel Spacer on Front
'03 Burb, 5.3L Flex Fuel, Bone Stock, AWESOME VECHILE
Mess with the Best, Die like the Rest!!!
hillbilly2084 is offline
Old 04-06-2008, 04:11 PM   #66
rigamortis's Avatar
Now I know that I have rear AC controls in there, the console came out of a suburban, Ill eventually get a blank to put in there but for now I didnt want an empty hole. I didnt think about taking pix as I made the holes but I did take these two after it was done.
For those of you that have a gap up towards the front its because of the back behind the map lights and you can cut a hole out behind them and the gap with do away.
Shot with iPhone at 2008-04-06
2002 silverado ext cab
4.8L Z71
rigamortis is offline
Old 04-07-2008, 03:13 AM   #67
98 K1500
akjay907's Avatar
yeea anyone know how much an overhead console would run for??
gallons per mile...
akjay907 is offline
Old 04-08-2008, 01:28 AM   #68
rigamortis's Avatar
got mine for less than $30 on ebay.....
as for those people that are installing this and do not have the harness.. or only have two wire harness..... you need a ground, always hot, and only hot when the headlights are on. To me it is important that have everything wired correctly, if you have 2 always hot the lights for the homelink will always be on...... that means even when the truck it shut off and your not there.. they are on. very important to have those connected to only on with headlights.
4.8L Z71
Old 04-08-2008, 03:11 AM   #69
98 K1500
akjay907's Avatar
30 dollars???? damn thats alot cheaper than i thought it would be, i should do this now...
gallons per mile...
akjay907 is offline
Old 04-08-2008, 10:25 AM   #70
rigamortis's Avatar
I saw one for nbs.... 02 model for $9 something on ebay yesterday..... it may go up but I only paid $40 something for mine with shipping
4.8L Z71
Old 04-09-2008, 02:23 AM   #71
Hired Goon
Aloicious's Avatar
That looks really nice, good job. I'm installing mine soon, $30 is a good deal, they go anywhere from $30-$60 pretty regularly that I've seen.
'96 ECSB 5.7L, T56, 411 PCM, EFILive self-tuned, LC-1, ZZ4 cam, Custom MPFI, Hydroboost, headers, Mark VIII Fan, catback, Detroit Truetrac, 3.73, sound deadened, DEH-P600UB, Polk comps/10", kicker amps. In the works: RHS Heads, intercooled whipple, & Distributorless CNP. the "LS31"
Aloicious is online now
Old 04-12-2008, 12:41 PM   #72
JoeliusZ28's Avatar
for what its worth... i have mine spliced into my dome light and and my lights work all the time.
I just messed with the wiring until i found a setup that worked and soldered it. I dont remember what exactly i did but i have to take it back apart eventually to put my oil temp gauge in. I'll post back with my setup when i do.
-Joel
'98 Z71 SLT ECSB
JoeliusZ28 is offline
Old 04-12-2008, 12:43 PM   #73
JoeliusZ28's Avatar
I also have a question: does anyone know how to program the homelink? I did it on a ford once and you had to hold the outer two buttons for 5 seconds, but that doesnt work on the GM.
Apparently it was not an option at all on the trucks. The owners manual only shows the compartment where you just stick a regular opener inside.
-Joel
'98 Z71 SLT ECSB
Old 04-13-2008, 08:16 PM   #74
rigamortis's Avatar
http://www.homelink.com/home/home.tml
4.8L Z71
Old 04-23-2008, 05:10 PM   #75
TREY333's Avatar
Hello, I Have A 91 2wd Swb, That I Plan On Putting One Of These In, Being A 91. Any Chance Or Idea On Mounting It?
TREY333 is offline
Old 06-18-2008, 02:13 PM   #76
GMAN12's Avatar
Just curious, what are you guys using to cut the headliner?
"02" Silverado Reg. Cab 6' Box 4.8 2WD
GMAN12 is offline
Old 06-18-2008, 02:18 PM   #77
02GMCtruck
88GMCtruck's Avatar
Location: Albion, Wa: from Pullman, Wa: from Edgewood, Wa
I used a sharp razor blade in both my trucks.
I noticed you have a NBS truck, I just installed a console in my 02 regular cab and it was very different than when I installed one in my 88 regular cab (this how-to was done in an 88-98). I have come pictures to upload and was planning to create a how-to for the 99+ regular cabs.
When I installed mine I moved the dome light back and rewired the map lights to work with the dome lights and independantly.
Last 3 Stepsides
79 Chevy C10, RCSS/5.0L/TH350/10, 86k. 4/6 drop.
88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 176k. 9" SAS w/ 35s
02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 20k. Sierra HT package: 1 of 234 Trucks.
88GMCtruck is offline
Old 06-19-2008, 12:32 PM   #78
02GMCtruck
88GMCtruck's Avatar
Here is my How-to install in a Regular Cab 99-06 (07 Classic)
http://www.fullsizechevy.com/forums/...ml#post3312847
Last 3 Stepsides
Old 11-22-2008, 12:38 PM   #79
OBS Obsessed
94Z-Buggy's Avatar
Will their be mounting slots and wiring for an overhead console in my 94 ext cab Z71 ???
1994 Chevrolet Silverado Z71 ECSB
Crank/33x12.50x17 MT Claws/17x9 Gear Alloy Modified/True Duals/Smoke Tint
222K on the clock
94Z-Buggy is offline
Old 11-22-2008, 01:38 PM   #80
02GMCtruck
88GMCtruck's Avatar
I would guess that there would be the slots, but no wiring in your 94.
Last 3 Stepsides
HTML code is On
