#21 |
Forum Leader
Status:
Online
Member ID: 84
Re: Post Your Setup
1998GMC
Tbars cranked 1.5" 2" rear blocks 3" body lift 9000x shocks 305-70-16 goodyear at/s 16x8 4"backspacing procomp 1079s Fenders measure 41" all around no rub what so ever ![]() |
#22 |
Member ID: 3976
Re: Post Your Setup
2000
chevy silverado 4wd 315/75/16 16x10 with 4" of BS 6" super lift + 3" body Stock bars not cranked at all stock keys 5.5" lift block no add a leaf Ranch hand bumpers front and rear not sure on fenders inner fender on the front lots of cutting ![]() ![]() ![]()
"I'll be back. You can't keep the Democrats out of the White house forever, and when they get in...I'm back on the street WITH ALL MY CRIMINAL BUDDIES BUWAHAHAHAHAHAH" - Sideshow Bob
#23 |
Supporting Member
Member ID: 21123
Re: Post Your Setup
2001 Silverado 1500 4x4
Reg. Cab shortbox Stepside 4" Rancho lift 3" PA bodylift stock TB settings 315/75R16 Baja Claws 16x10 Black Rock Crawlers with 4" backspacing 47" front fender height [I MG]![]() Last edited by 4mcrue : 06-22-2005 at 11:09 PM. |
#24 |
Slightly Irregular
Member ID: 8103
Re: Post Your Setup
81 Blazer
42" Iroks 16.5x12 MT Classics 8" Suspension f/r no blocks, ORD Shackles D60/14ff, ORD crossover 4" Body lift Cut outs Warn Enforcer Bumper,stock rear Measurements [IMG] [/IMG] LIGHT TRAVELS FASTER THAN SOUND, WHICH IS WHY SOME PEOPLE APPEAR BRIGHT UNTIL YOU HEAR THEM SPEAK 05 GMC 2500HD SLE:Stock for now, 7"+ 36's planned |
#25 |
formally lugnut
Member ID: 1084
Re: Post Your Setup
2005
Chevrolet Silverado 2500HD 4WD 37" BFG Mudterrains 17" ProComp Wheels 8" Fabtech Lift w/ Fabtech dual shock hoop Torsion Bars still at factory (stock) specs No torsion bar keys No body Lift Stock bumper Will measure fender height Front valance trimming necessary Bilstein primary shocks (stock locations) Fox secondary shocks (dual shock hoops) Detroit locker 4.56 Precision Gears (front and rear)
#26 |
Got Sand?
Member ID: 16447
Re: Post Your Setup
2003
Chevrolet Silverado 4wd 36x14.50R16 Super Swamper STS Radial 16x10" Eagle Alloy 0589 Full Throttle 9.5" in front. 10" Atlas springs in rear. No stock block. Stock YH torsion bars Cranked .5"-1" No lift blocks. No Add-a-leaf. No body lift. No aftermarket bumper. Front Fender:49" Rear Fender: 48.5" Had to trim the front valence due to rubbing. Have never rubbed on the rear fender, any metal, or the frame. ![]() ![]() |
#27 |
needs to be bigger
Member ID: 26089
Re: Post Your Setup
96
GMC Sierra 4wd 285/75/16 Dueler MT's 16x8 Ultra 164's 3" BDS bl will have to measure later no trimming or rubbing ![]() ![]() ![]() ![]() 96 GMC 4x4, 3" bl, k&n cold air intake, 16x8 ultras 78 K20, 350, th400, 14ff/10b, and lots of rust-sold 2000 Bombardier DS650, AC, FMF, PRM, etc...and totaled because somebody thought it was better to steal than buy! |
#28 |
Premium Member #13
AKA Hollywood
Member ID: 14196
Re: Post Your Setup
Year - 2000
Make - chevy Model - 1500 ECSB 2wd or 4wd - 4WD Tire Size - 315.75.16 Wheel Size - 16X10 Lift kit size and Brand if not stock - RANCHO 4"-6" Torsion bar Rating or Code: - STOCK Torsion bars cranked or not and if so how much.- 2" MAYBE Torsion bar keys if any- STOCK Lift Blocks? - 5.5 SL Add-A-Leafs? - NO Body Lift? - 3" PA Aftermarket Bumpers? - NO Fender Height Measurements - FRONT 48" REAR 48" Any fender or body trimming needed? (If so where?) - NONE ![]() (SOLD)
#29 |
Member ID: 20105
Re: Post Your Setup
2000
Chevy 2500 ECSB 4WD Tire Size - 305-75-16 Wheel Size - Stock Wheels 16 x 6.5 STOCK TB's STOCK Key's 3'' BDS Body Lift Stock Bumpers ![]()
1995 GMC Sierra RCLB 4X4
5.7-4L60 stock for now |
#30 |
Member ID: 6052
Re: Post Your Setup
Year
Make - GMC Model - Sierra 1500 2wd or 4wd - 4wd Tire Size - 33x12.5x16 STS's Wheel Size - 16x8 w/4" bs Lift kit size and Brand if not stock - Rancho 4-6" Torsion bar Rating or Code: stock Torsion bars cranked or not. Acually uncranked some for cv angle Torsion bar keys if any. nope Lift Blocks? Rancho 4" block Add-A-Leafs? yes came with kit Body Lift? no Aftermarket Bumpers? just the light bar Fender Height Measurements - 42" front and back Any fender or body trimming needed? (If so where?) - front air dam only
1999 gmc sierra z71, flowmaster super 40, KN filter, power programer, 33x12.5x16 sts's, Rancho 6", 16x8 extreme alloys!! zenon flares
#31 |
Most Extreme Elimination
Member ID: 1371
Re: Post Your Setup
Year: 1995
Make: GMC Model: Sierra - Extended Cab - 6.5' Bed 2wd or 4wd: 4WD Tire Size: 315/75R/16 Wheel Size: Stock - 16X7 Lift Kit Brand and Size: None Torsion Bar Rating or Code: GG - 6709 ft/lbs Torsion Bars Cranked? (How Much): 2.5", BJ Flip, BJ Spacers Torsion Bar Keys: AIM keys Lift Blocks: 2" Blocks Add-A-Leafs: None Body Lift: 3" Trailmaster Body Lift Aftermarket Bumpers: None Fender Height Measurements: 43" Front ~ 43" Rear Any fender or body trimming needed? (If so where?): Front Bumper Valance Old Pictures... ![]() ![]()
1995 GMC Z-71, 5.7L TBI, 3.42 gears, 14SF, G80, 3" Body Lift, 2" Blocks, 2.5" T-bar Crank,
Ball Joint Flip, Ball Joint Spacers, Rancho RS9000X's, 315/75R16 BFG AT KO's, N-Fabs, Power Slot Rotors, Hub-Centric Wheel Spacers, Stabilizer
#32 |
The goggles do nothing!
Member ID: 699
Re: Post Your Setup
96
Tahoe 4wd 38x15.50 TSL Radial 15x10 6" Rancho + 3" body 6" Superlift springs + 1.5" blocks in the back Rancho tbars cranked about an inch TJM bumper up front, nothing out back for now Front fender is trimmed but doesnt need to be, these tires dont rub this setup Will have pics up later today ![]() ![]()
#33 |
I really am an a$$hole™
Member ID: 12022
Re: Post Your Setup
1998
Chevrolet 4wd 315/75r16 American Racing Atlas 16x8 with 4.5" BS 6" RCD RGG no crank in these pics RCD 3.5" Lift Block RCD AAL 3" Body Lift GoRhino Grill Gaurd 46" no trimming, I could go with 37s if I wanted A comparison pic with my buddies 98 with 3" front 5" back and 285s ![]() ![]() Ah rain.
#34 |
Member ID: 14834
Re: Post Your Setup
Year: 1997
Make: Chevy Model: Silverado 2500 4wd Tire Size: 38x15.50x16.5 Wheel Size: 9.75x16.5 Lift Kit & Brand: Cognito 10''-12" Suspension Torsion Bar Rating: Stock Torsion Bar Crank: 3" cranked Torsion Bar Keys: Stock Lift Blocks: 2 1/2" AAL: New Atlas Springs Body Lift: None Aftermarket Bumper: None Fender Height Measurements: Front 51" Rear 49" Fender & Body Trimming: Front bumper valance ![]() Year: 1995 Make: Chevy Model: Tahoe 4d LS 4wd Tire Size: 33x12.50x15 Wheel Size: 15x10 Lift Kit & Brand: 6" Trailmaster Suspension Lift Torsion Bar Rating: Stock Torsion Bar Crank: Stock Torsion Bar Keys: Stock Lift Blocks: 2 1/2" AAL: Add a leaf Body Lift: None Aftermarket Bumper: None Fender Height Measurements: Front 43" Rear 42" Fender & Body Trimming: Front bumper valance ![]() Here are some side by side comparison's ![]() ![]()
1997 Chevy 2500 4x4, 7.4 liter,Wait4Me, 4.88's. Cognito 10"-12" Suspension, 38x15.50x16.5 STS's on 16.5x9.75 Mickey Thompson's
#35 |
Member ID: 8345
Re: Post Your Setup
Year -2003
Make -Chevy Model -Silverado 2wd or 4wd -4wd Tire Size -315/70R/17 Wheel Size -17x8 Lift kit size and Brand if not stock- 5-6in Superlift FIT kit Torsion bar Rating or Code: -Stock Torsion bars cranked or not and if so how much. - 1 in Torsion bar keys if any -NA Lift Blocks? - 4 in Add-A-Leafs? -NA Body Lift? -NA Aftermarket Bumpers? -NA Fender Height Measurements -Front 44 rear 441/4 Any fender or body trimming needed? (If so where?) Little bit of the airdam .[/quote] ![]() ![]()
2008 Chev. Silverado CrewCab Z71 5.3L
SOLD: 2003 Chev. 5.3L EC SWB Z71. Superlift 6" F.I.T. kit, 35/12.50/17 BFG AT's on 17x9 Xtreme Alloy 6001's. Wait4me tune.
#36 |
Must.....go.....faster...
Member ID: 22887
Re: Post Your Setup
Year-1992
Make - GMC Model - Sierra 1500 2wd or 4wd - 4wd Tire Size - 33x12.5x15 wild countries Wheel Size - 15x10 Lift kit size and Brand if not stock - none Torsion bar Rating or Code- stock Torsion bars cranked or not- cranked about 3" Torsion bar keys if any- nope Lift Blocks? 2" blocks Add-A-Leafs? No, coil over rear shocks Body Lift? no Aftermarket Bumpers? No Fender Height Measurements - 41" back, 39.5" front Any fender or body trimming needed? (If so where?) - Corner of bumpers, A little hammer work to bottom of fenders. ![]() ![]()
2003 Z71 ext. cab short bed, 4X4. Cherry Bomb single chamber extreme series muffler, 3" tips. OBX stainless headers, ORY, Tune by Blackbear performance, 285/75-16 Maxxis Bighorns on 16x10 AR diamond backs.
#37 |
Member ID: 10803
Re: Post Your Setup
Year-2001
Make - Chevy Model - Silverado 1500 2wd or 4wd - 4wd Tire Size - 315 BFG AT Wheel Size - 16x10 Lift kit size and Brand if not stock - 6inch Procomp Torsion bar Rating or Code- stock Torsion bars cranked or not- stock Torsion bar keys if any- stock Lift Blocks? 3inch Procomp that came with kit i belive Add-A-Leafs? 2inch procomp add-a-leaf Body Lift? 3inch PA Aftermarket Bumpers? No Fender Height Measurements - well fnd out tongiht Any fender or body trimming needed? (If so where?) - air dam only
Chevy 2001 z71 1500 5.3, 4.56, Flowmaster, K&N Generation II Air Intake Kit and a Tune by JESSEBUBB
6inch Procomp /3inch PA bodylift / Micky Tompson 16x10 / 37x13x16 Boggers
#38 |
Southern By Grace of God!
Member ID: 2260
Re: Post Your Setup
Year - 2002
Make - Chevrolet Model - 1500 Regular Cab Z71 2wd or 4wd - 4x4 Tire Size - 35x12.5x16 SuperSwamper SSR's Wheel Size - 16x10 Weld racing Scopio V Lift kit size and Brand - 6-8" CST Torsion bars cranked - Some (dont know an exact amount) Torsion bar keys - Stock Keys Lift Blocks - n/a Rear Springs - Custom Alcan springs in the rear Add-A-Leafs - n/a Body Lift - n/a Aftermarket Bumpers - No bumper but front Ranch Hand grill guard Fender Height Measurements - about 45.5" up front 47" out back (roughly) Any fender or body trimming needed - Trimmed front air-dam, fender metal in rear portion of front fender. ![]() 6-8" CST, 35" SSR's, 16x10 Weld Racing Scorpio V's Last edited by BDZ71 : 06-26-2005 at 05:33 PM. |
#39 |
Member ID: 27993
Re: Post Your Setup
Year - 1998
Make - Chevrolet Model - Extended cab K1500 with Z71 package Engine - 6.5 Turbo Deisel 2wd or 4wd - 4WD Tire Size - 33x12.50x15 Super Swamper Boggers Wheel Size - 15" american racing Lift kit size and Brand if not stock - 6" Procomp Torsion bar Rating or Code: Dont Know Torsion bars cranked or not and if so how much. - Not cranked as of yet Torsion bar keys if any - Stock Lift Blocks? - Rear 4" Add-A-Leafs? - Pro Comp Body Lift? - None Aftermarket Bumpers? - Front Custom Made With Winch Mount Fender Height Measurements - Never Measured Any fender or body trimming needed? - Front Fenders Boggers Rubbed At Full Turn Upgraded headlights signals and corners to apc clears, warn m12000, cobra cb with dual whips, custom front winch mount, in dash dvd navigation/information center, straight pipe exhaust, boost fooler, intercooler on the way, k&n filter, on board air in the works, and the list can go on forver but here are a few pics, sorry for the size |
#40 |
Money Pit
Member ID: 30183
Re: Post Your Setup
Year - 2004
Make - Silverado Model - 2500 CCSB 2wd or 4wd - 2wd Tire Size - 35x12.50R17 Wheel Size - 17x9 M/T Classic Lock Lift kit size and Brand if not stock - Fabtech 4" spindle Torsion bar Rating or Code: - ??? Torsion bars cranked or not and if so how much. - Cranked 2" Torsion bar keys if any - GM Green keys Lift Blocks? - 2" blocks Add-A-Leafs? - none Body Lift? - 3" body lift Aftermarket Bumpers? SS front Fascia and rear bumper cover Fender Height Measurements - 47.5" Any fender or body trimming needed? (If so where?) - Had to trim the SS front bumper cover to prevent rubbing. ![]() |
