#61 |
Premium Member #2
Registered (truck) Abuser
Member ID: 32112
Re: Post Your Setup
Year 1991
Make Chevrolet Model k2500 2wd or 4wd 4wd Tire Size 305 x 70 - 16 terra grapplers Wheel Size 16 x 8 Helo maxx 8 black Lift kit size and Brand if not stock n/a Torsion bar Rating or Code: 3/4 ton bars Torsion bars cranked or not and if so how much. 1/2" Torsion bar keys if any n/a Lift Blocks? n/a Add-A-Leafs? n/a Body Lift? P.A. 3" body Aftermarket Bumpers? n/a Fender Height Measurements 40" Any fender or body trimming needed? (If so where?) plastic air dam Needs nerf bars! ![]() ![]() Last edited by TIM222 : 05-17-2006 at 08:43 AM. |
#62 |
Lil Red Stepside
Member ID: 21092
Year - 1998
Make - Chevrolet Model - K1500 Silverado Z-71 Stepside 2wd or 4wd - Who would buy 2x4? Tire Size - 285/75/R16 (for now) Wheel Size - 16x8 (stockers) Lift kit size and Brand if not stock - ProComp Torsion bar Rating or Code - Stock Torsion bars cranked or not and if so how much - Stock Torsion bar keys if any - No (maybe fords) Lift Blocks - 4 Inch Procomp Add-A-Leafs - 2 inch procomp Body Lift- negative Aftermarket Bumpers - 6.5L Turbo Diesel (titz) Fender Height Measurements - at shop cant messure Any fender or body trimming needed? (If so where?) - We'll see when i get my 35's Lookin for a 14 bolt Full Float right now and SFA plans starting Before: After: ![]()
**max sig width is 500 pixels!**
#63 |
Member ID: 33035
Re: Post Your Setup
Z-71
37x12.5 MTR's 16.5x9.75 Rock Krawlers 4" Rancho Cranked 1.5" 5.5" Blocks AAL's 3" Perf. Acc. Ranch Hand Front End 48" Front and rear fenders ![]()
04 GMC ext. cab Duramax
Black H2's Edge with Attitude Last edited by WAR WAGON : 10-02-2005 at 06:29 PM. |
#64 |
Member ID: 32696
Re: Post Your Setup
2004 2500HD Crew Cab
4 wheel drive what lift? No blocks No torsion crank 16x10 Centerline Coolers 33x12.50 Trxus A/T's Minor triming of the airdam and the inner fenders. Nothing a sharp pocket knife could'nt handle. ![]() ![]()
2004 2500HD CCSB 4x4
#65 |
4x4'ing!
Member ID: 23406
Re: Post Your Setup
Year 2004
Make GMC Model Sierra 2wd or 4wd 4WD Tire Size 305/70/16 Claws Wheel Size 16x10 1079 Torsion bars cranked 2-3" Torsion bar keys Ford Lift Blocks? 4" Front 39 1/4" Rear 40" Front and inner Trimming.. ![]() ![]()
04 Torrid Red on red M6
catless mids,Iat relocation,Noltec diff bushing,descreened maf,coolent bypass,JHP tube with k&n and ported air box,tune,LSS,c5 pads,splitter
#66 |
Huskie Hater
Member ID: 15345
Re: Post Your Setup
Year: 1996
Make: Chevy Model: 2 Door Tahoe 2wd or 4wd: 4wd Tire Size: 285/75/16R BFG MT Wheel Size: 16x8 Lift kit size and Brand if not stock: Stock Torsion bar Rating or Code: ???? Torsion bars cranked or not and if so how much: Cranked 2" Torsion bar keys if any: Stock Lift Blocks: None Add-A-Leafs: None Body Lift: None Aftermarket Bumpers: Front- Custom with winch mount, Rear- Stock Fender Height Measurements: I will have to measure Any fender or body trimming needed: None When I first got it: After my roof rack: And with my bumper on: Mitch ![]() Swamper Brotherhood SSR Chapter Last edited by GoCougs : 10-13-2005 at 04:59 PM. |
#67 |
My custom user text.
Member ID: 24156
Re: Post Your Setup
Year: 2001
Make: GMC Model: Sierra Z71 2wd or 4wd: 4WD Tire Size: 285/75-16 Pro Comp X-Terrians Wheel Size: 16x8??? (stock) Lift kit size and Brand if not stock: n/a Torsion bar Rating or Code: n/a Torsion bars cranked or not and if so how much.: Cranked about 1.5" Torsion bar keys if any: none Lift Blocks?: not yet Add-A-Leafs?: no Body Lift?: no Aftermarket Bumpers?: no Fender Height Measurements: about 38" Any fender or body trimming needed? (If so where?): none ![]() ![]() Last edited by luvitlo94 : 10-24-2005 at 10:23 PM. |
#68 |
Member ID: 34063
Re: Post Your Setup
Year - 1997
Make - GMC Model - K1500 2wd or 4wd - 4WD Tire Size - 38x15.50x17 Wheel Size - 17x10 Lift kit size and Brand if not stock - Straight Axle Conversion with the ORU kit, crossover steering, hydraulic assist steering, 5.13 gearing front and rear, with a 14 bolt full floater and detroit locker. Front axle is a 1991 Ford dana 60 king pin. Sway Away 2.5 in shocks around and King bump stops in the front. Limit straps in rear. Lift Blocks - 6 in Atlas springs up front and 8 in Atlas springs in the rear with a two in block. Body Lift - 3 in Aftermarket Bumpers - Custom bumper by Four X Doctor in Burbank, CA, not yet completed Fender Height Measurements - Front 52", Rear 50" Any fender or body trimming needed - A little here and there! ![]() ![]() Last edited by WiNgMaN : 11-08-2005 at 05:55 PM. |
#69 |
Member ID: 34063
Re: Post Your Setup
Here is a pic with the Sway Aways on
#70 |
Member ID: 13248
Re: Post Your Setup
Year- 1994
Make- GMC Model- Sierra 1500 2wd or 4wd- 4wd Tire Size- 35x12.5 Wheel Size- 15x10 Lift kit size- 5 in Torsion bars cranked or not and so how much. Cranked quite a bit Lift Blocks? 3in Add-A-Leafs? no Body Lift? 2in PA Aftermarket Bumpers?no Fender Height Measurements- gotta check Any fender or body trimming needed? (If so where?) Front air dam, just a little. ![]() ![]() |
#71 |
Member ID: 13799
Re: Post Your Setup
1997
Chevrolet Silverado 4wd 38x14.50x16 Nitto Mud Grapplers 16x10 Cragar Soft 8's 4" BS Front:3" ORU brackets, 4" lift Alcan springs(47" stretched to 52" with 3" added after the center pin), 6* tapered zero rate, 2" longer shackle for the longer springs. Rear:4" ORD shackle flip, 3" lift Alcan spring, Zero rate. Reunel and XD9000i(350lbs) 47.5" Front and 47" rear. Inner fender cut ~8" up in the rear of the front, outer fender in the rear of the front cut and bent back a bit and bumper edge cut off for tire clearance. ![]() ![]() ![]() |
#72 |
Team White!
Member ID: 18751
Re: Post Your Setup
2000
Chevy Silverado 1500 4wd LT315/75R16 Dunlop Mud Rovers 16x10 American Racing Atlas 4.5 BS Superlift 7.5 Bracket Kit PA 3 inch Body Lift, Ford Keys cranked to level truck Torsion bar Rating or Code: Stock 1500 Torsion bars cranked or not and if so how much. maybe an inch? Still have plently of room to go Torsion bar keys if any: Ford keys Lift Blocks? 5 inch on top of factory 2 inch block (soon to be AALs) Add-A-Leafs? Not yet, maybe Xmas? Body Lift? Performance Accessories 3 inch Aftermarket Bumpers? Chrome with white trim Fender Height Measurements: 49 Front/49 Rear Any fender or body trimming needed? (If so where?) None, Still have tons of room!! ![]() ![]() ![]() 2000 Lifted Silverado-10 inches of lift and soon 38s on 20s! GOAL TO BE ON THE COVER OF TRUCKIN WITH A LIFTED SCLB My MySpace Truck Pictures Last edited by 4.8Silv4x4 : 12-10-2006 at 05:27 PM. |
#73 |
Re: Post Your Setup
1989
chevy 1500 2x4 - SFA 4x4 custom custom custom sitting on 31s soon to have 35x12.50 on 12x16.5 wheels 52" chevy rear springs up front chevy dana 44 front np208 rear shackle flip with doulble shackles work in progress ... rear shackle flip with '05 2x4 hanger and jeep shackle![]() |
#74 |
Member ID: 32959
Re: Post Your Setup
1996
Chevy 3500 Crew Cab 4wd 39.5 x 15 x 16.5 Truxus 16.5 x 10 Pro Comp 6" TB's Cranked a lil' more than inch and a half tapered blocks (4" I beleive) soon to be replaced by leafs 3" BL Stock Bumpers painted white 49.5 up front and 50" out back lil bumper triming ![]() ![]() ![]() The rims on now are MT Clasic II, though I have some all black teflon coated Mohaves for my offroads set up 38x13x16 TSL's 4.88 gearing, 14 bolt rear end , dual flow master's Last edited by comaone : 11-15-2005 at 03:31 PM. |
#75 |
SouthernMudders
Member ID: 26382
Re: Post Your Setup
Year 2004 Make Chevy Model 1500 Ext. cab 5.3 2wd or 4wd 4x4 Tire Size Super Swamper SSR 35's Wheel Size 16x10 Lift kit size and Brand Fabtech 6" Torsion bar Rating or Code: Stock Torsion bars cranked a little Torsion bar keys if any none Lift Blocks?5 1/2 Add-A-Leafs? 2" Body Lift? none Aftermarket Bumpers? none Fender Height Measurements 44 3/4 Front 44 /34 Rear Any fender or body trimming needed? (If so where?) Front end for offroad clearance
- Joe
2004 1500 Ext. Cab,Fabtech Lift (8"),Super Swamper SSR 35x12.5x16, Eagle Alloys 058 16x10 True Straight Pipes, Super Chips, and still addin....
#76 |
cut 'em off!
Member ID: 2493
Re: Post Your Setup
Year: 1993
Make: GMC Model: Yukon Tire Size: 315/75r16 Wheel Size: 16x8 Torsion bars cranked or not and if so how much: Not Cranked - no suspension lift Body Lift: 2" Any fender or body trimming needed? from 1" to 2" off all fenders all of the pertinent info and more pics @ www.yukoneer.com |
#77 |
Mud-boggin fool
Member ID: 37128
Year: 1978
Make: Chevy Modle: K-20 Custom Deluxe Drive: 4x4 Tires: 35x14.5 Rim size: 16.5 Lift: 6" Skyjacker Torsion Bar: yeah, right... Lift blocks: None Add-a-leaves: None Body lift: none Aftermarket bumpers: 14" Drop bumper in rear, dual 3" tube air tank bumper in works for front. Fender Trim: Front and rear corner of front fenders trimmed off. ![]()
1978 Chevy K-20: 6" lift, 35" Thornbirds, 355, 400 turbo, 4.10's, bucket seats, on-board air, and a paint job only a mother could love
#78 |
If in doubt, let em out!
Member ID: 4375
Re: Post Your Setup
2003 GMC Sierra
6-7.5" Superlift 17x9 Moto Metal 951 35" Xterrains 46" to fenders ![]() ![]() ![]() ![]() ![]()
#79 |
Member ID: 26447
Re: Post Your Setup
Year
Make:chevy Model:silverado ls 2wd or 4wd:4x4 Tire Size:35x13.50x18 Wheel Size:18 Lift kit size and Brand if not stock:4" trailmaster Torsion bar Rating or Code:i dont know Torsion bars cranked or not and if so how much: not much Torsion bar keys if any: Lift Blocks?:4" Add-A-Leafs?: Body Lift?:2" Aftermarket Bumpers?: bumper cover, roll pan(not installed yet tho) Fender Height Measurements:44 front and rear. Any fender or body trimming needed? (If so where?):none. ![]() ![]()
#80 |
Member ID: 15144
Re: Post Your Setup
Year:1990
Make:chevy Model:1500 2wd or 4wd:4x4 Tire Size:44X19X16.5 Boggers Wheel Size:16.5X12 Lift kit size and Brand if not stock:12+ custom Torsion bars cranked or not and if so how much: solid axle Torsion bar keys if any: Lift Blocks?:4" Add-A-Leafs?: Body Lift?:3" Aftermarket Bumpers?: Custom bumpers Fender Height Measurements:?? Any fender or body trimming needed? (If so where?):massive fender trimming chevy dana 60 and 14 bolt. 5:13 gears, detriot. np205 and turbo 400 tranny. Only 305 for now. |
