#121 |
Re: Post Your Setup
1987
Chevy V10 (K10) 4wd 36 x 13.50 17" 4 inch skyjacker Lift Blocks? Unfortunately Add-A-Leafs? Nope Body Lift? Nope Aftermarket Bumpers? Yes front Fender Height Measurements: Don't know Any fender or body trimming needed? (If so where?) Nope ![]() |
#122 |
Re: Post Your Setup
Year:1995
Make:Chevy Model:K1500 2wd or 4wd:4wd Tire Size:BFG A/T 295 Wheel Size:16x10 Lift kit size and Brand if not stock:Stock Torsion bar Rating or Code:Stock Torsion bars cranked or not and if so how much:Not Torsion bar keys if any:Stock Lift Blocks: none Add-A-Leafs: none Body Lift: 3in PA Aftermarket Bumpers:no
1995 K1500, Duel exhaust off the cat, 3in PA body lift, American Racing 16x10 wheels, 305 Cooper Discover STT's..
#123 |
The Man
Member ID: 8948
Re: Post Your Setup
1997
Z71 K-1500 265/75/R16 BFG All Terrains 3" Body Lift Warn Bumper Warn M12000 Winch ![]() ![]() ![]() Comming Soon... 315/75/R16 BFG Mud Terrains 15x8 American Racing Chrome Rims Pro Comp 6" Lift
'97 K-1500: 6" Pro Comp Suspension Lift, 3" BDS Body Lift, 315-75-R16 BFG Mud Terrains, 12,000lb Warn Winch
#124 |
Premium Member #2
Registered (truck) Abuser
Member ID: 32112
Re: Post Your Setup
Year - 1995
Make - Chevrolet Model - K1500 2wd or 4wd - 4wd Tire Size - 325x60-18 - 33.5x12.8-18 Wheel Size - 18x10 Lift kit size and Brand if not stock - none yet Torsion bar Rating or Code: - stock Z71 Torsion bars cranked or not and if so how much. - 2" Torsion bar keys if any - N/A Lift Blocks? - 2" Add-A-Leafs? - N/A Body Lift? - 3" Aftermarket Bumpers? - N/A Fender Height Measurements - 42" Any fender or body trimming needed? (If so where?) - N/A ![]() ![]() ![]()
2003 2500HD 8.1 ALLISON 4wd ECSB 4.10s *new*
1995 Novi 2000 Supercharged 5.7 Z71 3" body 2" torsion 33's-18's *SOLD*
#125 |
weekend knee dragger
Member ID: 36107
Re: Post Your Setup
Year--- 2002
Make- GMC Model- 2500HD 2wd or 4wd- 4wd Tire Size- 38/15.5 r16 Mickey Thompson MTZ's Wheel Size- 16x10 American Racing Bajas Lift kit size and Brand if not stock- 6" Pro Comp full drop Torsion bar Rating or Code:- Factory bars (what ever the HD's come with) Torsion bars cranked or not and if so how much.- Driver side cranked to level side to side Torsion bar keys if any- Green keys (passenger side bolt only has 1 turn on it, driver side has about 5 turns) Lift Blocks?- 5.5" blocks (really only 5" blocks but called 5.5's for some reason) Add-A-Leafs?- yes Body Lift?- yes 3" Aftermarket Bumpers?- no Fender Height Measurements- 53" front 53" rear Any fender or body trimming needed? (If so where?)- none needed but I did remove the air dam from under the front bumper a long time ago because I didn't like how it looked. ![]() ![]() ![]()
2002 GMC 2500HD CCSB, 8.1 + Ally, SFA, HP60 with some Dodge and Chevy parts and TracLok, 5.13's, 7" custom 52's in front, 8" Deavers out back, 3" body lift, 38/15.5x16 MTZ's, 16x10 American Racing Baha's.
#126 |
Re: Post Your Setup
New here, thought I would introduce myself here with a crappy camera phone pic of my truck. (sorry, only pic I have at work)
2001 Z71 36" SS TSL 16X10 Rancho torsion bars cranked a little 3"PA very little trimming ![]() Last edited by bondog2000 : 05-19-2006 at 09:05 AM. |
#127 |
Registered Noob
Member ID: 46987
Re: Post Your Setup
Year: 1998
Make: Chevy Model: Ext Cab, 1500 z71 2wd or 4wd: 4wd Tire Size: 265 75r16 Wheel Size: ? 16x7 (stock) Lift kit size and Brand if not stock: n/a Torsion bar Rating or Code: ? Torsion bars cranked or not and if so how much.: see below Torsion bar keys if any: n/a Lift Blocks?: n/a Add-A-Leafs?: n/a Body Lift?: n/a Aftermarket Bumpers?: n/a Fender Height Measurements: 36" front & rear Any fender or body trimming needed? (If so where?): nooooo As you can see, I'm starting from scratch here. Does anyone know if this year/model truck is level from the factory (front to rear)? I'm not sure if the previous owner cranked the T-bars to get it level.
I need a pic...
98 z71 ext cab, 5.7L Last edited by Quink : 05-24-2006 at 06:17 AM. |
#128 |
Re: Post Your Setup
Year: 2003
Make: Chevy Model: Z71 Tahoe 2wd or 4wd: 4wd Tire Size: 315/70/17 Wheel Size: 17x8 Lift kit size and Brand if not stock: Pro Comp 6" Torsion bar Rating or Code: Not sure Torsion bars cranked or not and if so how much.: n/a Torsion bar keys if any: n/a Lift Blocks?: 5" blocks from the pro-comp kit Add-A-Leafs?: n/a Body Lift?: n/a Aftermarket Bumpers?: nope Fender Height Measurements: Havn't checked Any fender or body trimming needed? (If so where?): very slight trimming in the front. ![]() ![]() 2003 Tahoe Z71, Pro Comp 6" suspension lift, 315/70/17 BfGoodrich A/t, 17" Pro Comp Xtreme wheels, Westin Grille Guard, Texas Flag Bowtie, Hypertech Power Programmer III, Flowmaster 50 Series |
#129 |
Country Boy
Member ID: 46885
Re: Post Your Setup
Year: 2003
Make: GMC Model: Sierra 2wd or 4wd: 4wd Tire Size: 285x75x16 Wheel Size: 16 Lift kit size and Brand if not stock: stock Torsion bar Rating or Code: Torsion bars cranked or not and if so how much: 2.5 turns Torsion bar keys if any: Lift Blocks? no Add-A-Leafs? no Body Lift? no Aftermarket Bumpers? no Fender Height Measurements Any fender or body trimming needed? (If so where?) |
#130 |
Re: Post Your Setup
2003
Chevy 2500hd crewcab sb 4x4 duramax 37x13.50 r 17 toyo mts weld rims 6-8 cst lift torsion keys dual bilstien 7100 w/ resv. up front singles in the rear atlas springs in rear no blocks a bit stiff lol light cut on lower valance on front bumber they tire rub on the inside fram on full turns when going off curbs or out of drive ways. that is mainly becuase the rim offset is not right but im not spending $1600 for new rims so I will live with it |
#131 |
Member ID: 42166
Re: Post Your Setup
here is a pic of mine, it looks like it is raked but it is not that bad.
![]() ![]() 05 Sierra Superlift 6-7.5", Ford keys, 3"BL, AAL, 1" Zero Rates, Shackle Flip, 39.5" Iroks On 17x9 7089s, 14FF, 5.38s, Discs, Glo Cover, ARB Air Locker, TransGo Shift Kit, Corvette Servo, EFI Live, Flowmasters, Cognito Tie Rods... |
#132 |
Member ID: 48401
Year 95
Make Chevy Model Silverado 2wd or 4wd 4X4 Tire Size 35X12.5 Wheel Size 16.5X9.75 Lift kit size and Brand if not stock ORU 3" + 4" springs/crossover steering.HP D60 front,D70 dually rear,4:56. Torsion bar Rating or Code: N/A Torsion bars cranked or not and if so how much. N/A Torsion bar keys if any N/A Lift Blocks? 5" rear Add-A-Leafs? 2.5 rear Body Lift? N/A Aftermarket Bumpers? Soon to be WARN classic for my 8,000 upright Fender Height Measurements Any fender or body trimming needed? (If so where?)Bushwacker cut-outs. ![]() ![]() ![]() ![]() Sorry,I go crazy w/the pics. sometimes me PETE Last edited by HeavyChevy#1 : 05-30-2006 at 06:44 PM. |
#133 | |
Member ID: 43695
Re: Post Your Setup
THATS FREAKING SWEET MAN, ID LIKE MY 2500HD TO LOOK LIKE THAT SOME DAY. I SEE THE FRONT BUMPER GOES STRAIGHT ACROSS INSTEAD OF THE CUT OUT, WUT KIND OF BUMPER IS THAT? |
#134 |
Member ID: 37329
Re: Post Your Setup
Year: 2004
Make: Chevrolet Model: 2500HD SCLB 2wd or 4wd: 4wd Tire Size: 36x13.50 IROKs Wheel Size: 16x10 DC-1's Lift kit size and Brand if not stock: 6" Pro Comp (Full Drop) Torsion bar Rating or Code: Stock Torsion bars cranked or not and if so how much: ~1" Torsion bar keys if any: Stock Lift Blocks?: 4" Add-A-Leafs?: Yes Body Lift?: None Aftermarket Bumpers: None Fender Height Measurements: 47.5" Front, 48" Rear Any fender or body trimming needed? (If so where?): Yes, front air dam Before: ![]() After: ![]() ![]() |
#135 |
Member ID: 15241
Re: Post Your Setup
[b]Year- 2001
Make- chevy Model-LS? 2wd or 4wd-4wd Tire Size- 36x13.5 Wheel Size-16x10 Lift kit size and Brand if not stock- superlift 6-7.5 Torsion bar Rating or Code:- Ford keys Torsion bars cranked or not and if so how much.- couple inches Lift Blocks? With kit Body Lift? 3" PA Aftermarket Bumpers? Aim Industries front Fender Height Measurements- 49 all round ![]() ![]() Brett
#136 |
Ottawa_denali
Member ID: 35627
Re: Post Your Setup
Year 1999
Make GMC Model Yukon Denali 2wd or 4wd 4WD Tire Size 35x12.5x17 Pro Comp Mud Terrains Wheel Size 17x9 Pro Comp 1079 Lift kit size and Brand if not stock 6" RCD Torsion bar Rating or Code: Stock Torsion bars cranked or not and if so how much. 2" Torsion bar keys if any Ford Keys Lift Blocks? 1" Add-A-Leafs? No Body Lift? No Aftermarket Bumpers? No Last edited by Ottawa_Denali : 06-27-2006 at 12:23 PM. |
#137 | |
SAS-here we come
Member ID: 30807
Re: Post Your Setup
#138 |
Re: Post Your Setup
My dads truck, 2006 GMC 2500HD 6.6 duramax and 33inch MTRs. 6 hole dog box. Big hitch and plow frame drags in mud.
![]() My truck, stock 78 3/4 with Accel racing coil, dual glass packs, and oldschool mud terrains. Ive had it for about 2 weeks and have allready managed to bury it up to the bottom of my cab. ![]() |
#139 |
TOM D. A55hole
Member ID: 35478
Re: Post Your Setup
Year: 1999
Make: GMC Model: Yukon 4-dr 2wd or 4wd: 4WD Tire Size: 35"x12.5" 16" Mickey Thomson Baja HP ugly but $200 Wheel Size: 16"x7" stocker's Lift kit size and Brand if not stock: stock Torsion bar Rating or Code: Stock Torsion bars cranked or not and if so how much: 2" crank Torsion bar keys if any: Stock key's Lift Blocks? 2" Add-A-Leafs? No Body Lift? No Aftermarket Bumpers? No
99' YUKON - 35" on 2.5"
#140 |
BIGGER & BETTER in TEXAS!
Member ID: 49870
Re: Post Your Setup
Year: 2004
Make: Chevy Model: Crewcab Z71 2wd or 4wd: 4WD Tire Size: 285/70/17 BFG M/T's Wheel Size: 17"x7.5" stocker's Lift kit size and Brand if not stock: 6-7.5 Superlift in process! Torsion bar Rating or Code: Stock Torsion bars cranked or not and if so how much: 2" crank Torsion bar keys if any: Stock key's Lift Blocks? 2" Add-A-Leafs? No Body Lift? No Aftermarket Bumpers? Replacement front w/ 4 lights ![]() 38" Swampers & Rockstars back on! TEXAS REBELS Last edited by tatez71 : 09-29-2006 at 03:15 PM. |
