#1 |
Member ID: 13799
Driveshaft finally!
Finally got the new front shaft, took long enough to figure out what I was going to do and make it happen. No more CV
![]() ![]() Crazy angle on the Tom Woods 1350 u-joint, even without grinding on the 1350 yoke yet. Doubt Im going to have to now(35*, the angle finder is on the wrong orientation). ![]() Left-Old 1310 u-joint Right-New 1310 u-joint ![]() Last edited by bggrnchvy : 03-09-2006 at 05:15 PM. |
#2 |
16oz. to freedom~~
Member ID: 31135
Re: Driveshaft finally!
Nice
2007 Ford F-150 King Ranch 4x4
2008 Lexus IS250 2005 Mercedes CLK320 2006 Honda CR-V ELX 4WD 2004 Chevy 3500 Duramax Dually 4x4 LT 1997 Chevy Suburban 5.7L 2WD |
#3 |
Member ID: 10803
Nice and did take awhile. Hopefully it will work out for ya. Now lets see how it looks on the truck
Chevy 2001 z71 1500 5.3, 4.56, Flowmaster, K&N Generation II Air Intake Kit and a Tune by JESSEBUBB
6inch Procomp /3inch PA bodylift / Micky Tompson 16x10 / 37x13x16 Boggers
#4 |
Member ID: 13799
Once the new crossmember comes in and I mount it, Ill put in the driveshaft and snap some pic's.
#5 |
Member ID: 13799
![]() ![]() ![]() UPS showed up today and brought a bunch of goodies, but the best would be the crossmember Zach built me. Its getting paint now, and I have a drill, tap and G8 bolts and washers standing by. |
#6 |
Member ID: 13799
![]() Out with the old and almost in with the new, 3 more holes and two of those need to be tapped. |
#7 |
Member ID: 10803
Cool, why did you need a new crossmenmber? it was cause of the angles right?
#8 |
Member ID: 13799
Yea, at full droop with no CV the front shaft will have to somehow bisect the stock crossmember...not good.
#9 |
Member ID: 10803
Yeah i understand now. That new one you got should work great for you.
#10 |
Member ID: 13799
![]() ![]() In, but still have to drop it down a little and hit the floorboards a little to as the new one put the end of the t-case up about 3/4 of an inch. No driveshaft in yet as I seem to have lost my 1350 u-bolts this evening. |
#11 |
Member ID: 13799
![]() ![]() ![]() And its in. Vibrations in 4wd get bad at about 25mph, definitley not a highway worthy driveshaft, shouldn't be an issue for me though. |
#12 |
looks sweet. is that driveshaft for extreme flex so it extends?
My Car Domain
Victory Red 1999 NBS Z71. 6" Trailmaster Lift. Wait4Me. K&N 57 Series CAI. Taylor Wires. NGK's. Turbo Exhaust. Cowl Hood. Soft Tonneau. Eagle Alloys. Discover STT 305/70R/16 |
#13 |
Member ID: 13799
Its designed so it doesn't pull apart like the last one before I top out my 12" shocks. So I guess the answer to your question is yes.
#14 |
Member ID: 13799
Finally finished grinding the 1350 yokes(they don't come with the cast in depressions like 1310 and 1410 yokes). I know its not beautiful but that much die grinding just sucked.
#15 |
Member ID: 16820
That's a sweet looking crossmember. I lucked out because my cv stuck out far enough that the crossmember won't be an issue. Did you actually need that much travel on the driveshaft or was that just overkill?
'95 Z-71 Ex-Cab 38x15.50 MTZ's on 18" Welds
2004 5.3L Engine Swap (tuned w/ EFI live) Front: HP D44, 6" Custom Alcon Springs, 4.88's, Limt'd Slip Rear: 14BSF Eaton E-Locker, 4.88's, Disc Brakes ![]() Van-GMotorsports.com |
#16 |
Member ID: 13799
I pulled apart a 7" slip, the next step up was this 17* slip thing, its way more than I need but its good to have extra.
#17 |
BigBlue
Member ID: 20380
very nice kyle.
![]() 2000 ECSB - Fabtech - 35x14.50 Iroks- 18x10 Welds - HPP3 - Detroit RIP Jason Payne |
#18 |
Dune Slut
Member ID: 42595
Is there anyway to get no vibration out of the front shaft? I am doing a sfa on this truck (sig) in june, have all the stuff, but the autotrac scares me, I would just buy a shaft, but everyone I talk to says there is no way to eliminate the vibrations, autotrac case can kick in at any time and it scares me any help would be great, sorry to whore out the thread! Will sumthing like the shaft shown here with a dual card. joint work???
![]() 2006 ECSB L33/Z06Cam/TBTC/LTs/ORY/Baker Engineering Tune&Trans/6-RCX/20 Spys/35 Toyo/Full Detroit/Handbuilt 3in TD's/BEI Turbo setup soon! 1998 RCSB S-10 Lm4/Z06 Cam/T-56/Zexel/Caltracs/Baker Engineering Tune/Static 6-6 drop |
#19 | ||
death to pluto
Member ID: 12061
not even a fancy shaft can help autotrac once you SAS... your gonna have to get a 241 or the like
no longer a 2wd solid axle pavement pounder
![]() TSL Chapter :evil: Quote:
#20 | |
Member ID: 16820
Kyle isn't running an autotrac transfer case. His vibrations come from the driveline angle and an unbalanced driveline. I have a SFA and I get no driveline vibrations. You will just need to swap out the t-case and be done with it ![]()
| Advertisements |
| Thread Tools | |
| Display Modes | |
