#1 |
Tow hooks with a body lift......
What does everybody do with their tow hooks when they body lift. I know on some trucks you can flip them over and change sides and they will still work. Any one have pics of a body lifted 03-06 truck with the hooks still on?
#2 |
beer?
Member ID: 31494
Re: Tow hooks with a body lift......
you can just cut out notches on bottom of the stock plastic lower valence to make them fit:
![]() you dont have to flip them or anything, hope this helps! ![]() 2004 C1500, dumped exhaust, 3" fabtech spindles and blocks, 3" PA body lift, crane cams programmer, 35" toyo AT's, MT classic II's, random stickers, zip ties holding stuff up, seat molded to my ass |
#3 |
FTS FTL!
Member ID: 18570
I made some shackle mounts to replace mine.
#4 |
Premium Member #38
Forum Leader
Member ID: 20434
I fabed my bullbar to still come through the valance in the normal place. I am still thinking about welding some tow hooks under the front end somewhere so I have a nice front tow point.
#5 |
Dune Slut
Member ID: 42595
I would try the flip, or make a set of d ring shackles like frostbite b4 I cut my vallance but thats me.
![]() 2006 ECSB L33,6Rcx,35 Toyo,20XD spys,Comp 222/224/112lsa,Baker Engineering Tune/Trans, Yukon 4.56, Yank3k,LTs, Maggie 112/Handbuilt 3in TD's Last edited by SilveradoLQ9 : 06-03-2008 at 06:18 PM. |
#6 |
Member ID: 86965
I made a bar that bolts up the same as the stock hooks that stick out about and inch, drilled a hole to fit 3/8" chain grab hooks on... I normally leave the hooks out unless I need them (keeps the clean look) similar to frostbites...
99 GMC Sierra
Pro Comp 6" Lift (plus 2 add a leafs) ORD Shackle Flip + Super Shackles 3" Body Lift Pacesetter LTs 3" True Duals w/Magnaflows 4.56 gears w/Eaton posi 36x15.5x20 Mickey Thompson MTZs 20x10 Moto Metal 954 GM Hot Cam w/ LS6 springs Wheatley Custom Tune 3/4 Ton CV Conversion |
#7 |
03 Z71
Frostbite...can you tell us how you fabd those D-ring shackles? those are pretty sweet.
![]() 3" BDS BL, 3" BDS Blocks, Ford Keys, Skyjacker Hydro7000 Shocks, 315/75-16 Maxxis Buckshot Mudders, Flowmaster 40 series muffler, Westin Black Brushguard, KC Daylighters w/stone guards |
#8 |
Member ID: 34549
![]() ![]() I think they are pretty much the same concept as Frostbites, but i took off the front valance, cause it would have been ripped off during wheeling anyways.
1999 GMC Sierra
![]() Thanks 454ss for the sig!!! |
#9 |
needs to get a life
Member ID: 13448
I welded a shackle to a piece of 1 1/4 x 1 1/4 thick wall tubing and then bolted the tubing to the frame like a stock tow hook does. Used them a couple weeks ago and the old man kept tugging my truck as he towed it and using just one hook they worked fine.
1995 Silverado - Very torquey, fun to drive (see below)
1999 NBS Silverdo - Torque? Never heard of such a thing.
#10 | |
FTS FTL!
Member ID: 18570
Replaced Towhooks with Shackle Mounts
#11 | |
Member ID: 86965
One big advantage of the OBS is that fact that the bottom of the bumper is straight and the valance can be removed without the "something's missing" look. NBS has the different style... there is also a big difference from the Chevy to the GMC (more metal on the sides and lower fog lights on the GMC). After i installed my body lift, I put the bumper back on without the valance... it was only that way for 1 day. I spent several hours taking the bumper and valance off and on and trimming the valance as close as I could to the tow hooks to keep the clean look...
99 GMC Sierra
| Advertisements |
| Thread Tools | |
| Display Modes | |
