06-22-2008, 08:05 PM
god damn canadians eh!
Ball joint flip , UCA rubs wheels
I been researching ball joint flips and iv'e seen people say that your UCA will rub on stock wheels. I have 36" tires on stock wheels. Any suggestions? What kind of after market wheels would fox this?
Originally Posted by Spazmo
F*ck that, I feed off of these pissing contests. FSC "debates" are usually extremely entertaining.
I'm Canadian, there's no doot aboot it!!!
06-22-2008, 08:08 PM
#2
Cowboy From Hell
Re: Ball joint flip , UCA rubs wheels
Assuming you have 16"s, I would think 17"s would clear.
DD: 2001 Silverado 1500 ECSB 5.3L
06-23-2008, 10:12 AM
#3
i heard 15 will clear, because the 17 has a bigger circomference and i think the 17 would rub even more. Or an after market wheel with less bacck spacing.
11-05-2009, 06:53 AM
#4
has been "had"
 an old one here, but didn't want to start a new thread about it.
i am going to do the bj flip, but have factory obs 16" wheels. i've searched & still couldn't find a definitive answer about them rubbing on stock wheels or not. i do have a set of 17's, but i need tires for them. in other words, i want to make sure i can clear stock wheels before i do the flip.
thanks!!!
 - i'm new
 <-thanks again, xZoomerZx
96' burb - 6-inch RC, 4.56's, 35's, detroit, SYE, realift, flow 50's, w4m, 06' 17's, other stuff
98' silvy - z71, 285's, flow 50's, 1" block, some crank, blackbear
11-05-2009, 07:15 AM
#5
bikes cars trucks women
I ran stock steel 16s with no problem
91 GMC 350 5 speed, SAS started, HP 60/14 bolt
91 camaro, bolt ons, 454 started on rebuild, waiting on wieland 8-71 blower
'00 ZX9R, 150 RWHP
'84 K10, 6" Tuff Country, 35s. soon to have 1 ton swap and 383 TPI
'63 CJ5
TUFF COUNTRY LIFT FOR SALE $450, EAGLE WHEELS AND 35" BFGs $1200
11-05-2009, 07:30 AM
#6
has been "had"
any idea if those have the same backspacing as the aluminum ones?
 - i'm new
11-05-2009, 07:49 AM
#7
Enginerd
Regardless, the Aluminum wheel has a much smaller ID than the steel wheel does. This is likely to be the cause (or at least a large contributor) of the rubbing on the UCA.
2004.5 Dodge 2500 CTD - DD/Tow Rig
1991 Silverado - Coil sprung 3-linked D60, 14FF, 38.5x11 Boggers, mostly stock...Build Thread
11-05-2009, 08:04 AM
#8
i too would like to find out if it will work with the stock rims or not.
11-05-2009, 09:01 AM
#9
yeah me too....
Why dont one of you guys do it and let me know....LOL
11-05-2009, 11:30 AM
#10
hahah i might today..idk
11-05-2009, 01:20 PM
#11
has been "had"
yes please. i would like an answer asap
 - i'm new
11-05-2009, 01:36 PM
#12
what is the purpose of doing a ball joint flip? does it help if you are cranked?
11-05-2009, 01:41 PM
#13
has been "had"
it puts the upper control arms further away from the bumpstop so it will ride better & not constantly be hitting them. and will help the longevity of the ball joints by putting them at a better angle.
 - i'm new
11-09-2009, 08:34 AM
#14
Soooo......Anybody try this yet???
11-09-2009, 08:42 AM
#15
has been "had"
i was just getting ready to bump it up too.
 - i'm new
11-10-2009, 05:42 PM
#16
DUH! Big Red Truck!
less backspacing will help, both the stock steel and aluminum wheels are 5.5" BS
11-12-2009, 11:04 PM
#17
in my experience stock steel rims rubbed the bolts holding the bj in but you could cut the bolts to fit , i dont think aluminum rims would work out
| Thread Tools |
| Display Modes |
Linear Mode
