Old 07-04-2008, 09:04 PM   #1
joshman
joshman's Avatar
Member ID: 40885
ARB install into 9.5" troubles
Has anyone ever not been able to set the backlash with one of these? I had about 50 thousandths with the adjuster nut all the way in. Does someone sell shims for the ring gear? Or could I make my own from some shim stock? Thanks.
'94 ECSB w/ a 350 that's bone stock, DC 6.5" lift, 35" claws on rock crawler wheels, 4.56 gears, York OBA, XM and CB
my off road club: www.core4x4.org
Old 07-04-2008, 11:30 PM   #2
silverado_nolan
Forum Leader
silverado_nolan's Avatar
Member ID: 40655
Re: ARB install into 9.5" troubles
should have gotten an install kit
Originally Posted by silverado_nolan
hey n*gga steve you want a french fry??
Originally Posted by N*gga Steve
fo sho n*gga fo sho
Old 07-06-2008, 09:18 AM   #3
joshman
joshman's Avatar
Member ID: 40885
Install kit? Do you mean all the other stuff that came with the air locker? Just to clarify myself, the air locker seems to a bit longer than the stock. So when i screw the adjuster nut out, it bottoms out before I can get the lash set.
Old 07-09-2008, 09:02 PM   #4
ilmudrunner
A1, A4, A5, A7 Certified
ilmudrunner's Avatar
Member ID: 40513
he was talking about a master differential install kit. comes with a pinion nut, pinion crush sleeves, pinion spacers, side bearing spaces, new bearings...everything you need to overhaul your diff.
'98 GMC Sierra K1500
6.5" DC, 3" PA body lift, 37x13.50 Toyo Open Country MT's, 17x9 Helo Black Maxx6, 4.88 gears, detroit locker rear, thunderbolt muffler (flowmaster 40 knockoff)
