#1 |
Member ID: 92402
3/4 ton suspension on 1/2 ton
I would like to lift my sierra 1500 2wd using factory parts if possible. i like the height of a stock 2500 2wd with a level kit up fornt. I know the leaf spring in the rear will work but I cant find any info on the front suspension of a 2500. I want to use factory parts for a couple of reasons. a. reliability. b. cheaper sometimes than aftermarket. c. I want to show people how much you can do with GM parts or modifying them. I couldnt find a thread like this anywhere so apology in advance if its somewhere else. Thanks!
I can take anything apart and almost put it back together.
05 Sierra SLE 2WD 5.3 ECSB...modified intake, coolant throttle bypass, drop in K&N |
#2 |
Custom
Member ID: 37776
Re: 3/4 ton suspension on 1/2 ton
I think it would be cheaper and easier to just but a 2500 personally. But if you have the money and skills you can do anything you want. Nothing is going to bolt up (for the most part) though. The front frame designs are different.
#3 |
Member ID: 5321
You would have to relocate the cross member for the torsion bars, and most of the parts like mentioned just won't work without mod's.
Just buy a quality lift and you'll be fine. Steven ![]() 2007 GMC Sierra SLT Vmax. 4.10 gears, Bedrug, Boss MT100 20x8.5 wheels/Kumho STX tires, Extang Bed cover, Line of Fire, Denali Grill, GM Performance Intake and DiabloSport Predator. |
#4 |
Keep on truckin
Member ID: 28536
what yr is your truck....I have some 3500 stuff in my 92 1500
#5 |
needs bigger tires
Member ID: 60284
First of all, you'll have to replace all of the 1/2 ton IFS with 3/4 ton IFS. And you didn't say what year it is, but if its an OBS or NBS, you've got coil springs, and 3/4 tons have torsion bars, so that would be a lot of work to swap. The rear suspension shouldn't be too difficult to swap though. Also, if you want it to sit like an HD, their frames are different, making them sit 2" higher than a 1500.
But first things first. What year is your truck? ![]() http://www.fullsizechevy.com/forums/general-discussion/projects-builds-restorations/348651-kirks-truck.html[/url] < My build thread http://rpmtrucks.net/index.php?referredby=30 < check it out |
#6 |
Member ID: 92402
I have a 05 Sierra ECSB w/5.3. The whole reason for the lift is because I have a camper shell on the back full of tools( its for work) and with the cap on it alomst looks like I dropped the truck. I still want to do more research before I buy anything. Thanks for all the info so far.
#7 |
Member ID: 86965
Add-a-leaf set... lifts rear a bit and adds about 500lbs more suspension capacity per set
99 GMC Sierra
Pro Comp 6" Lift (plus 2 add a leafs) ORD Shackle Flip + Super Shackles 3" Body Lift Pacesetter LTs 3" True Duals w/Magnaflows 4.56 gears w/Eaton posi 36x15.5x20 Mickey Thompson MTZs 20x10 Moto Metal 954 GM Hot Cam w/ LS6 springs Wheatley Custom Tune 3/4 Ton CV Conversion |
#8 |
like a rock
Member ID: 58382
just change your springs in the rear and get some coil spacers up front
| Advertisements |
| Thread Tools | |
| Display Modes | |
