#1 |
Just my Luck....
Member ID: 49905
Drive shaft extended for 2 door tahoes?
I got a 6.5" full drop needing to go on, but im trying to get everything together for a smooth install. Iv'e searched around for a few hours now, and havent found a straight answer. So how much if even at all, do i need to get my drive shaft lengthed on my 2 door Tahoe. ill be putting 8" springs in the rear with 1 or 2" blocks. If no one knows, how do i measure to make sure i get the correct drive shaft length? Thanks. -Anthony
![]() 95 2-Door Tahoe 4X4 5.7L 17" wheels, 31" Tires |
#2 |
Member ID: 82615
Re: Drive shaft extended for 2 door tahoes?
as far as I know you should be fine.
![]() 1994 Chevy,9" total lift,37x13 boggers,stock gears,14Bolt SF,350,soon to have 5.13s and locker front and rear. 1996 Chevy,DD,1 1/4" block,33x12.5 claws,305. |
#3 |
22's and man boobs baby!!
Member ID: 86949
you should be ok. you will need to re route the exhaust with the front driveshaft, unless you have true dual exhaust with 2 down pipes.
Life's too short to pretend you give a sh*t
1993 K1500 Blazer 32" BFG A/T's and Slight Torsion Bar Crank |
#4 |
Intenionally blank
Member ID: 39135
Curious myself. Hopefully be lifting mine, don't want any unexpected surprises...
Stuff for sale: 78/79 HP60, ORU SAS kit, ORU steering stuff, BDS springs and a doubler for above axle. PM me!!!!
http://community.webshots.com/user/b454rat |
#5 |
Member ID: 63932
Why would you put a 1-2" block along with the 8" springs, your gonna have pretty steep angles getting it level with all that...just run the springs IMO
And get tons of pics! ![]() ![]() '99 2dr Z71 Tahoe - 36x12.50 TSL Radials, Black Rock Crawlers, 3" Summit BL, Ford Keys, 2" Block, Wheatley 93 Octane Tune Super Swamper Brotherhood |
#6 |
Just my Luck....
Member ID: 49905
sweet, i was pretty sure id need a longer drive shaft. Bama2door, i want the back raked about an 1-1.5"
#7 |
I have 8in leafs springs also. I put angled shims to make it the driveshaft line up better.
#8 |
Just my Luck....
Member ID: 49905
what kind of angled shims are they?
#9 |
I don't remember the brand name but I got them at ORW. They are 0.5-1" angled shim. Its basically and angled block.
#10 |
can't make up his mind
Member ID: 78058
If you want the back raked 2" get the same amount of lift front and rear.
![]() 2002 Red ECSB LT Z71: RC leveling kit with 36" TSL's, Flows 40 series, 9" DC lift soon 2005 trx400ex with tons of mods
| Advertisements |
| Thread Tools | |
| Display Modes | |
