10-28-2009, 10:39 PM
#41
DUH! Big Red Truck!
Re: almost done with lift
Originally Posted by carloracer1987
Why are you dissing this guys truck grease? Dont you listen to your mommy if you aint got nuttin nice to say keep your F*ckin mouth shut before i slap you.
Nice truck though !
because there are things on the truck that really dont make sense, nor does his logic on why they're there (or not there).
the Rock Jock centersection by itself is $1000, vs a complete hub to hub 60 that you dont have to have custom built for $1000 (high end)... evev if he were to take the "boneyard" 60, and throw all of the internals away, it would still come out cheaper, and doing the job just as well with the addition of a $150 cover.
the ubolt flip... you can buy the centersection for $1000, but not spend $80 not to drag ubolts when it is taken offroad.
and why would you have a stronger front axle, and a weaker rear axle? the rear is driven 100% of the time, so it should be stronger.
10-30-2009, 01:52 AM
#42
Originally Posted by GreaseDog
and a weaker rear axle than the front axle... someone didnt do his homework.
so the rock jock was necessary, but $70 worth of parts so you're not dragging rear ubolts is "too much"? thank you for confirming my suspicions.
The front and rear moser are both 60 axles one just has the high pinion, so as far as axles they cant be that much different in strength. The actual axles are a lot thicker and stronger then the stock 10 bolt i was running, which i was surprised it didn't break with the beating it took and after 130,000 miles as a work truck. Many people run 35-38" tires on the stock axle with no problems.
i had 31" tires on it and typically if i nailed it going 55 or less they spun. And i did that a lot lol
http://www.lsxvideo.com/view_video.p...78ec76a704e9b5
I have kept this truck like new since 1996. The reason i am building this truck is to have as an emergency vehicle that is reliable, not to bash it across rocks for fun. So i doubt ill be dragging my u bolts. What suspicions do you have of me?
Originally Posted by BigChevy17
im drooling over your truck man
if you dont mind me asking, how much is all that running you?
I don't know exactly yet, but i will when it's done.
Yesterday i went by and they had the exhaust done on it, ended up putting a magnaflow 2 in 2 out with a x crossover inside the muffler. ill have to get a sound clip of it because it really toned down the loudness.
i had 2 magnaflow race series originally and it sounded like straight pipes, then i got 2 super 44's hoping to muffle it some, which it did a little at idle and low rpm but no change above 2500 rpm, so i couldn't be happier with the sound of it now.
96 GMC sierra Z71 ECSB
10-30-2009, 06:24 AM
#43
RAMZ TRK
Originally Posted by fastlt1
What did that front axle set you back? I like the 6 lug look too. Can you fit 15 inch rims on there?
And did you order it from currie complete?
2004 GMC Seirra ECSB 4X4 5.3 AUTO
Originally Posted by someotherguy
It's always easier to ask forgiveness, than ask permission!
Richard
10-30-2009, 01:20 PM
#44
I'm not sure about the 15 inch rims, but i don't think they would fit. i don't know where they got the axle from, but it came in parts, i saw the axle shafts i believe they are 35 spline and i don't think i could ever snap them.
11-01-2009, 01:13 AM
#45
DUH! Big Red Truck!
that you took a truck to a shop, told them build a big truck, and i'll pay the bill.
if you really believe that a semi floating dana 60 rear axle is comparable to a dana 60 front axle, i dont care what kind of axles its got in it, its weaker. if you break an axle shaft, you're losing a rear wheel. the dana 60 front wont do that, nor will any full floating axle. just because its good in a front axle, doesnt mean its good in a rear axle application... look at the 8.5" 10 bolt for example. with moderate sized tires and a driver who pays attention to what he's doing, it will live a long healthy life. put it in the rear, and you're breaking it on sub-30" tires...
just because it says Dana and 60 on it does not make it good.
and FWIW, the Dana 60 SF rear was available in alot of 1/2 ton trucks back in the day. you've just installed a 1/2 ton rear, and a beefed 1 ton front axle.
11-04-2009, 06:07 PM
#46
whats wrong with taking my truck to a shop?
So you point out everything you find wrong with his work but you haven't said what axle i should have used?
11-04-2009, 06:09 PM
#47
RAMZ TRK
Rockwells FTW
Richard
11-04-2009, 06:18 PM
#48
Loving The 3 Speed
[QUOTE=567234ta;4332587]
QUOTE]
Wow alllll that money can't even fix the bushings in the door.
And he said several times, 60 Full Floater, or a 14 bolt full floater.
Nice truck but I think your wasting your time with an SAS, and a truck with a Blower and that much engine is pretty far from reliable.
355ci-9.6:1 Compression-TBI mods-Vortec Heads-GMPP TBI Intake-Melling Cam-Roller Rockers-Flowtech Headers-MSD Ignition-Super 40's-TB Spacer-AFPR-6" Superlift-36"TSLs-Built Turbo 350
11-04-2009, 06:26 PM
#49
Rev it up and GO GO
[QUOTE=ryan_thompson87;4348306]
QUOTE]
Looks like bad cab bushings to me.
Truck looks good, well built, but I have to agree with GreaseDog on the axle issue.
91 RCSB fleetside Z71 6"Superlift/3"bl/35X12.50 SSR's/15X10 Eagles/4.10's
96 ECSB stepside/DD/265's/slight crank
99 ZR2 Blazer/32's stock
11-04-2009, 06:34 PM
#50
Supporting Member
dont listen to grease dog, it seems like every time someone does an sas or a lift he gets testy and grouchy... my PO is that he thinks he's better and smarter than EVERYONE on the forum and if your not up to par with him your no good and so is your truck... granite i dont have near as much knowledge about trucks as him.
dont argue with him, its pointless, just crap filling up your thread.
on a side note, truck looks great, wish i could do that kind of build. Cant wait to see the final pictures.
06 Trailblazer SS Cam 224/230 .610/.605 116LSA , PRC Gold Dual Valve Springs, TSP 7.4 Pushrods Ieatsrt8 V2 Intake, Magnaflow, Pcm4Less Trans Cooler, Circle D Converter, Built Transmission: Transgo HD2, Vette Servo, Z pack (upgraded clutches), Wider red band. Built and Tuned by RPM Motorsports
11-04-2009, 06:40 PM
#51
Forum Leader
QUOTE]
why is a sas a waste of time and what makes his engine unreliable? his engine could take a ton more boost and still be fine, tranny may need a build i'm not sure what he has there but i'm sure the engine is fine and reliable and sfa is more reliable than ifs.
No its not stock height!
Click the signature!
#52
Rev it up and GO GO
Oh he's a little testy that's true, but he knows his stuff, and doesn't want anyone to build an unsafe vehicle, which I don't think this truck is.
11-04-2009, 06:42 PM
#53
Supporting Member
agreed
11-04-2009, 06:49 PM
#54
Loving The 3 Speed
[QUOTE=nebraskaz71;4348364]
He's wasting his time, because he really doesn't need it, a Cognito or DC would have done him just fine for what he needs. If he is not doing anything he is worried about the u-bolts dragging through everything, the general beef for an SAS isn't really required. Granted it's a kickass engine and I'm sure it runs the balls off most things, but if it's reliabilty you want leave it stock. much less things to go wrong. I'm sure it took hours upon hours of tweaking to get that thing where it is. Never said anything about the diff, just that the truck is pretty far out there for what he said he wants.
11-04-2009, 07:01 PM
#55
Engine has been perfect for sure, it has a 4l80 with a shift kit and 4.5 quart extra pan.
11-04-2009, 07:06 PM
#56
Supporting Member
11-04-2009, 07:08 PM
#57
I'll stay out of the drivetrain debate.
I'm more interested in better pictures of the welds on the lower link frame mounts if possible. It may be the picutres, but from what's shown they look pretty bad for professional work.
1997 K1500 ECSB L31/80e/241/D60f/C14FF
2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
11-04-2009, 07:11 PM
#58
I was with you until granite....
1998 k1500/5.7/3.73/Mickey Thompson MTZ/Moto Metal 951/14b sf/Wheatley tune
1967 International 1500B/16,000 GVW/hydraulic bed/1 owner
11-04-2009, 07:12 PM
#59
Supporting Member
ahahha thats how my comp spelt it... i have become way to reliant on it...
#60
Supporting Member
and i love your truck stucknthemud... beautiful
| Thread Tools |
| Display Modes |
Linear Mode
