Old 02-26-2008, 09:51 PM   #801
chev_guy67
Member ID: 82594
what do u guys think is the best rear locker for a 14ff, i dont wnna spend a bunch like the front arb but id like an auto locker (for the snowy days up here in canada) or is that a bad idea?? right now i have a 14sf with the G80 and i love it for the winter but im only 20 and havent expericenced any other diffs/lockers.
"Its not what you buy, its what you build"
Old 02-26-2008, 09:57 PM   #802
GreaseDog
King Of The Hill
GreaseDog's Avatar
Status: Online
Member ID: 21917
just go with a Detroit. it'll take a little getting used to in the snow, but i know alot of guys are running them all the time. its also the cheapest option for a locker.
Old 02-28-2008, 06:37 PM   #803
chev_guy67
Member ID: 82594
ya thats what i was wondering about running a detroit on the streets alot and what not. i guess i always can used it for a bit and buy a selectable later
Old 03-04-2008, 05:45 PM   #804
91chevZ71
hold my beer & watch this
91chevZ71's Avatar
Member ID: 50434
ARB users-
ok, you have the air supply line into the diff, and subsequently into the bearing cap to the locker. duh. Who's running a conventional diff breather in addition to the locker supply line...which isn't a really a vent since it supplies pressure and isn't supposed to leak at all?
Still building up to the SAS...
Old 03-04-2008, 07:15 PM   #805
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
Everybody, you have to have a breather or the pressure will escape elsewhere, like axle shaft seals.
No one is ever gone if they are always remembered.
JasonPayneMemorial
Old 03-04-2008, 07:18 PM   #806
91chevZ71
91chevZ71's Avatar
Member ID: 50434
Don't all axles have breathers in stock trim? work with me, please...he he
my 14SF has a breather, transfer case does, trans does, front IFS does (pretty d*mn sure, anyway)
Old 03-04-2008, 08:37 PM   #807
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
Yes, all axles have a breather stock hence why I said everybody who has an ARB needs a breather. Everybody who doesn't have an ARB needs a breather too.
In short the ARB doesn't change the need for a breather.
JasonPayneMemorial
Old 03-05-2008, 05:06 AM   #808
fernanbfg1
Member ID: 17637
Anyone running an axle with 36.5" width spring perches? If so, what wheel backspacing and tire width are you using?
I am still in the early stages of this project, still collecting parts. The truck is a 94' F/S Blazer and my goal is to lift it approximately 10"-11" running the TSL/SX 38.5x14.50x16.5 on a 16.5x9.75 wheel with a backspacing of 4.75"-4".
Will this lift and tire/wheel setup work, or do I need to go more narrow with the tires?
Old 03-05-2008, 10:28 PM   #809
chev_guy67
Member ID: 82594
hey good question ill need to know that too i wanna run 38.5s as well but think i might have to go a bit smaller for the 36.5 perches. also does anyone know if i keep my ford 60 outers can i throw ford rims all round (14bSF on the rear) i know that the center holes are larger on the fords but what about the stud holes?
Old 03-06-2008, 07:02 PM   #810
97diesel4x4
Member ID: 73439
you need to use less backspacing to keep the tire out from the leaf springs i think you can get 3 5/8" or less
all the older 8 lugs axles are the same 8-6.5" but the newer fords are metric
1997 GMC K1500 6.5 diesel Ext.Cab SB, FSD-Cooler 3.5 straight Exhaust planning for a 10" coil over 4-link solid dana 60 axle swap 38x15.50 tire
Old 03-07-2008, 05:10 AM   #811
fernanbfg1
Member ID: 17637
I did some searching and found Stockton Wheel (http://www.stocktonwheel.com/4wd_offroad.htm) which sounds like they can build any dimension needed at decent prices.
As for backspacing, I was thinking about 2"-2.5" or will my tires stick out too far?
Old 03-07-2008, 04:10 PM   #812
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
I wouldn't go for that backspacing for wear on the wheel bearings and races and the big increase in scrub radius. Steering effort will be greatly increased as will the wear from steering on tires.
JasonPayneMemorial
Old 03-07-2008, 06:24 PM   #813
fernanbfg1
Member ID: 17637
Guess I will have to run a more narrow tire and live with it to keep my front end alive.
Old 03-08-2008, 06:06 PM   #814
babybluebeast
babybluebeast's Avatar
Member ID: 82511
I have the opportunity to get a Chevy D60 and right hand drop transfer case for a lot less than a Ford D60. Has any one in here ever done a conversion with a Chevy axle?
Old 03-08-2008, 06:18 PM   #815
GreaseDog
King Of The Hill
GreaseDog's Avatar
Status: Online
Member ID: 21917
im working on one right now, but im using a 2wd truck. bggrnchvy's truck has a Chevy 60 in the front.
Old 03-08-2008, 06:38 PM   #816
babybluebeast
Member ID: 82511
I have read that the chevy axle has better knuckles and is less prone to breakage. Is anyone running the NP205 transfercase with the 4L60E tranny? If so what adapter are they using?
Old 03-09-2008, 12:35 AM   #817
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
The better question is what method of adding VSS to the 205 are you planning? This being the 60e requires VSS to operate and every 27 spline 205 was a mech speedo.
And yes, the Chevy knuckle has a little more material around the upper kingpin so with highsteer breakage happens less often. However with regular crossover and hydro assist the difference is negligable.
JasonPayneMemorial
Old 03-09-2008, 01:05 AM   #818
GreaseDog
King Of The Hill
GreaseDog's Avatar
Status: Online
Member ID: 21917
www.jagsthatrun.com should be able to help with VSS issues, as they're pretty well versed in EFI swaps which often also require VSS retros.
Old 03-09-2008, 11:04 AM   #819
babybluebeast
Member ID: 82511
I have located a 208 transfer case out of a 1985 for less than $100 in excellent working condition. I was just curious what it would take to put an 205 in it if I was going to switch to a right side drive shaft.
What transfer case are you using bggrnchvy?
Old 03-09-2008, 11:27 AM   #820
GreaseDog
King Of The Hill
GreaseDog's Avatar
Status: Online
Member ID: 21917
i would skip thry 208, not only is it mechanical speedo, but its slip yoke too, with no way to eliminate the slip yoke.
IIRC Kyle is running a 241
