Old 04-03-2008, 08:26 PM   #841
KADILLACKID
Keep on truckin
KADILLACKID's Avatar
Member ID: 28536
also closed knuckle I believe,with full time hubs
Old 04-11-2008, 05:08 PM   #842
keveyj
Member ID: 54383
ok i found a 208 tcase pass drop will it work on in a 02 chevy 1500 sas swap
Old 04-11-2008, 05:40 PM   #843
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
How many ties have I posted in this thread about the need for VSS?
How many times have I mentioned the only cases with 40 pulse GM VSS factory that were p-drop are the 88-91 NP241 and the 91 NP205?
I'll take a stab in the dark and say an NP208 would piss off your motor and your tranny if it's an auto. You can tune it out of the motor, however tuning it out of the e-controlled auto is not happening short of converting to a full manual valvebody.
No one is ever gone if they are always remembered.
JasonPayneMemorial
Old 04-11-2008, 07:26 PM   #844
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
88 and 89 passenger side drop 241s are cable speedo Kyle... 90 and 91 are VSS. and they're a bitch to find.
1977 Chevy K20 - 350/350/203 10/14FF
1980 GMC K2500 - 350/465/205 10/14FF
1992 Chevy C1500 SWB - 5.7/4L60/14SF - totaled 5/9/08
1993 Chevy C2500 - 350/80E/241 10/14FF
1994 Chevy K1500 - 350/60E/241 IFS/G80 10 bolt
Old 04-12-2008, 12:53 AM   #845
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
True, but all you need to convert them is a 90-91 tail housing and a tone ring which are factory parts.
208 never had VSS.
JasonPayneMemorial
Old 04-12-2008, 09:38 PM   #846
rob
Member ID: 6375
anyone running LT headers, and leaf spring SAS on a 32.5" spacing? or is the later ford 36" the only possible way?
what length leaves are you guys running in the front of your trucks? 47"? or 52"?
'94 Z-71
heads/cam/intake/LT's/locker
'02 z-71
LM7/M30/GT4/G80- stock for now
'95 Formula
heads/cam/LT's/gear
'92 Civic
4-door 5-speed,35mpg
Tuned By:
Bluecat
KYHORSEPOWER.COM
Old 04-24-2008, 06:59 PM   #847
littleman1125
Member ID: 88154
new to site. I want to know can I use a 78 bronco dana 44 to do a sas on my 96 suburban useing leaf springs ?
Old 04-24-2008, 07:43 PM   #848
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
tried BBC longtubes on mine when i had the BBC sitting in it, no dice. had a Ford 60 under it then too.
no, the Bronco 44 wont work.
Old 05-01-2008, 07:11 AM   #849
kkkwhite4life
Member ID: 88612
anyone got a axle
Old 05-01-2008, 07:13 AM   #850
kkkwhite4life
Member ID: 88612
ehh yah gots a ford
Old 05-01-2008, 07:13 AM   #851
kkkwhite4life
Member ID: 88612
where can i get a solid axle
Old 05-01-2008, 07:14 AM   #852
kkkwhite4life
Member ID: 88612
i got alot of things but no solid axle. how i go about getting one of dem
Old 05-01-2008, 12:17 PM   #853
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
pirate4x4.com is your friend. try there, lots of straight axle for sale.
Old 05-07-2008, 03:29 PM   #854
454dog
Member ID: 83456
what about using the rear sensor on the 4l80e for vss may shift wierd in 4lo but you could just manually shift it going that slow
Old 05-08-2008, 11:19 AM   #855
79Shortbox
79Shortbox's Avatar
Member ID: 24980
Where can I find a drop pitman arm for 88-99 trucks? Will the newer ones work, like is the shaft got the same amount of splines and everything? And dude asking for axles, cruise the junkyards around where you live.
97 K1500 ECSB Z71 Cepek Stage II 315/75/16s, Bulletproof Steering, 210k, leaky exhaust, 3 different colors. DD/work in progress
78 K10 SB 12" Superjunk 39.5" TSLs SOLD
Old 05-20-2008, 04:41 PM   #856
Bad Ass Z71
formerly shortbox
Bad Ass Z71's Avatar
Member ID: 48980
http://www.trader.ca/Search/Details....ADS=6913387%7C
What do you guys think of the parts on this? The price is right... just want to make sure it is doable on a 2005 silverado. Having a really hard time finding older axles for less than 1500 each. I've been watching for complete trucks and this is as close as I've come in ages.
Old 05-20-2008, 06:03 PM   #857
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
no bueno. looks like leaf sprung TTB crap.
Old 05-20-2008, 06:35 PM   #858
Bad Ass Z71
formerly shortbox
Member ID: 48980
ttb = ?
Old 05-20-2008, 06:49 PM   #859
KADILLACKID
Keep on truckin
Member ID: 28536
Originally Posted by shortbox
ttb = ?
ttb=garbage
It was like fords somewhat independent suspension "experement" lets call it.....Some goofy guy runnin round town here on dana 50 TTB with 12" homebrewed from a 6" kit lift and 4" body and 44 boggers on 15x14s.....BBBEEAAAAUUUUUUTTTTTTIIIIIIIFFFFFFFFUUU UUUUULLLLLLLLLLLL rig...
Old 05-20-2008, 07:10 PM   #860
Bad Ass Z71
formerly shortbox
Member ID: 48980
well then. heheh
*off to read about ttb now*
