#861 |
King Of The Hill
Member ID: 21917
Twin Traction Beam, a driven version of Ford's Twin I Beam suspension. its crap.
#862 | |
Member ID: 6375
not as nice as a solid axle, but atleast you can get a TTB setup to flex, unlike anything with torsion bars....
'94 Z-71
heads/cam/intake/LT's/locker '02 z-71 5.3/3.73/g80- 285's, no cats, single 3" aero chamber '95 Formula heads/cam/LT's/gear '92 Civic 4-door 5-speed,35mpg Tuned By: Bluecat KYHORSEPOWER.COM |
#863 |
King Of The Hill
Member ID: 21917
fair enough, but its alot more work to get one to work than a straight axle. the Twin I Beam setup is popular with the prerunner crowd because of its better ability to flex than a SLA setup.
#864 | |
Member ID: 6375
true, but when you get in to the SERIOUS pre-runner stuff, everyone goes back to the SLA, kinda weird how it comes full-circle, huh? who woulda thought the worst design in 4x4 suspension is by-far, THE best in 2wd suspension? I guess the nicest thing about buying a ford leaf-sprung TTB, is you can bolt in a dana60 from an f-350 with ease. if I ever bought an OBS f-250, that's what i'd do for sure!
'94 Z-71
#865 |
Member ID: 79430
Maybe you guys can conirm my logic here. Im doing an sas on my 98 and im using the ORD kit and a 78 ford dana 44. The cite says to get 4 inch springs if i want a total of 7 inch lift. If i get a 4 inch lift kit for an 87 and older truck will that be the same 4 inch springs they sell? This would be easier for me because i found an older truck with a 4 inch suspension lift with the rear axle i want for dirt cheap.
#866 |
King Of The Hill
Member ID: 21917
IIRC they use 88-91 front springs, which are the same springs, just different bushings and bigger bolts. i'm running ORU brackets and 4" TC EZ Rides.
#867 | |
I.L.B.T.'s
Member ID: 79988
I may be wrong here, but doesn't Ford use that so called junk suspension on their 1/2 tons ? I would trade a IFS suspension for that pile of crap TTB Ford used. ![]() 91 RCSB Z71 6" Superlift/ 3" b/l 35X12.50 SSR's/15X10 Eagles......96 ECSB 1/2 ton DD 265's slight crank www.skyhighrides.com |
#868 |
Member ID: 79430
but i dont have to buy their springs for $225 because any older chev lift kit will be +3 inches? in other words "6 inch old chev lift=9 Newer Chev lift with sas"? 88-91 springs are what the kit is specifically designed for?
#869 |
King Of The Hill
Member ID: 21917
eh... kinda. you'll have to buy bushings for an 88-91 truck and your specific springs (some brands dont use stock sized spring eyes), other than that the springs are the same.
#870 |
Member ID: 79430
i got my 14 bolt ff today and did some very quick measureing and it looked like i might need to move my spring perches out a little bit. Is my quick measuring the cause or is this the case.
#871 |
King Of The Hill
Member ID: 21917
what did your 14 bolt come out of? if its anything other than a comparable year 2500 or 3500 truck, you're probably going to have to move them.
#872 |
formerly shortbox
Member ID: 48980
are the axles out of this truck any good? I can deal with the coils. http://www.usedottawa.com/classified...ory=4x4-trucks
#873 |
formerly shortbox
Member ID: 48980
didn't work. Try this link.
http://image1.usedottawa.com/YOW5751527.1.jpg its a 71 ford bronco. How many lugs would it have? I can pick it up for like 300... rolling chassis. Last edited by Bad Ass Z71 : 05-29-2008 at 12:29 PM. |
#874 |
so is a 14 bolt from a 1981 2500 chev 4X4 the same or pretty close to say a newer ff 14bolt?????
#875 |
Status:
Online
Member ID: 13799
You have to modify spring perch mounting for rear axle if you swap between body styles, so yes 88-98 using a 73-87 axle will require perch modification.
I wouldn't touch pre 77.5 Ford axles. |
#876 | |
King Of The Hill
Member ID: 21917
no. there is absolutely no advantage to putting a 9" Ford under a fullsize truck that you plan to install larger tires on. as has been stated numerous times, Ford coil axles commonly CANNOT have the radius arm wedgfes removed, thus are useless. not only that, but the axles are WAY too narrow. have you ever seen the size of a 66-77 Bronco? they'd be PERFECT under an S10 though.
#877 |
formerly shortbox
Member ID: 48980
I know almost nothing about old Fords. I am learning though. Just not learning as quickly as I'd like. I'm having a hell of a time finding some axles. I now know, I won't go with anything less than HP 60 though.
SSSHHHHHHH! I'm on a secret mission!
#878 |
King Of The Hill
Member ID: 21917
a 78 or 79 HP 44 out of an F250 would do just fine. its plenty wide.
#879 |
Member ID: 28176
I've got a chance at an HP Dana 44 from a 78-79 F-150. It's not the 1/2" thick axle tubes. I'm just getting into wheeling... should I wait the heavier duty axle for double the price? or bite on this one? Any advice is much appreciated.
#880 |
Intenionally blank
Member ID: 39135
Dont' use that axle inless your gonna run the suspension too. Where the radius arms on the tube, it's actually part of the tube. Start grinding them off, and your grind right through the tube. Best bet is look for a 3/4 ton, or get a 1/2 from a 77 and older truck....
For sale: 1978 High pinion Dana 60 $1000
GM Dana 60/14ff 4.56s/Detroit $600 http://community.webshots.com/user/b454rat |
| Advertisements |
| Thread Tools | |
| Display Modes | |
