11-05-2009, 07:33 AM
#1041
I have a question about doing a SAS on my 98 burb. I would like to still retain my stock engine,trans and transfer case. Will the transfer case still work (pushbutton) with swapping out the IFS for SA?
11-05-2009, 08:45 AM
#1042
Redneck Hillbilly Fix 'er
It should, as far as I know. The only difference should be the front driveshaft length.
94 C1500 RCLB, 305/4L60, custom 2-tone interior
Soon to be: 8 lug/14BFF, C3500 suspension, auto to 5spd
11-05-2009, 08:59 AM
#1043
That would be awesome! I am thinking of doing the axles out of a 3/4 ton or 1 ton Dodge and a Radius arm deal with 37 or 38 inch tires. I still want to drive to the trails and haul a couple of buddy's and a day or two worth of gear and refreshments comfortably...
11-07-2009, 03:53 PM
#1044
hey all im new to this site i got a 1999 Chevrolet Suburban 2500 4x4 with the 454 ci im wanting to do a sold axle swap i know i need a dana60, what else do i need to do since i have a suburban compaired to the trucks if anyone can help me out pm me or email thanks i saw the list on page one but am confused
11-07-2009, 07:30 PM
#1045
You want a Ford D60, preferably HP. That or you swap your T-case for a P-drop 241.
11-08-2009, 11:16 AM
#1046
so i can keep my transfer case all i need is the front dana 60 i dont need to swtich out my rear end?
11-08-2009, 12:37 PM
#1047
Supporting Member
Depends on your transfer case. You also can get away with a HP Dana 44 instead of the 60 if you aren't running tires bigger than 37s hard.
UNDER CONSTRUCTION click here 99 GMC RCLB ~19" Dana 60 & 14FF Detroit 5.38s GM HotCam Tom Woods Driveshafts PSC Steering Mazzi 20x12s Bilstein 7100s 36 MTZs(44" Pitbulls soon)
04 GMC Z71 ECSB
11-08-2009, 05:07 PM
#1048
Might want to swap rear ends, depends on lug pattern of the front axle. Unless you want a weak rear axle and 2 spare tires.
11-08-2009, 10:04 PM
#1049
Hey Im doin a SAS on my 98. I have front leaf hangers. Does anyone on here have drawings (CADD) or dimensions of front rear hangers so i can fabricate a pair for myself?
11-08-2009, 10:08 PM
#1050
Check out some of the build threads, it also depends on the spring perch width, that ultimately determines your shackle hanger design.
11-08-2009, 10:11 PM
#1051
bigkuntry08
anyone got pics of an 2006 1500 z71 crewcab straight axled with tires around 40's just wanting to see wat my project might look like in a couple months anxious!
11-09-2009, 06:35 PM
#1052
Oh yea that would help huh? I bought a 78 F350 1 ton dana 60 for 650 bucks! So its 31.5 inches between perches
11-09-2009, 09:17 PM
#1053
Need to be bigger!!!!!!!
Anyone know the length of the front leaf springs for a SFA? I was looking at the +6 kit from ORU but the price of 1k for a set of front springs is a killer.
Damian
1998 Chevy Ext. Cab Short Bed 5.7 4x4/AFO intake, Borla exhaust and JBA headers, Gran. MAF, and HPP 3/9.5" Full Throttle Suspension with 9" rear springs and 2" blocks, 16x10 EA143s, 38" MTZs.
11-09-2009, 11:08 PM
#1054
I've heard the springs from a 73-87 truck is common, all depends on your shackles and such. Any combo is possible, depends on your lift and all that stuff. Talking to a local spring shop would make things a lot easier.
11-10-2009, 02:30 PM
#1055
ORU and many other companies use a 47" inch GM front leaf from the 73-91 (88-91 getting different rear bushings). The +6 kit uses an offset 52" inch spring that a company like Alcan can build you in the neighborhood of $200/pack in the 3-6" range.
1997 K1500 ECSB L31/80e/241/D60f/C14FF
2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
11-12-2009, 11:45 AM
#1056
Hey guys im new here but i was looking for some oversight on an idea ive got. I just recently bought a 85 k5 blazer with a 6 inch suspension lift and i have a 1990 chevy k1500 short bed regular cab z71. I was wondering since the lift is like new on the blazer how hard it would be to take the solid axel out and put it under my z71 and ditch the ifs. Now i know most people do it for hardcore wheeling in which i probly will not be doing. But i cant see letting the blazer go with the lift expecialy since i need a lift to clear my 35's ive got waiting to go on it
I have read up alot on it and just wondering what i can take off it. And would i need to buy anything for it? the z71 is an auto 350. The blazer is an 350 3 spd with granny low. Would i have all the parts off the blazer to do the swap??? Thanks guys i apreciate any help you can give
11-12-2009, 11:26 PM
#1057
T-cases both on the same side?
11-13-2009, 05:43 PM
#1058
sas chevy builder
you will run into a bunch of issues such as the t-case in your truck now is on the wrong side to use a chevy axle and the t-case from the parts truck is the wrong spline count to mate to the current trans, the other issue would be steering, you can use brackets from the donor truck to mount the axle but once its in there you will need to change the steering knuckles and run crossover steering with a track bar.
there are quite a few of us over on pavementsucks.com that have built a few sas trucks and can answer every question you have if you don't see what you need here, i currently am working on a absolute table of what axle/lift needed to fit what tire with what backspacing and spring rate differences and lengths causing certain things, we have a few builds to get different measurements from from using stock gm hangers to using oru kits or going with a linked front with coils.
11-13-2009, 05:47 PM
#1059
sas chevy builder
stock 73-87 chevy 2wd rear shackle hangers flipped upside down are the right offset to use for that,there are 2 different length frame hanger brackets if i remember right one is a 11" hanger and the other is 8", and the 8" is the one you want.
like this(test fit picture)
11-13-2009, 10:28 PM
#1060
Too bad ur doing that upside down. Shackles on top are 100 percent better
| Thread Tools |
| Display Modes |
Linear Mode
