Old 11-10-2003, 11:11 AM   #101
snailrail
snailrail's Avatar
Member ID: 9885
I have a dana44 front axle. I bought a passenger flat top knuckle and a steering arm from foothill offroad.
foothilloffroad
I also bought a drop pitman arm for a late model Dodge 3/4 ton 4x4. The arm is really easy to come by, my friend just happened to have one. I took the steering arm and the pitman arm to the local autoparts store, and went through boxs till I found two tie rods, a left and a right handed thread, that would fit properly. I actually made my draglink. I used 1.5" solid bar stock. Then tapped a hole in each end for the tie rod threads. I may have had a total of $400 in it. The draglink is probably the hardest part, just because you can't easily mail order it. Any machine shop could do it for you. I bribed a guy with some beer!
I drive a Chevy truck.. I know it isn't as nice as your Benz or Lexus, but if I ever hear you brag, I'll crush your p%$sy wagon like a roach!
Old 11-17-2003, 06:34 PM   #102
6Point2
Chainsaw Collector.
6Point2's Avatar
Member ID: 855
I'm currently in the process of converting a 2WD version of Snailrail's rig into 4WD using the SAS kit from ORU, 4" lift Tuff Country springs, and the 1" lift Zero-rate Add-A-Leaves from Off Road Design. The rear will have the ORD shackle flip combined with a set of custom springs made by Alcan Spring. The front axle is a HP60 out of a '79 F350, the transfercase is a Doubler(GM NP203 to Ford NP205) from ORD, the rear axle is a FF 14 Bolt out of a '97 Chevy K3500. I'll get some pics up of it when its done.
Old 11-19-2003, 08:48 PM   #103
71 CREWCAB
Member ID: 1701
How wide is a chevy dana 60 or 44 front? Im trying to get parts rounded up and found a nice dana 80 rear at the salvage yard out of a dodge dually but it measures at about 74 inches hub to hub. Im thinking that it will be too wide to match the front.
Old 11-19-2003, 08:51 PM   #104
95gmcd6014
salas poser
Member ID: 517
chevy 60 is right around 69" WM-WM. Pretty sure the 44 is close, maybe 1-2" narrower depending on the years an if they are 6 or 8 lug.
95 gmc with no IFS...82 K30 stock for now
http://community.webshots.com/user/95gmcd6014
Old 11-24-2003, 08:56 PM   #105
Castle Killer
Member ID: 3659
heavychevy, what year did your Dodge D60 come out of?
Old 11-27-2003, 11:11 PM   #106
Triple X Rated
Member ID: 10240
Take pics of the parts. I want to see the build up
The ice in ma mouf keep da Crystal cold.
Old 11-28-2003, 01:14 PM   #107
Smith
Member ID: 7843
If i was to take a 79 chevy dana 60 front and a 14 b ff rear along with the T-case how much harder would this be to do when compared to takeing a ford front dana 60? What im worried about is there any crossmembers that would need to be cut for the front driveshaft or what? also how would i make the 14bff rear froma 79 work on my 90?
90 Z-71 3" Exhaust running from the cat with a turndown. No Muffler Quad Beam Setup 31" Dueler AT's Auburn Locker Tinted windows. Future plans: SFA Swap with 14BFF Rear and Dana 44. Will be done in next 2-3 Months Bowtie/Flame Headliner New Grill
Old 12-03-2003, 06:22 PM   #108
Hot Rod
Member ID: 8663
I have heard some people say that you can reuse a bracket off of a _____? for the spring mounts? Does anyone know what bracket and how well they work? Also, do I have to change my pitman arm or can I run the stock one(91GMC 1 ton 4x4)? Thanks,
Tyler
By the way. I have a 6 lug Dana 44 with drivers pumkin I will trade for an 8 lug drivers pumkin axle if anyone is interested.
Old 12-10-2003, 02:32 PM   #109
Triple X Rated
Member ID: 10240
It would be less shipping $$ if you just traded hubs.
Old 12-10-2003, 09:48 PM   #110
1998chevy1500
The Big Sky State
1998chevy1500's Avatar
Member ID: 5163
stupid question. I have a 1998 chevy with the push button 4wd. Just for curositys sake would I have to swap in a different t-case or would this work. It is not autotrac (I think) cause I can hand turn the front driveshaft when in 2wd.
thankx
conrad
“Learn as if you were going to live forever; Live as if you were going to die tomorrow.”
“In dating and mating, what is finally settled for is always a function of what is available.”
Old 12-11-2003, 09:15 PM   #111
Triple X Rated
Member ID: 10240
thankx
conrad
You're fine.
Old 12-11-2003, 11:53 PM   #112
1998chevy1500
The Big Sky State
Member ID: 5163
Another question for the sake of curisoty. What it my transfer case (np205,241..?). I have a 1998 chevy with the push button 4wd.
thankx
conrad
Old 01-04-2004, 10:27 AM   #113
97k1500
Member ID: 11121
Re: Re: Solid Axle Conversion Tech
Originally posted by 96chevysfa
dude, i thought i was the only one that thinks you need one, i asked a few guys and they did not believe i needed one untill i showed them ho much lateral movement my axle had when i steered. ill have one on my truck soon though, something easily detachable.
hello all! i am a new member to this site. i would really like to e-mail some of you guys on straight axle tech, but i cant figure out how to use this site!!!! i am fuming right now because i cant figure it out!! when i try it says i need 5 posts to e-mail? how do i obtain them? i tried to add my picture to my profile but i cant!! what the hell is an avatar anyway? i tried to follow the sites directions but i keep going in circles & have to go get another beer to cool off! i am now out of beer. any help or info would greatly be appreciated!! thanks everyone. 97k1500
Old 01-07-2004, 04:36 AM   #114
EBMoffroad
Member ID: 9034
You can pm
95 chevy ext.cab sfa shackleflip 38.5 swampers vortech tbi gibson headers
68 swb step side soon to be bagged
Old 01-07-2004, 05:24 AM   #115
JB
2008 NNBS
JB's Avatar
Member ID: 44
thankx
conrad
241
Crawl under your truck and look for a tag on the back, it will tell you which model.
2008 Chevy Silverado 1500 RCSB LT1,5/7 drop
my cardomain site
Old 01-11-2004, 11:33 AM   #116
slacker
slacker's Avatar
Member ID: 8054
i have a 4wd '78 F250 i can get my hands on, would this be the right axles to use for my sub?
Old 01-11-2004, 08:44 PM   #117
DarkEternal
Drive it like ya stole it
DarkEternal's Avatar
Member ID: 3365
it depends if its the higher gvw one. Technically it will work weather itsa d44 or 60, but if you ever plan on wheeling it you want the 60. Just check if its got a 44 or a 60 up front. I would use a 14 bolt for the rear.
Heres my progess (writeup)
http://homepage.mac.com/darketernal/SAS.html
2001 Silverado Z-71 5.3 - 1 ton SFA
Old 01-12-2004, 08:10 PM   #118
EBMoffroad
Member ID: 9034
Even if it is the 44 you can still build them pretty strong with 8 lug outer and a 14 bolt in the rear. You have to wheel pretty hard to brake a built a 44. If it is a 60 then your in luck.
Old 01-22-2004, 05:33 PM   #119
Smith
Member ID: 7843
Hey what do i need to do as far as brake lines are concerned? DO i order extend brakelines for a chevy or for a ford since the axle is a ford?
Old 01-22-2004, 05:44 PM   #120
DarkEternal
Member ID: 3365
You will probably need custom made ones.
