Old 06-10-2003, 12:10 AM   #21
Is the NBS Tahoe torsion bars the same lengh as the truck torsion bars?
03 GMC CC LB Duramax/Allison loaded
02 GMC Denali - Dropped, Giovanna 22's
86 GMC Jimmy - 60 up front and 70 in the rear, H1's, too much other crap
02hoe is offline
Old 06-10-2003, 12:44 AM   #22
how uuu deewwwin
Luke2kZ71's Avatar
no..... and sorry but im not really even sure if u guys have the same keys or not if so, you could use the ford keys, a member here did install heavy bars on his tahoe, and had to do a little bit of welding to make it work.
Luke2kZ71 is offline
Old 06-10-2003, 03:22 AM   #23
Drive it like ya stole it
DarkEternal's Avatar
Heres anotehr question, whats the heaviest bar you can run on a half ton truck, I remember someone saying that at least the heaviest ones wont load up or something... Anyone know?
2001 Silverado Z-71 5.3 - 1 ton SFA
DarkEternal is offline
Old 06-10-2003, 12:22 PM   #24
2K2 Z71
Great tech article luke! Now when anyone asks about tb cranking, we can just refer them to your sticky!
2002 Chevy Silverado Z71, 6" Superlift suspension lift, 3" PA body lift, 36x14.50 Super Swamper TSL Radials on 16x10 Eagle 589's, 4.56 Genuine gears, 1 ton torsion bars, Rhino liner, K&N FIPK Gen II, Superchip...
chvythndr is offline
Old 06-10-2003, 12:55 PM   #25
how uuu deewwwin
Luke2kZ71's Avatar
i reccomend a 3/4 ton bar, u know, cause you are only gonna crank so much anyways .....
Old 06-10-2003, 01:05 PM   #26
Ok, what ones fall into that catagory then?
Old 06-10-2003, 02:17 PM   #27
how uuu deewwwin
Luke2kZ71's Avatar
get the WZ or GK bars
Old 06-11-2003, 10:46 AM   #28
Bigger isn't better?
1BADHD's Avatar
I have the GL bars. When I installed my lift I was going to put the "green" keys in. I had a 7 ton puller. With those bars and the green keys, I couldnt install them. There was so much tension the T-bar bracket started to give way. I put a long center punch in the place where the bolt bracket would go. If it wasnt for that the punch, the whole thing would have came down on me. Needless to say, I installed the stockers and sold the green ones. That was one of the few things that ever scared me.
2001 Silverado HD, 6" Rancho Lift, 16x10 Eagle 102's and 36x14.50x16 STS's, Rancho Traction Bars.
1BADHD is offline
Old 06-11-2003, 04:07 PM   #29
"Jetski Freak"
redneck's Avatar
great job Luke!!!!!!!
redneck is offline
Old 06-12-2003, 07:01 PM   #30
I've got the WL bars on my stock height silverado 00' I have to crank my bars ALL THE WAY to level my truck. If I go to a 3/4 ton bar, do I need different keys too, or will the ones I have work?
07 CCSB LTZ
Hunter660 is offline
Old 06-12-2003, 07:15 PM   #31
Banned
Incredible Hulk's Avatar
Ford Keys are The " Hack" way to lift your truck.
If you are gonna lift your truck this way, get ready to start breaking parts.
Incredible Hulk is offline
Old 06-13-2003, 02:17 PM   #32
how uuu deewwwin
Luke2kZ71's Avatar
many people have done it successfully.
Old 06-18-2003, 02:46 AM   #33
One more thing to add. You should always put a fat clump of grease on top of the keys before you install them.
www.performancelifts.com
"Function before looks"
Matt@PLC is offline
Old 06-25-2003, 08:54 PM   #34
The goggles do nothing!
Suareezay's Avatar
Is there a difference between Rancho and heavier-rated GM bars? Should I go with Rancho or GM bars?
Also, does Ford make a key for OBS Tahoes? If so whats the part number?
[IMG][/IMG]
Suareezay is offline
Old 06-25-2003, 09:46 PM   #35
how uuu deewwwin
Luke2kZ71's Avatar
the heavier rancho bars are very simular to the GM bars, and ford doesnt make a key for the new trucks, they just happen to do this.... uhrmm i know aim makes one for the obs trucks though.
Old 06-26-2003, 01:01 AM   #36
wishes he had a duramax
HvyChevyZ71's Avatar
dont even think about using these.
1996 Chevrolet Z71 cepek lifted. w/ mods...SOLD!!!
2001 Chevrolet 2500 HD, 4x4, 6.0, Rancho RSX9000, 315x75 BFG AT's, Wheatley 93 tune, Pacesetter LT's, Outlaw Intake w/ Volant ram air, Magnaflow True X, Taylor 8mm wires.
http://www.imagestation.com/album/pi...?id=2102610814
HvyChevyZ71 is offline
Old 06-26-2003, 01:52 AM   #37
Suareezay's Avatar
I know ford doesnt make them for chevys, they just happen to work that way. What I mean was is there a torsion bar key that will fit OBS tahoes....besides OEM ones.
[IMG][/IMG]
Old 06-26-2003, 08:44 PM   #38
GANGSTAH
where can i get 3/4 ton bars for an obs truck 1991 without getting raped by the local dealer.
and can you tell me a part number so wont look like a tool, and so the service guys wont argue about them fitting?
wade is offline
Old 06-28-2003, 03:03 PM   #39
your daughter's a freeeak
Re: Ford Keys & Torsion Bar Cranking/Replacing TECH**
[QUOTE]Originally posted by Luke2kZ71
Here is the Ford key part number:
XL3Z5B328CA
A good place to get them is Ford Parts Online
**These keys work best on 1/2 tons
For the 3/4 ton trucks and above use the "green key" or the 1/2 Chevy key. 15592573 you can get them from GM Parts Direct
so a ford key will not work on a 2500 HD.. it only takes the green key?
Siyé
SOLD
'00 Z71 with goodies
My LAST truck
00' powerstrokeMy CURRENT truck
KLEEN KUT is offline
Old 06-28-2003, 03:48 PM   #40
how uuu deewwwin
Luke2kZ71's Avatar
Re: Re: Ford Keys & Torsion Bar Cranking/Replacing TECH**
[QUOTE]Originally posted by KLEEN KUT
XL3Z5B328CA
Well you can use the ford keys, but the green keys acheive more what you would be looking for.
Siyé
