Old 09-27-2007, 04:35 PM   #941
bradthomashines
Member ID: 72665
[IMG][/IMG]
[IMG][/IMG]
just wondering i have my stock keys cranked to the max and was thinking about getting the Ford keys for a little more lift are my angles too extreme to lift anymore ? or am i too close to the bump stop?
04 Z71 fabtech 6", torsion bars cranked, 20" moto metal, 35" Interco Trxus A/T.
Old 09-27-2007, 08:03 PM   #942
04BlackGMC
4x4'ing!
Member ID: 23406
i would leave as is really man. you have just enough gap between the stop and arms.
04 Torrid Red on red M6
SLP LMII,catless mids,Iat relocation,160* Thermostat,P&P TB,Noltec diff bushing,descreened maf,coolent bypass,JHP tube with k&n and ported air box,tune,LSS,c5 pads,nitto dr's,splitter
13.400 @ 104.01 1.999 60 FT
Old 10-09-2007, 02:46 PM   #943
00chev
Member ID: 75891
Hey, i just got the Ford keys for my 00 Z71. I see that some companies that sell the t-bar key kits include shock extensions. Wouldnt shocks for a 2-3" lift work as well or better?
Old 10-09-2007, 08:17 PM   #944
hvyhaul
Member ID: 75919
great info, I have a 2000 1 ton crew classic 4x4 how much can ford keys get me up with new shocks as well
Old 10-10-2007, 10:34 AM   #945
stoltz23
Z71 IN PROGRESS
stoltz23's Avatar
Member ID: 61683
you want heavier keys than the ford ones if you have a 1 ton. You want green or purple ones i think depending on what came stock in your truck. they are available at the chevy dealership. Wait for someone to chime in or read some of the 40+ pages of this post and you will find what keys you need.
Sold 3/08:
2007 Silverado Z71 ECSB FF5.3
GM Performance Cat Back, Gibson headers, Pocket Flares,GM Bed Rug,Extang Cover,
Ford Keys, 3" Blocks, Modified 1" PA body lift, ProComp Shocks, Metal Moto 951's, 35's
Old 10-10-2007, 06:31 PM   #946
Jordan_W
Jordan_W's Avatar
Member ID: 70984
I have a 2000 4x4 1500 Burban. I have decided to go ahead and crank my stock keys a tad. I have about an inch of thread on each stock key.
I understand that I will probably have to crank and examine as I go but could someone make a guess at how many turns I should go to achieve an inch of lift?
Thank you.
Old 10-10-2007, 08:13 PM   #947
stoltz23
Z71 IN PROGRESS
stoltz23's Avatar
Member ID: 61683
my guess would be 6-10 turns. i think mine were a tad over 1/8" per turn.
Sold 3/08:
Old 10-11-2007, 10:59 AM   #948
00chev
Member ID: 75891
Anybody know the pros and cons of shock extensions vs. longer shocks?
Old 10-27-2007, 12:08 PM   #949
DetroitDan
Member ID: 24566
Okay, I've read about 30 pages and I'm getting a headache.
Is the 15992573 part number the key I want for a 97 K3500 Diesel? When I check GM partsdirect there is no picture, and only shows a description of "arm". What does that mean? Can I go to the stealership and order that part number, and will it be the same price? I'm in no hurry so I don't mind ordering online, but I'm afraid of ordering an "arm".
How does changing the key affect weight carrying? I have the heavy diesel engine up front, plus I carry a 950 lb Blizzard Powerplow in the winter. I have currently cranked the bars five times for the weight, it leveled it nicely and seems to carry the weight well. But I want a little lift so I can go up to 255/85/16 tires. Just don't want to add keys and crank a couple inches, then snap something first time I lift the plow. Any reason to think it wouldn't be a good idea? How about Timbrens? I want to add them for the plow, will they work with keys?
I am putting 5000lb airbags in the rear, was thinking I'd wait on rear blocks because the bags may allow me to lift the rear up a bit.
So let me get this straight: Green keys cranked 5 times should give me additional height over what my stock keys cranked 5 times did, right? I got 1.5 inches out of the 5 turns on the stock bars.
Old 10-27-2007, 07:25 PM   #950
04GreenZ
04GreenZ's Avatar
Member ID: 70522
would ya'll say Rancho RSX17000 are a good shock for a key and spacer job? on a 2004 Z71 Tahoe
2004 Z71 Tahoe: Defender Series Roof Rack: Hella Black Magics: Hella 500's: 500 Watt Polk Momo amp: 2 Memphis Audio 12" Subs: Ipod2Car: Reverse Light Mod
Old 10-28-2007, 11:22 AM   #951
Maverick2003
Maverick2003's Avatar
Member ID: 74995
I recently purchased a 2003 silverado 1500. I have been checking it over and like most chevy's the front is lower than the back. SO i was going to crank up my torsion bars and they are cranked to the max but the front still sits 1.5" lower than the back. The truck also leans really bad in corners comnpared to my other 1500. Can this be caused by the torsion bars wearing out? If so what bars/keys would you recomend for my truck to have it sit level with the back and help prevent the excessive suspesion squat in the corners. Any advice would be greatly appreciated.
Old 10-30-2007, 03:17 PM   #952
kevin_saun
Member ID: 71701
I have a 94 1500 z71, got it from a friend who has owned it since it was new, it has 180000 miles on it and the bars have never been cranked Im thinking about cranking the bars some when i put my new rear springs in this weekend, when i looked at my keys one has only about 6 0r 7 threads left, and the pass side one seems to have twice as much but the truck seems to sit level side to side what im looking for is some stock no crank measurments so i can set it to stock height then get my 1.5 or 2 inches Ill have to use ford keys because im thinking the 13yr old torsion bars are pretty sagged. was also thinking of adding a 1 or 2 in block in the rear to gain a little as well but dont want to over crank , my truck is a mall crawler/daily driver and wont be in 4wheel except the odd time in the winter but still worried about cv angles and alignment. thxs in advance for any replies
Old 11-08-2007, 09:11 PM   #953
bmx_hb_boi
bmx_hb_boi's Avatar
Member ID: 77620
well with the stock torsion keys how much lift can u get out of them if u tightin them????
Old 11-10-2007, 11:29 AM   #954
z71offrd
Z71 Custom
Member ID: 72156
hey i jst wanted 2 give lil word of advise when u do a torsion key leveling kit..dont forget your pinion angle or else ur driveline will really suffer. the angle should b measured and b no more than 3 degree's or else u can if ur lucky jst ruin the ujoints.. but worse can b you'll ruin your pinion bearings and have a blast doing that. jst little word of advise cuz when i did mine i had a really weird rattle like sound when i deccelerate and it was my entire drivline
Old 11-12-2007, 04:57 AM   #955
chvythndr
2K2 Z71
Member ID: 3064
With stock bars & keys, the average is about 1/4" per turn.
2002 Chevy Silverado Z71, 6" Superlift suspension lift, 3" PA body lift, 36x14.50 Super Swamper TSL Radials on 16x10 Eagle 589's, 4.56 Genuine gears, 1 ton torsion bars, Rhino liner, K&N FIPK Gen II, Superchip...
Old 11-12-2007, 08:44 AM   #956
kevin_saun
Member ID: 71701
my top of the wheel well measurments are 35 1/4 with 265/75/16s on factory wheels and my cv's look pretty flat, any idea what the stock non sagged top of the wheel well measurements should be or maybe a measurment with a 2in crank so I have some comparisons?
Old 11-13-2007, 07:53 PM   #957
Ridge Runner
Member ID: 73878
I am getting ready for new tires and want to crank up my keys a bit. Where do you take the measurements from to get it leveled out.Thanks
Old 11-18-2007, 04:57 AM   #958
chvythndr
2K2 Z71
Member ID: 3064
ground to top of fender/wheel well
Old 11-21-2007, 06:22 PM   #959
Ridge Runner
Member ID: 73878
Thanks...
Old 11-24-2007, 09:25 PM   #960
Blue 04 Z71
Hates wating
Blue 04 Z71's Avatar
Member ID: 75312
Question for you guys. When i bought my truck i cranked the TB's and i went to have it aligned and they said that they could not do it. so i ended up having to go back to the dealer to have them reset my ride height. I really want to crank the bars or put in the ford keys but im hesitant to do it bc nobody can do it. Is it true that some to some trucks it just cant be done or are they full of SH**
thanks
jusitn
04 Silverado 1500 Z71 5.3, 3 BL,Truxedo,Westin Bull Bar,KC Slim lights, MTZ's Eagle's.
1989 Scottsdale 2500 Rockin a new Drivetrain
