09-20-2003, 10:43 AM
#81
Thanks for the reply. Hope to find time this weekend to pput them in.
Question:
My friend who is helping has a 2001 1500 Z71 and he wants to level/raise his front. Does the Green Key do this for him?
Maybe we will be doing two next week!
Butch - Now it is LTCBUTCH
2000 "OBS" K2500 Crew Cab
Shortbed, 8 Lug, 5.7L
2" BL
BFG AT/KO 305s
16x8 KMCs
K&N Filter
Flowmaster Dual In / Dual Out
09-24-2003, 11:05 AM
#82
how uuu deewwwin
Question:
no, the ford key lifts the 1500 Z71 thats what the pics are of.
09-26-2003, 09:31 PM
#83
i have a 1992 1500 it sagges a good 2 inchs in the front i want to level it off what do you recomend im kinda confused on what it would take and all thanks
killed
09-27-2003, 12:01 AM
#84
VISIONS
Thanks Luke2kZ71 for this *tech* Even tho I'm going down instead of up. I bought some Belltech keys to lower the front of my truck. I was going to start calling around to see who could install them for me since I had no clue how to do this, now I think i give it a try this week-end. We have some big gear pullers at work. Thanks again man
2002 Silverado Bagged with KP & ART on Intro 22's
2000 Silverado z71 3" Body Lift on MB 18's Black Bear Tuned
09-29-2003, 01:15 PM
#85
how uuu deewwwin
your welcome bro! i didnt think about using this thread for going down
09-30-2003, 07:48 PM
#86
Truckless
PRELOADING
Is there any reason to PRELOAD the bars when you change the keys? Read the whole post and didn't see any mention of it, so I ASSUME I don't need to. However I want to make sure as I'm doing the key replacement tomorrow.
Also, I have the YH bars should I upgrade? I plan on adding a ranch hand replacement in the near future. Do you think my stock bars w/Ford keys can hold it?
thanks
I miss my truck.....
2002 5.3 Z71 LT
09-30-2003, 08:37 PM
#87
Arctic07Tahoe
Torsion Bar
What is a Torsion bar?
2006 GMC Canyon
2007 Chevy Tahoe
10-02-2003, 02:31 PM
#88
how uuu deewwwin
Re: PRELOADING
thanks
i say get new bars...
10-02-2003, 02:32 PM
#89
how uuu deewwwin
Re: Torsion Bar
A torsion bar is a spring, but instead of bouncing up and down, it twist instead.
10-06-2003, 10:25 PM
#90
Luke, need some questions answered please!!..
OK, I own a 03 GMC Sierra Z71. Today, I went and ordered the Ford Keys(00 Ford F-150 keys). Then I go see how much it would be to install the keys and blocks. This is a stock truck(FYI). And, the guy told me that it would be $100 to install the blocks and the keys AND he said that to put blocks in the back, he would have to undo the back shocks to put blocks in?? Never heard of this before. He also told me that my shocks wouldn't hook back up with the 2" block in the rear. So, I'm turning to you for advice. I am going to get new shocks when I get the money. But, could I do this and get away with it for a couple of weeks before I get my new shocks? The ride is not that important to me. I just want a way to fit 33's on 16x8's. And, of course, my dad won't let me lift it. So this is my only option without him noticing. So here are my questions:
1. Can I do this install front and rear without replacing my shocks?
2. Is installing the blocks in the back really that difficult?
3. Is the torsion key swap really difficult to do? I think I can do this, but I just don't want to break anything :crazyi:
Thanks, for your help. Please be patient with me :-D
10-07-2003, 02:33 AM
#91
Drive it like ya stole it
1) Your shocks should be long enough just to run as a temp,just dont flex it or you may break a shock. They have to be long enough for the suspensions full travel, and its got more than 2" of drop to it stock.
2) Installing blocks is easy, undo the u bolts and add em in, put the new longer u-bolts back in, you may not even have to take the shocks off teh axle (no big dual if you do)
3) The torsion key swap is easy to do as well if you have the tools, 2 hrs MAX. Just be safe and think about what your doing. I would personally save the $100 and spend it on new shocks!
2001 Silverado Z-71 5.3 - 1 ton SFA
10-07-2003, 02:39 AM
#92
See the thing is, I don't know if I would be doing it right
The only 2 questions I really have is: can I just buy one puller and or do I need two to clamp on both keys? And what exactly do I have to do when it says to tighen the puller till the key is out?? I don't want to do something and lose a finger or a hand LOL.
10-07-2003, 09:07 AM
#93
how uuu deewwwin
the how to covers that... the puller has a bolt that you tighten/losen and you do 1 at a time, like instructed in the how-to
10-07-2003, 12:57 PM
#94
torsion bars
great info but my problem is I got a 02 crew cab2500 5" rancho with 305's bars are already cranked some. I want to put some 35's on it but I get a vibration at 55-60 mph do I crank it and put a longer drive shft or what? thank for all your go info and what a great site Bobsatruck
10-07-2003, 01:04 PM
#95
how uuu deewwwin
Re: torsion bars
you might want to have your tires rebalaned  and maybe even try a hub centric wheel if it bothers you that much.... but cranking the bars wont make it vibrate more... you will just feel it more cause the suspenson will be slightly stiffer.
10-07-2003, 02:38 PM
#96
Alright, well Sears does not have the 7 ton puller in stock right now. 2 weeks or something like that to get it in. I went to advanced auto parts today and they had a "heavyduty 6inch" but nowhere on it did it say "7 ton" so. Does heavyduty mean 7 ton? Or could I rent a GM torsion unloading/loading tool from the GM place? Need help here guys!!!
10-07-2003, 02:44 PM
#97
OK heres one for ya luke. Say you happen to break the TB bolt.... like maybe the head off. What size bolt would one buy to replace this? Would just a grade 8 bolt work? If not, whats the part # of the bolt so one could order it from GM.
10-07-2003, 03:40 PM
#98
how uuu deewwwin
what i personally would do... is get the toher bolt out, leave the puller on the truck, and head over to the local hardware shop, have them match the bolt, and make sure you get a grade 8 bolt.
10-07-2003, 03:42 PM
#99
how uuu deewwwin
i would either buy the puller online and have it in 5 days or so.... or ask a gm dealer to borrow a puller. i wouldnt risk using one if you dont know the capasity
10-07-2003, 05:24 PM
#100
But if this person only has 1 vehicle?
| Thread Tools |
| Display Modes |
Linear Mode
