Old 06-03-2008, 07:30 PM   #1141
032wdsilverado
Member ID: 78788
if you have never had your bars out, then you need to get a BFH and a pin or large punch and go to town, just dont hit your fingers, i did and it hurt
***totalled***
***Current***
'97 ecsb z71, cranked, 3/4 ton springs, 3" BL, 42" fender height, soon to come 6.5" stage II cepek, or sfa with 37s and 4.56 gears
Old 06-03-2008, 07:38 PM   #1142
Atomic
Premium Member #96
AAAAAAAAHHHHHHH!!
Atomic's Avatar
Member ID: 28959
BFH, I lawled at that.
Old 06-03-2008, 09:14 PM   #1143
chriskg
Member ID: 81795
I have a really nice BFH, but they weren't even budging, but i didn't got to town on it actually, i only beat on it for about 5 minutes, then got frustrated and decided to just crank the key's all the way up. it should fit my new 33's just fine.
i'll end up putting the key's in later though haha
Old 06-05-2008, 10:18 PM   #1144
badasstahoe
Member ID: 90478
kmjmkm
Old 06-06-2008, 09:17 AM   #1145
bowtieboy42
Status: Online
Member ID: 62702
When I unscrewed the adjusting screw, the key stayed stuck at the top, as if the screw was still tightened all the way. Why?
98 k1500 3" blocks, AAL, Cranked, K&N drop in, hi flow cats, 305/70/16 BFG MT
Old 06-06-2008, 12:29 PM   #1146
Atomic
Premium Member #96
AAAAAAAAHHHHHHH!!
Atomic's Avatar
Member ID: 28959
Now thats interesting....rusted?
Old 06-06-2008, 07:10 PM   #1147
bowtieboy42
Status: Online
Member ID: 62702
I guess, I was kind of scared to beat it down, so I just tightened the screw up again.
I'm having a problem getting my LCA screws back in, it doesnt seem to want to line up. Would a tense torsion bar be the cause of that?
Old 06-12-2008, 07:00 PM   #1148
jscott_1
Member ID: 89157
hey i got a 2000 2500 put the green keys in and it bounces so much i cant keep my foot on the accelerator will new shocks stop the bouncing
Old 06-12-2008, 07:08 PM   #1149
foreman00081
IM MIKE D
foreman00081's Avatar
Member ID: 50102
it would probably help, ive heard nothing but great things about bilstien 5100's, my truck rides pretty rough and ive only got the stock keys cranked up along with a 6" lift and im going to go with the bilstiens sometime in the future. what size tires are you running? with those green keys just be ready to replace ball joints much more often then normal because of the added stress of being cranked up that high. ive replaced my uppers twice in 2 years and again thats still with stock keys.
Old 06-12-2008, 07:26 PM   #1150
jscott_1
Member ID: 89157
im running 285/75/16 i liked the ride with me stock keys cranked all the way but these green keys crank not even half way up ride awful u hit a bump and it just keeps bouncing
Old 06-13-2008, 12:05 PM   #1151
foreman00081
IM MIKE D
Member ID: 50102
why did you put green keys in just to run 285's? they fit fine with stock keys cranked. your shocks may also be just plain worn out, are they stock and how many miles on them?
Old 06-14-2008, 04:40 PM   #1152
jscott_1
Member ID: 89157
the 285s rubded on mine witht he stock keys cranked all the way
Old 06-20-2008, 07:55 PM   #1153
Atomic
Premium Member #96
AAAAAAAAHHHHHHH!!
Atomic's Avatar
Member ID: 28959
Made this for another thread, thought it might be useful for those that still dont get it.
Old 07-21-2008, 11:57 AM   #1154
hellcamino59
hellcamino59's Avatar
Member ID: 90021
So I need to replace my RH torsion bar on my '95. I need help finding out the right part for my truck. At the beginning of this thread there's the list of all the part codes. Are those based in part to the VIN on my truck? The old owner re-sprayed the under carriage so there's no ID on the torsions. Thanks in advance 4 the help.
Old 07-21-2008, 12:38 PM   #1155
LPG PWRD
Supporting Member
LPG PWRD's Avatar
Member ID: 79183
Better off buying a set. reason #1,you may never find the exact match to your other one. reason #2 even if you do match your other bar, they will not have the same spring rate due to brand new vs a 13 year old bar. Reason #3 I have a set for sale
DD: 2001 Silverado 1500 ECSB 2wd 5.3L Black
Project: '94 GMC ECSB Black Current: Freshly Painted Frame, D60 & 14BFF
Old 07-21-2008, 12:47 PM   #1156
hellcamino59
Member ID: 90021
How much do you want for the set and how much do you think it would cost to ship to Socal??
Old 08-01-2008, 11:32 PM   #1157
73deville
Member ID: 90911
Hi. Can someone tell me what ratings are the following torsion bars and what key did they came with as the marking are gone expect the code. Code is YB part number is: 15988806 It is on a 1997 4WD 4door Tahoe with 4L60E. thanks again.
Old 08-03-2008, 08:04 PM   #1158
chriskg
Member ID: 81795
I'm running 285s in my 91 1/2 ton with the keys cranked all the way, there was barley any rubbing when I put the tires on, only when you turned the wheels all the way L/R, and only on the driver's side, I just had to shave off less than a 1/2" from the bumper.
Old 08-06-2008, 06:22 PM   #1159
tracker975
Member ID: 93649
Hello...I am new to the site and having read this thread in it's entirety....ok i skipped a few pages but i read most of it...so here is what i seem to have gathered from this vast wealth of knowledge....I just bought a 1997 GMC 1500 extended cab short bed.It already has 3 inch body lift blocks and a 3 inch block in the rear.The Torsion bars have also been cranked up pretty high.The Upper control arm was on the bumpstop.I lowered it and gave myself about a 1/2 inch of space.So here come the questions.....How do i know where stock torsion bar height was....My bars only had 1 tag..part number 15528960 which from the page one list comes out to be GH at 7161.....so my next question is do i use ford part number XL3Z5B328CA for my truck....and if so do i just put it in until the bolts are tight on the keys then adjust the height from there.....I have 33x12.5x15 yokahama geolanders on it and it sits nice i just don't like the control arms being so close to the stops.The truck is mainly a daily driver and both a tow rig for my samurai and a trail and slight mud wheeler.So it does see the dirt often enough for it to be a problem at times but i don't use it heavy enough nor do i have the cash for a full suspension lift.Thanks in advance for the help and time...Joey
OOOOPPPPSSSS i forgot i have Rancho 5000's all around for a 4 inch lift...i know they aren't the best but they were what i could get for the cash locally at 45 a piece....again thanks...Joey
Old 08-08-2008, 11:30 AM   #1160
J-Roc
Member ID: 93744
Hi all, I'm new to this board, but not to the Chevys. I've read hundreds of posts and pages upon pages of information regarding keys and T-bars and WoooOoowW!!! I did not know that there was that much technical info and confusion regarding our trucks! Here's my situation: I've got an 05 1500HD 4x4 with green keys and YH t-bars from the factory. I bought ORU torsion keys thinking I'd be able to level out the truck. WRONG! The ORU key has the same index as my green key! Now, I'm stuck and dont know what to do What key or t-bar do I need to level my truck out? I thought this would be straight forward, but I did not know that GM used soooo many different keys and t-bars I'd like to get my truck up and sittin purdy. Any help or info is appreciated!!!!
