Old 10-07-2003, 04:58 PM   #101
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Originally posted by DarkEternal
But if this person only has 1 vehicle?
ask richard for a ride?
Old 10-07-2003, 05:02 PM   #102
DarkEternal
Drive it like ya stole it
DarkEternal's Avatar
Member ID: 3365
It wont be happening here, actually in Mansfield, and I dont think ill hav a ride there.
2001 Silverado Z-71 5.3 - 1 ton SFA
Old 10-08-2003, 04:32 PM   #103
JimWilson
Member ID: 4348
Tell one of your friends you'll buy him a cold one if he gives you a lift. Well, that would work with me anyway...
2002 Chevy 2500HD CC SB; PIAA eXtreme White Hi & Low Beams; SUVLights headlight harness; PIAA airdam with PIAA foglights; 50 watt backup lights; Undercoated; PowerFlow splash guards; Warn steps (all 4 doors); Jeraco fiberglass cap; Rhino liner; 'Green keys'; 2" rear blocks; 285/75/16 Nitto Terra Grapplers; Rancho RS9000x; VR Straps; Mobil 1 everywhere; Pinstriping
Old 10-08-2003, 09:12 PM   #104
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
its yellow, it smells, rides bad, and is expensive! call a cab doofus!
Old 10-08-2003, 09:30 PM   #105
DarkEternal
Member ID: 3365
your talking to a broke college student who is going to be well outside of any range a cab will want to drive for cheap.
Old 10-09-2003, 02:34 AM   #106
JAYB1RD
Got Hummer?
JAYB1RD's Avatar
Member ID: 3013
great article! i only have one question.... can i or can't i put the ford keys in my OBS 1991 K1500? all these numbers and colors and descriptions have my mind going screwy :crazyi:
2007 Hummer H3 - 33" Mickey MTZs, rock rails, brush guard & lights, Kenwood Excelon & Infinity Kappa sounds
1991 K1500 Sport for sale. All stock, very clean! New crate engine and new trans. 40k miles ago. Lots of other new parts. PM for more info.
Old 10-10-2003, 02:05 PM   #107
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
3) The torsion key swap is easy to do as well if you have the tools, 2 hrs MAX. Just be safe and think about what your doing. I would personally save the $100 and spend it on new shocks!
takes me 30 mins
Old 10-10-2003, 02:14 PM   #108
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
To be perfectly honest, i dont know what the ford keys will do to a OBS truck. i do know you use the same procedure in installation. I do know the torsion bar replacment will work. I think you are going to want to buy some of the aim keys.
Old 10-10-2003, 05:23 PM   #109
DarkEternal
Member ID: 3365
takes me 30 mins
I was saying 2 hrs MAX for a first timer. I can do it in about 30 min now also. 2 Hrs is allowing for problems like stuck bolts etc... and adjusting to get the 2 sides the right height (by driving around then measureing etc..)
Old 10-12-2003, 01:11 AM   #110
Z71GMCSierra
Member ID: 5007
Well, I got it done. Thanks guys. I'm glad I didn't pay that guy for doing that easy job. It took me 45minutes to do the key swap. And I love it the front sits a little higher than the back and I'm going to put a block in the back to to level it out. The only problem I had was when I was trying to get my first key out, so after I wiggled it around for 3minutes or so, I got pissed and yanked toward the front of the truck and I ripped a 3inch GASH in my darn thumb I had to wrap a rag around it so I could finish the job and not be late picking my g\f up for our date
Old 10-12-2003, 10:00 AM   #111
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
thats no good, but im glad u got it down, send some pics before and after
Old 10-13-2003, 04:31 PM   #112
79k20
Member ID: 2376
Can these ford or chevy green keys work on a 01' 3500 hd? If i got the truck i would like a little bit of lift but not much as the truck would be towing a lot.
SEAN
Old 10-13-2003, 07:24 PM   #113
philsummers21
P-I-M-P
Member ID: 8211
Ok so let me get this straight. Ford Keys are just something that you use to "crank" your torsion bars to get more lift?
Old 10-13-2003, 07:27 PM   #114
Z71GMCSierra
Member ID: 5007
Yes, these keys allow more more cranking with less turns. You can install the keys and leave the bolts at factory specs and gain 1.5" roughly. Maxing out the bolts would gain you somewhere in the range of 2-3inches.
Old 10-14-2003, 12:08 PM   #115
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Yes, the green keys would work and not affect towing
Yes, ford keys basically are indexed differntly... thus u can get more lift out of cranking
Old 10-14-2003, 04:49 PM   #116
maxchevy2003
Member ID: 4243
2004 2500 Crew Cab
Ok l am going to crank my torsions soon but a few questions first. lf l crank them up more than 1" should l replace the shocks and what kind of shock should l get? Or should l replace the keys that are there plus get new shocks? I had a 20031500 HD Crew Cab before this truck l raised it up about 1 1/2' everything seemed ok with stock shocks. So with this new truck 2004 2500 Crew Cab the bolts have been raised a couple of threads factory leaving alot to go up. What would you do if you were me. l only want couple inches out of the front. Plus a block in the back end what you recomend? Martin
Old 10-15-2003, 09:08 AM   #117
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Re: 2004 2500 Crew Cab
The shocks will be fine unless u go over 2" Depending on how/where you drive. you can either crank, or get the green keys, it is up to you dude.
Old 10-15-2003, 03:53 PM   #118
maxchevy2003
Member ID: 4243
torsions
Luke changing to green keys will not make the ride any smooth will it? Also where can l fined out the exact block that is used in my 2004 2500 Crew Cab. So should l go what 1" bigger than the one there or 2" I was thinking raise the front 1 1/2 ' then add a 2" bigger block in the rear. Thanks Martin
Old 10-16-2003, 02:50 PM   #119
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Re: torsions
It makes it ride worse, if have a stock 2" block. i only reccomend lifting the frotn level with the rear.... not actually trying to lift your truck like this.
Old 10-16-2003, 03:16 PM   #120
J to the izA
Member ID: 1409
Re: torsions
well..........................you just might have trouble finding A block back there buddy ;)
hint---------they dont have one on 8 lug trucks
16x8 AR bajas for sale. hub centric 6 lug
