Old 10-29-2003, 08:55 PM   #141
cfulback32
Member ID: 2382
I know that there is the possibility of increased wear on the front end components when you crank your torsion bars, but how bad is it really? What parts experience increased wear? and how expensive are they to replace down the line if needed? By the way, I'm not talking some huge amount of cranking, just enough to make my truck level.
Andy
White Chevy 1500 Extended Cab, 3" PA body lift, 285 BFG AT's, 16x8 Weld Sidewinders; Focal 165 K2, Infinity Perfect 12, Rockford amps
Old 10-29-2003, 09:01 PM   #142
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Andy
There is hardly any increased wear from what i have expirenced. If you just want to level it, you will get probally no wear at all. Have you been listening to some stupid salesman or somthing?
Old 10-29-2003, 09:18 PM   #143
cfulback32
Member ID: 2382
lol, you called it. Between the dealership who thought I had a lift and gave me a ton of sh1t just because I had 285's , and a fourwheeler article a while back, I was starting to have my doubts. But I haven't heard of anybody having trouble on here, and I know that there are lots of you guys that have had them cranked for quite a while, so I guess I'll go do it. Thanks for the info
Andy
Old 10-29-2003, 09:22 PM   #144
J to the izA
Member ID: 1409
2 inches or less of cranking is not gonna cause any noticable extra wear IMO. like you said a lot of people have done it for long times. i had my last truck cranked. no problems.
and yeah four wheeler magazine is VERY anti-cranking. but they are also completely anti IFS.
16x8 AR bajas for sale. hub centric 6 lug
Old 11-01-2003, 03:27 AM   #145
00Silverado
NCM!TB!LGB!YBWOB?
Member ID: 1128
Originally posted by Luke2kZ71
Is the truck a 4wd? otherwise it is going to have coils and coils are better covered in the street forum...
but yes techincally... purple keys would lower your 4wd.
The K means 4wd C means 2wd. Just a nice fact for the night
And to J to the izA, I dont think you'll have a problem with cranking your bars. I plan on getting some ford keys here soon
Old 11-03-2003, 10:31 PM   #146
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
i was aware of that, i guess i just didn't catch it... thanks for the heads up
Old 11-04-2003, 01:03 PM   #147
maxchevy2003
Member ID: 4243
When l cranked my torsion bars 2' l had a 2 wheel alimgment but l also put in 2' blocks should l have had a 4 wheel aligment? Martin.
2004 2500 ChevyCrew Cab 4x4 6.0L
torsion crank and 2' block
Old 11-04-2003, 02:07 PM   #148
philsummers21
P-I-M-P
Member ID: 8211
If im am planning on getting a lift in the next few months should i still do the TB cranking or just wait on the lift. Also would this be beneficial to me after I get the lift. Thanks a lot everyone
Old 11-04-2003, 02:14 PM   #149
J to the izA
Member ID: 1409
you cant align the back so dont pay for it
Old 11-10-2003, 12:05 PM   #150
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
you can do any lift mods u want to the rear, it will never have to be aligned, besides the fact you cant align it if you wanted to.
Old 11-14-2003, 11:33 AM   #151
silveradoreb
silveradoreb's Avatar
Member ID: 8756
GM dealerships ford key opinion?
What do the guys at the chevy dealerships say about ford keys? Will they not work on something on your truck because of it or what? I have heard alot of good things bout the keys but putting ford suspension part on a chevy doesn't sound to good for many people. I want to get them but am still debating on wheather to do it or not. Thanks
Old 11-14-2003, 11:36 AM   #152
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
Re: GM dealerships ford key opinion?
it really isnt changing a whole lot, and a dealership will still work on your truck... most likly they will never know u have them unless somthing in your front end goes out.... in that case most that stuff is NOT under warrenty, cause they are considered wearable parts.
Old 11-14-2003, 11:38 AM   #153
silveradoreb
Member ID: 8756
Thats what I was thinking, i figured thed never know, I appreciate your help.
Old 11-14-2003, 11:45 AM   #154
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
very welcome. post some before and after pics if you do it... or comments/suggestions
Old 11-15-2003, 11:41 AM   #155
kmx99
Member ID: 4051
I have had my ford keys for 5000 miles currently have 8500 miles on my 03 avalanch 1500, they stearing assmbley, (idler arm pitman rod) are completly worn out they reason that I noticed is in 4wd the tires accualy toe in, therefore if one is going forword the other tire is accually turned slightly therfore always pushing, well this creats a bad problem if the turned tire gets traction on snow instead of ice, it darts you that direction, and then when you go to correct 1 tires is turned farther the other direction, then your hoping that you dont end up like this along side the road
If anybody has any info for this problem please let me know,and btw my fathers 03 d-max does the same thing and has had the t-bars cranked from day one, and both vehichles were realined after cranking
y2k3 1500 Avalanch 3"spintech, Smoked UPD, Helix power tower, and my fav. 4.10 gears with the g80 (needs it for the 3 ton that it weighs. ouch)
y2k1 Yamaha R1, blue, trimed and flushed, Micron high pipe, barnet race clutch
y2k1 Yamaha Banshee, black/white, toomy t5's, full trimed fenders, getting ready for porting
y2k Ski-doo Highmark, yellow, ppp can, milled head, clutch work
http://us.f1.yahoofs.com/users/ef0d4...hl3K.AA4hZy083
Old 11-15-2003, 05:50 PM   #156
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
sounds like a alignment prob to me.... my truck had maxed torsion abrs then ford keys since the day i owned it, and thats over 40k miles... and i havn't ever had to change out any steering equitment.... u did wait for the bars to settle for about3 days before getting it aligned?
Old 11-16-2003, 12:47 PM   #157
kmx99
Member ID: 4051
I had it realined the same day. do you really need to let them set in??? It does make since. I will try that, set them were I want them and drive it for a while then have it fixed and realined.
Old 11-17-2003, 08:20 PM   #158
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
well i noticed after i cranked my bars a little, i noticed it dropped a pretty good amount of size over the next few days, and i had to keep adjusting the bolts untill it no longer settled down.
Old 11-17-2003, 09:49 PM   #159
Dirty TX Ryder
Todd
Dirty TX Ryder's Avatar
Member ID: 7591
just finished putting them in my brother's truck. took about 35 mins total. super easy to do.
we wished we would have measured it before we added the keys but i am getting them for my truck on friday so i will try to remember to do that.
btw he gained a lot of height and it looks great. we didn't even come close to maxing the keys out. we are going to let it settle for a couple more days then check the height again.
the front fender is now at 38.5" with still room to go. (from ground to bottom of fender)
learned how to do it all by reading this post.
Old 11-18-2003, 08:08 PM   #160
Luke2kZ71
how uuu deewwwin
Luke2kZ71's Avatar
Member ID: 2186
need pictures dude!
