#241 |
Member ID: 81935
Re: Common Lift/Tire Combo's for OBS/NBS Trucks & SUVs
Thanks for the info. Hadn't thought of a leveling kit yet, thanks!
So it begins!
#242 |
Member ID: 82870
Okay It probably has already been covered but I am going to ask anyways. I have a stock '03 1500HD 4x4. I would like to level it and put the larget size tire possible without rub. I do not want to trim. I am not very mechanically inclined so I will be taking it to a shop to get the work done. What do you think would give me the best combination of functionality and look? Eventually I want to run 315's and a 6" suspension lift but that will have to wait until the bdget allows. so for now what do you all think would be best. THanks for the info..
HeavyT Last edited by HeavyT : 02-06-2008 at 09:18 AM. |
#243 |
Member ID: 82656
my 97 has 6"superlift,3"body,bars cranked,36x14.50x15"on 15x10,4.5 backspacing,no problems hear.
#244 |
Mickey Thompson Baja Claw Radials
LT325/50R20 33X13.50R20LT I have a 3" BL with torsion bars cranked and 2" blocks in the rear. I'm currently running 33 X 12.5 R16 on 10" wide rims. It doesn't rub but it is very close. Am I going to run into rubbing issues by going to the 13.5" wide tire compared to the 12.5" wide. on the same size rim. How can I prevent this? Larger or smaller wheel offset? TIA |
#245 |
Dirt Relocater
Member ID: 84094
Nice post SlamChops. Lots of usefull info for the NEWBS.I believe most 2wd trucks are going to have the same specs.
#246 |
Supporting Member
Member ID: 85720
i have a 88 scottsdale 4x4, sitting stock on 305/70/r16. with 16x10 centerline offroad racing wheels, and going
to put a 6" suspension lift, and 315/75/r16's under it. what brand do you all think i should get. i've been looking at the rough country 6" lift. Last edited by crlott111 : 04-10-2008 at 06:56 PM. |
#247 |
Just to check, if I did 3 inch blocks in the rear, ford keys and crank up front, and throw 35's under it, I'd be good to go correct?
#248 | |
Member ID: 53200
![]() RIP 2000 RCSB |
#249 | |
04 Z
Member ID: 85416
Thats what I did and my 285's look tiny you will be just fine seen a lot of people on here who have. |
#250 |
Member ID: 85799
I'll be redeploying from Iraq in december, and have plans to get a 2008 silverado,4wd. I have begun doing research on what i want to fix it up. My intent is to lift it, w/ 6" susp lift. appropriate sized BFG A/T's. I'm not familiar with all the brands and specifics. It will be a daily driver, look great but also have what it takes to handle some muddin' on the weekends. i don't expect a full "how to" response, but i could really use some do's and dont's. the last thing I wanna be is "that guy"
Any suggestions about the rims, normal vs offset? i was advised that the z71 package wd suffice if i don't plan on doing any the "rough stuff". Yeah, I'm the new guy so feel free to throw all the "new guy" jokes at me. I've got a million questions, but Ive got another 10 months to put it altogether. |
#251 |
Member ID: 86857
I'm going to do the 3" block and green key lift. I have 285's on 16x8's with 4.5" backspacing and zero rubbing. I want to run either 33x12.50, 33x13.50, 34x10.50, 35x10.50, or 35x12.50's. Would I have any chance to run any of these with the above rims, or am I better off to throw on the 3" body lift at the same time? I also have the stock steelies if that matters. Thanks!
1995 GMC Sierra 2500
350 5-speed 14 Bolt w/ 4.10's 2.5" Duals w/ Cherry Bombs 285x75x16 Goodyear Wrangler MT/R's 16x8" American Racing Outlaw 2 Rims 1983 GMC Sierra 2500 350/350/NP205 Dana 44 w/ 4.10's 14 Bolt w/ 4.10's 1.75" Duals w/ Cherry Bombs 4" Lift 38.5x11x16 Boggers |
#252 |
i have an 00 sierra 1500, i currently have stock rims with 285/75/16s on the truck, i have no rub at all. i didnt need to crank by torsion bars up any but i did anyways to help level it up some. Im thinking abt buying either 17 or 18 inch rims, whats the biggest tire i can run on them without any rub?
#253 | |
Supporting Member
Member ID: 85720
1988 chevy scottsdale
3/4 ton 4x4 350 auto K&N off-road cold air intake 3" duals w/ super 44 flowmaster magnaflow aftermarket cadillac converter 305/70/r16 Mastercraft Courser MT 16x10 centerline offroad racing wheels 3" bl Last edited by crlott111 : 06-17-2008 at 02:41 PM. |
#254 |
Member ID: 89835
I just got some 285/75/16 for my truck I am planning a 3inch body lift do you know what a good offset is I am going to buy new rims
| Advertisements |
| Thread Tools | |
| Display Modes | |
