Old 07-24-2003, 05:04 AM   #21
'00SierraGuy's Avatar
How about some 2wd to add to the mix. There are plnty of lifted 2wd's on the site and I am sure people are interested to know that as well. Looks good though, very imformative.
Go for it dude. I would find it very helpful and i bet some others would too.
My Car Domain Page
'00SierraGuy is offline
Old 08-27-2003, 12:55 AM   #22
High Tech Redneck
Z71mudder's Avatar
Im confused, how do we know if its a "true" lift or false lift or what not?? If ive got a 4", i didnt have cut out flares, and if its a 6" i didnt trim or crank the tbars?? Im confused! :kidding:
Sorry, I had too! Great info slamchops!!
0? ___ ______ ___
02 GMC Sierra Z71 - SOLD
98 GMC Sierra Z71 - TOTALED
Z71mudder is offline
Old 08-30-2003, 03:43 PM   #23
Josh's Avatar
Great thread!! I joined to learn things like this. Im going with a 3" body lift and 15x8 wheels with 32x11.5 tires. That should be as big as I can go without a suspension lift.
97 Tahoe 4D 4X4
95 Camaro Z28, vert, 6spd, forged 383, LE3/4 H/C. Fast.
Josh is offline
Old 09-08-2003, 07:04 PM   #24
If in doubt, let em out!
Im lifting my 02 2500HD in the near future whats the biggest tire i can run with a 6"lift and the H2 rims (17x8.5). 35"'s? Can i go bigger? Does anyone have any tire recomendations?
cokedrvrbjw is offline
Old 09-10-2003, 09:14 PM   #25
Got body damage?
slamchops's Avatar
the HD's have a little bigger wheelwells, you might be able to 'shove' some 36s under there, but 35 would be a safe bet.
Lock It Up Off-Road
79 K5 (now a Kruggy), 85 4runner BUILT (locked, geared, dual cases, etc), and an 02 2500HD to drag 'em around.
slamchops is offline
Old 09-27-2003, 06:08 PM   #26
03SUB's Avatar
Just finished my body lift(3") on my 03 sub, and I am running 295/75/16's on stock wheels. No rubbing as of now. Thanks, Shannon
2008 Chevy 1500 White Crew
20" Zinik's w/ 285/55/20 BFG A/T
Sold!
2007 1500 RCSB 2wd Plain and cheap!
Sold!
2006 2500 LBZ 6sp auto
exhaust and blocked w/stick
Sold!
2005 Chevy 1500 Crew
20x10's and 285/55/20 BFG A/T
03SUB is offline
Old 10-11-2003, 12:21 PM   #27
HDMLNIUM's Avatar
Question
Ok, How about for an 03 Sierra Denali? I have the t-bars cranked 6 full turn and it gave the truck an inch. They have at least a few more turns left before they bottom out so there is more height to be had. I was trying to level out the truck some but now I think I would like to make it a little bigger with some different wheels and tires.
Any ideas, I am from Maine so we can't go to big here or it won't be allowed on the street.
Bill-03-SD
04 GMC Sierra Z71
05 CTS-V
Online Photos http://photobucket.com/albums/v466/HDMLNIUM/
HDMLNIUM is offline
Old 10-11-2003, 10:18 PM   #28
tbyrne's Avatar
cokedrvrbjw: I run 35s on my '02 HD. 6" lift and cranked the bars enough to get close to 7.5" of lift in the front. I still had to do a little trimming at the corner of the airdam. Tires on this truck are 325/65/18s.
2002 8.1 Silverado HD - Comp Cam, TOGs headers, Volant induction, Direct Hits ignition, 6" lift 18" wheels/tires + more
2002 8.1 Suburban -Intercooled Whipple supercharger, TOGs headers, Volant induction, 22" wheels/tires + more - 14.54 @ 92.43
tbyrne is offline
Old 10-13-2003, 06:37 PM   #29
Banned
Incredible Hulk's Avatar
No, the wheel wells are the same. The difference is the H.D.'s frame is bigger, so it is like it has a 2" body-lift.
Incredible Hulk is offline
Old 10-14-2003, 01:26 PM   #30
how uuu deewwwin
Luke2kZ71's Avatar
Luke2kZ71 is offline
Old 10-21-2003, 12:03 AM   #31
Got body damage?
slamchops's Avatar
ah ha, thanks for that correction.
Lock It Up Off-Road
Old 10-21-2003, 01:07 PM   #32
Hello,
OK - I think I have this whole backspacing thing figured out but.............................................
I have an '01 Silverado Z-71 with the original wheels on it. I installed FORD keys up front and bout myself 2.5 extra inches for about $50 total. I am thinking about 1.5" lift blocks in back, but don't think necessary.
What I need to be sure of are two things:
1- Can I put on 305/70's with this current setup on my stock wheels?
2- If I put on 1.3" thick hub adapters would this help or hurt my fit? I would assume it would result in less problems / less trimming but I'm not sure.
Any advise would be much appreciated.
Thanks,
-Jesse
2001 Z-71 with K&N FIPK, some other "Free" Upgrades - Many future mods to come...
jessecarlson is offline
Old 10-23-2003, 11:56 PM   #33
surferdude's Avatar
I'm wondering why you're going through all of that just to put 305's on an otherwise stock Z-71? I have 305/70R16 MT/R's on my stock 99 Z-71 with minimal t-bar cranking. I had the 305's (AT/S's and MT/R's) on the stock 16x7 rims with NO rubbing and only "minor" rubbing on the left front running 16x8 AR Atlas (4.5" backspacing?) - the wider rim helps the tire fill out more. Now I have no rubbing after running the MT/R's since March - replaced 305 GY AT/S's. I guess I'm just trying to save you some work and $$$.
99 GMC Sierra SLE Z-71, 5.3L, Auto-Trac, Indigo Blue, Alpine head unit, stealth box, Escalade gauge cluster, Silverstars, K&N FIPK Gen II, WESTER's Garage PCM, 3.73 gears, Goodyear MT/R's LT305/70R16, Ravin 55 3" in 2.5" dual catback, AMSOIL synthetic oil, Corvette servo mod pending.
AMSOIL Dealer Z.O. # 1108793
surferdude is offline
Old 10-24-2003, 08:56 AM   #34
Thanks for the reply.
I did the Ford Key thing just because it seemed (after reading alot of threads here) the better way to go instead of just cranking.
I am glad to see you have had no rubbing issues even w the 305 MTR's - I do substantial hwy driving so will probably get a set of ATS'.
Sweet truck! - Mine is same color. I like the way yours looks w/o any additional lift in back / minimal in front. I think I will skip the lift blocks and go with what I have. I may even consider cranking down a 1/4 turn or so because when I put the ford keys in, my truck is about 1/2" higher in front than in back. I thought it would "settle" after a couple weeks, but no way.
I found out that the hub spacers actually make rubbing worse, so that'll save me a couple 100.
Old 10-24-2003, 09:06 AM   #35
surferdude's Avatar
Cool, Jesse, glad to hear you won't be using the hub spacer's! And I didn't know they cost that much!
Old 10-26-2003, 09:38 PM   #36
Six Oh Hoe-ing
treyZ28's Avatar
Red face
One thing I did a search for and couldn't find-
what size can i fit with a stock 2500 HD?
also- pardon my newbieness-
what are ford keys?
03 Silverado
Go Faster: 6.0 Lq9 , HP Tuners: , TB Converter, LT headers
Dont stop: 4x4, Built 4L65E, Terragrappelers, Ford Keys, Locker, Offroad lights, 23 hwy mpg!
Add some Flare: Helo Maxx 6, brush guard, Kenwood deck & speakers
treyZ28 is offline
Old 10-26-2003, 09:41 PM   #37
hd's cant use ford keys. if you dont have them get green keys. there is a HUGE sticky about this. read it.
as far as tires, 285s on stock rims is my favorite
16x8 AR bajas for sale. hub centric 6 lug
J to the izA is offline
Old 10-26-2003, 09:45 PM   #38
Six Oh Hoe-ing
treyZ28's Avatar
285/75/16?
I thought regular 1/2 ton LT could go that big. doesn't the HD have an additional 2'' of space?
03 Silverado
treyZ28 is offline
Old 10-26-2003, 10:04 PM   #39
with the shape of the fenders its hard to stuff tires in there.
yes half tons can fit them stock, but IMO they NEED ford keys at least. hence the two inches.
im not a fan of jamming the biggest tire you can afford into a stock truck. that southern style is fugly IMO and not practicle. on a stock HD you can fit a 295/75 but those tires are alot more $$ than 285's i think
Old 10-26-2003, 10:10 PM   #40
Six Oh Hoe-ing
treyZ28's Avatar
thanks for answering all my questions jeff (and not just this thread)
hopefully i can get this silverado i'm hoping for- but i need to see if the rebates in nov are the same
03 Silverado
treyZ28 is offline
