#101 | |
KY Born, Cali Livin!!!
Member ID: 2184
Re: Common Lift/Tire Combo's for OBS/NBS Trucks & SUVs
This site will provide you with some help on an NBS truck. Other than that, try searching Bodylift on the forums. Basic handtools...power/air tools make the job simpler, faster, and easier.
x-FSC owner.
![]() Will get another...soon I hope....
#102 | |
Stock but not for long.
Thanks bro, great site...
'01 Silverado 1500 HD Crew Cab
#103 | |
Member ID: 2184
Good Luck! ![]()
x-FSC owner.
#104 |
Member ID: 19690
i have a 04 serria 2wd i want to run 35,s i was thinking of the fabtech 7 inch lift or the procomp 7 inch. what do you think? any help would be nice thank you
#105 |
how uuu deewwwin
Member ID: 2186
i like the CST (california super trucks) 2wd kits.... try to get some info from them
#106 |
Member ID: 19690
i did look into there stuff but with there 7 inch lift the recommend 33,s or even 34,s if you can find them
#107 |
ok so i have 6" and 3" combo...running a 36x14.5 on a 10 inch wide wheel with no rub...could i squeeze a 38.5x15.5 with out trimming anything?
#108 |
abov_avg
Member ID: 19116
Im sure everyoen already knows this already, but with a fabtech 6" susp. lift, with just 16x10" rims, 35" tires, rubs liek crazy even under turning on or off road. I have a very shredded and unhappy toyo off read tire that is wearing the scars. The best thing i did to fix teh problem which worked, was cut notches in the front bumper and cut the fender out alittle. It works well not and not had any problems afterwards. Just tryin to save someone soem money, everyone knows by now, tires aren't cheap!
Yep, it's big but it will get bigger with time! LOL. ![]() Go Bush!
#109 |
abov_avg
Member ID: 19116
Sorry guys, i really should have read what i wrote before submitting it, typing on a laptop sux. Sorry for the jacked up spelling.
#110 |
Member ID: 13720
nice list, what about: 325-16 (37" on 16's)???
NBS Trucks (99-03), NBS SUVs (00-03): 9" Total Lift (6" Suspension Lift + 3" Body Lift) - 315/75R16 on Stock Wheels, 16x8, or 16x10 - 36/12.5R16 on Stock Wheels, 16x8, or 16x10 - 38/15.5R16 on 16x10 (torsion bar crank and heavy trimming) |
#111 |
Member ID: 22013
just wandering. i have a 2 door 95 tahoe and am interested in putting 315/75/16's on. even if i cranked the torsion bars high enough would the back rub? Would i have to put blocks? i am a cheapscape and dont have enough money for a lift.
#112 |
Classic's Rule
Member ID: 13631
would anyone happen to know if I could run a 305/70/16 on a 16x10 on a stock '68 k20???
#113 |
Member ID: 11652
The biggest problem I've noticed, is with the 10" rims, if you drop to 8's those rubbing problems almost totally disappear.
'08 Malibu, Momma's new ride!
'95 Saturn SL2 '93 Saturn SL2, FOR SALE '76 GMC K-5 Jimmy '73 Nova SS '66 Suburban '65 Short, wide, big window
#114 |
Bumble bee Tuna...
Member ID: 6626
my 03 hd with 6'' procomp 16.5x9.75 American racing outlaw II's and 35x12.50 Grabber M/T's my moms 02 HD 16x8 weld typhoons 3.658 backspacing 285/75 Future Dakota my dad's 04 Duramax on stock rims 285/75 Bridgestone Dueler A/T ![]() 2003 HD 6'' Lift true Duals with Flowmasters 17x10 Weld Cheyenne 8 wheels on 35x12.50 Baja Claw Radials 2008 GMC 2500HD Duramax 33'toyo m/t's key ways and no dpf!? |
#115 |
OBS FREAK
Member ID: 18959
4.5" - 6" sitting at a 4" Skyjacker lift with a 2" crank up in front, along with a 3" BL on an OBS with 15x10" wheels 3.75 offset, running 36/13.50s no trimming great clearance.
write that down... I dont have a pen... well remember that then ![]()
92 Chevy Silverado Z71 - daily driver- cutout flares 33x15.50s on stock sus,to be install 6.5" DC lift and 3" Body lift plus 38.5/15.00X15 BOGGERs.
91 GMC black RCSB bagged ![]() myspace http://www.myspace.com/mikeywaldoch |
#116 |
Member ID: 19774
Nice trucks.
#117 |
4x4'ing!
Member ID: 23406
Why isnt a 16x10 recommended on stock height 99+?
04 Torrid Red on red M6
SLP LMII,catless mids,Iat relocation,160* Thermostat,P&P TB,Noltec diff bushing,descreened maf,coolent bypass,JHP tube with k&n and ported air box,tune,LSS,c5 pads,nitto dr's,splitter 13.400 @ 104.01 1.999 60 FT
#118 |
Member ID: 24959
94 1500 4WD. Putting 9.5" FT lift and maybe a body lift. W/O body lift can I clear 38.5? Also what backspacing for 16x10 rims?
#119 |
Member ID: 24980
Hey guys, I am new to this forum, this thread came up when I was doing a Google search about lifting my truck. I am planning to lift my truck soon. It's a 97 7Z1 1500 Ext. Cab shortbed. Currently running stock rims, 275/70 BFG ATs that rub when offroading. Anyways, I was going to run a 6 inch suspension lift all the way around. I was thinking about RCD, anyone have pros, cons, or a good alternative? I wanted to run 35x12.50 BFG MTs on 18x10 rims with 4.5inch backspacing. Will I have rubbing issues? And I feel kind of lame for asking, but what does the rim height have to do with rubbing issues? Like, say instead I ran 16x10s with the same backspacing with the same size tires, would I have the same problems that I would with the taller rims? Thanks for the advise ladies and gents, this seems like a great forum, I might stick around. I am a regular over at Chevy Talk. Oh yeah, I am in Pasadena, I don't know I saw some of you talking about Dena earlier. Thanks again folks.
#120 |
Member ID: 5936
I just ordered 315/75/16 for my '02 2500HD. i have no lift. i cranked my t-bars all the way and got 2 inches. i trimmed a ton of plastic and took it down to discount tire and had them mount a BFG AT on my stock wheels. squeezed them in. cranked the wheel both ways trimmed a lil more. they looked awsome but i wanted Nitto Terra Grapplers instead so now i'm waiting for them. The 1st discount tire store i went to refused to even try the 35's on there, so i just called around till i found one that would humor me and mount them so i could see. I was told by someone on here, that has them, that the mud tires occasionally rub on the suspension bar so i got some AT's.(dont have the huge side lugs) I'm getting them on tomorrow. i'll post pics so you all can see how i crammed them on there. the only way i think they could rub is if i hit bumps with the wheel fully cranked, but that wont happen too much i dont think.
2002 2500HD Crew Cab Short Bed, 4x4, LT, 8.1L, Allison tranny, K&N FIPK, 395/70/16 (38x15.5) Mickey Thompson MTZ on DC-1 Black 16x10 wheels, 6" procomp lift + 3" Body lift, Bushwacker cut-out fender flares.
| Advertisements |
| Thread Tools | |
| Display Modes | |
