10-27-2003, 04:15 PM
#21
Hi Dark E
Maybe you already thinked on this, but why don't you add a column with max. tire size for each lift? What about max. tire size for the lift + a body lift?
I know it's in another thread here, but isn't better to have this kind of info in one place?
Just my opinion
Your list
2000 Silverado 2WD Std Cab (NBS)/ 6in Fabtech lift/ 305/70/16
10-27-2003, 10:27 PM
#22
Drive it like ya stole it
Originally posted by jiar577
[BMaybe you already thinked on this, but why don't you add a column with max. tire size for each lift? What about max. tire size for the lift + a body lift?
[/B]
I have thought about this, but it would be a very controversial column. It all depends so much on how much you crank, what rim size, backspacing, how much you trim, or what you consider aceptable rubbing, not to mention sizes differ between tire brands.
2001 Silverado Z-71 5.3 - 1 ton SFA
10-28-2003, 02:00 PM
#23
You have a good point with that!! anyway, great job, your list is very very useful
11-06-2003, 08:42 PM
#24
Wal-mart Sucks
looks great DE, lots of time and effort on your part.
Jake
1991 GMC 1500, 4X4, short bed, 5.7 liter, 4L60, BF Goodrich T/A KO 265/75R16, K&N air filter, Flowmaster
11-18-2003, 07:05 PM
#25
Klein Kat Soccer
Thanks alot!!!! That really helps me and a couple friends!!!
11-22-2003, 09:28 PM
#26
i wish there was 2wd stuff on there, especially fab-tech 6" long travel for a 95
your truck looks awsome  i was at the meet today and man that thing rocks
11-22-2003, 10:22 PM
#27
When I get the time to do the research, it will all be there, just it takes many many hours to compile all the info.
11-29-2003, 07:28 PM
#28
dumb question - what difference does it make if steering knuckles get dropped in a 6" HD or not? If lifts are hard on front-end components, and I realize there are several factors to consider, I'm just wondering if one set-up is better than another (drop vs. no drop) in that regard?
03 2500HD D/A
11-29-2003, 08:02 PM
#29
I kinda worded it bad, "drop steering knuckles" means that the lift DOESNT drop the upper control arm., but does the lower, and uses longer steering knuckles to compensate. This causes worse CV angles.
01-04-2004, 09:09 AM
#30
how uuu deewwwin
not dropping the upper control arm causes bad cv angles  i allways figured not dropping the front diff caused bad cv angles
01-04-2004, 02:18 PM
#31
Ehh shut up, Its because you drop the LCA more than the diff.
01-26-2004, 05:29 PM
#32
Havasu Realtor
this is great stuff dark....... I have referred my friends to it a few times.
Lets see if i can rate this thread again
02 gmc, ecsb, 5.3, 4.10's
6"rcd, 315's, 16x8's, & more doodads too
01-26-2004, 06:03 PM
#33
Thanks - glad its helped. Ive been really busy lately with sfa stuff but hopefull ill get obs and 2wd **** up soon. Its just a TON of work. These 2 combined probably took me 12hrs of research.
01-30-2004, 10:51 PM
#34
AKA 1BADZ
Just to help you out, the BDS and RCD kits Drop the diff 4.5" and the fabtech drops it 4" for the 99-up 1/2 tons. The RCD retains factory track width up front while the BDS and Fabtech push it out about 1-2" on each side. All this info was obtained from the manufacturer via telephone.
2000 Z71
6" RCD 315 X's, Helo Maxx 6's
Race Bullet, Shaved, etc.
See homepage for pics
SOLD
01-30-2004, 11:00 PM
#35
well fabtech and BDS are the same exact thing......
16x8 AR bajas for sale. hub centric 6 lug
01-31-2004, 05:40 AM
#36
AKA 1BADZ
The BDS doesn't retain factory track width. When the track width is widened, it puts more stress on the ball joints and steering components.
2000 Z71
SOLD
01-31-2004, 11:26 PM
#37
ok well just for clarification i made my post because of a TYPO in your post, which you have now fixed. i shall now edit mine so i dont look like an idiot.
and RCD widens the trac width
02-03-2004, 11:56 AM
#38
Havasu Realtor
yes it does... you are right
02-03-2004, 12:11 PM
#39
ALL spindle lifts widen the trac width to a certain extent, its just the design of the lift. Some may more than others, that I am not sure about.
02-03-2004, 04:26 PM
#40
AKA 1BADZ
I am sorry if I hurt your feelings J by using the edit button...I thought that is what it was there for. To many acronyms I guess. When I talked to Paul at RCD he said that it did not and that was why you could not run factory rims with it. Maybe he was incorrect, but he seemed very knowledgeable about his product. I am going to call them again tomorrow, so I will double check. As far as BDS and Fabtech being exactly the same, they are in the fact that they are a spindle lift but Fabtech only drops the differential 4" (directly from the mouths at Fabtech) while RCD and BDS go 4.5". It seems the RCD and BDS would put your CV's at less of an angle. I also experienced terrible customer service at Fabtech...has anyone else got this from them? On the other hand RCD was stellar.
Went ahead and called this afternoon. The RCD does not widen the track width on the 99-up trucks. The RCD retains the factoy track width 100%. The 99-up trucks do have a 1" wider track up front than in back from the factory. Maybe this is just more noticeable after the larger wheels and tires. The RCD for 88-98 trucks does widen the track width because of stability issues. Hope this helped.
2000 Z71
SOLD
| Thread Tools |
| Display Modes |
Linear Mode
