02-03-2004, 07:32 PM
#41
Drive it like ya stole it
Thanks for setting it all straight. Ill update that later tonight. I may double check the fabtech diff drop though, I could have sworn I saw 4.5 in lots of places, but I could very well be wrong.
2001 Silverado Z-71 5.3 - 1 ton SFA
02-03-2004, 09:24 PM
#42
AKA 1BADZ
No Problem. I believe the guy that I talked to at Fabtech was Louis. I thought only 4" was strange also. When I asked him why they only dropped it 4" when other spindle lifts dropped it 4.5" he said "I don't know why they only drop it that much". It does not say on their website, so you may want to call them.
2000 Z71
6" RCD 315 X's, Helo Maxx 6's
Race Bullet, Shaved, etc.
See homepage for pics
SOLD
09-11-2004, 10:26 PM
#43
wrong thread sorrrrry
12-27-2004, 06:27 PM
#44
OBS FREAK
Re: Lift Specs
Nice work Dark Eternal.
92 Chevy Silverado Z71 - daily driver - cutout flares 6.5" DC, 3" BL, 38.5/15.00/15 BOGGERs.
95 Chevy suburban, 4/6 drop, 22s, alot of other junk too.
91 GMC black RCSB 2wd building into a prostreet SS rep truck.
01-07-2005, 01:02 PM
#45
03 Silverado
Re: Lift Specs
Does anyone know which OBS kit adds the least amount to your front track width? I don't want the front tires sticking out way more than the back like I see on some lifted trucks.
01-10-2005, 04:13 PM
#46
AKA 1BADZ
Re: Lift Specs
Has anyone made one of these for the OBS trucks?
2000 Z71
SOLD
01-10-2005, 04:37 PM
#47
Re: Lift Specs
Any non knuckle lift wont add any width. The dick cepeck 6.5" is what I would pick.
01-10-2005, 05:05 PM
#48
how uuu deewwwin
Re: Lift Specs
tried to make a lift kit? no.
i have heard of 1 guy that extented a 6" to 8"
but u know... this isnt somthing easily made.... it has to keep all specs to keep alignment and steering in check...
when u can get kits so cheap, building one isnt worth it... it probally wouldnt even save u that much after all the materials you would have to buy
not to mention the time and testing
01-10-2005, 06:52 PM
#49
Re: Lift Specs
Dude he was talking about the spec sheet...
01-11-2005, 02:00 PM
#50
AKA 1BADZ
Re: Lift Specs
DE is right once again...Luke...get off the crack...lol
2000 Z71
SOLD
01-12-2005, 02:11 PM
#51
03 Silverado
Re: Lift Specs
Thanks. I guess the extra track width would allow more clearance for turning, though.
07-01-2005, 11:08 AM
#52
Re: Lift Specs
Does anyone use the rock krawler for nbs trucks. I read the link it looks sweet with the coilovers, but the price?
09-09-2005, 09:45 PM
#53
2KTallChevy
Re: Lift Specs
I thought you gained trac width when installing cv spacers that come with a lift kit. Is this not true that there is not trac width when using these spacers? I thought depending on the width of the spacer that was your trac width gained on the lift. I don't know if I'm stating this right, but I hope some one gets what I am talking about.
10-19-2005, 03:31 AM
#54
Z71
Re: Lift Specs
Great Job Man..ypu Have Helped Out Alot Of People..maybe Add Approximate Prices
11-03-2005, 07:33 AM
#55
Mike
Re: Lift Specs
Maybe I overlooked it, the 2500HD, and 3500 has the same setup in 4x4 as it does in 4x2 trim. So you can add the 4x2`s to the list for the HD`s.
I took a 6-8" BDS lift, and a 2-3" lift (for the older style GM 1/2 ton truck upto 1998`s) and made it an 9-10" lift. (Set at 10") But I would not recommend anyone do this unless they know what they are doing.
Mike http://community.webshots.com/user/hdmax2002 Chevy 2500HD duramax Diesel, Allison 5 speed automatic transmission, Crew cab, Short bed, LS trim, Forest Green, 4x4, Limited slip, boost & EGT gauges, 35" tires 2.5" lift, EFILive=500+ rwhp
http://esnips.com/web/bigluke39-MySongs
06-13-2006, 11:25 PM
#56
Grease Monkey
Re: Lift Specs
Newb question (good FAQ material?) what's the useful (if any?) difference in the rear lifts that replace the leaf spring versus the ones that use blocks under the stock leaf? From the photos I've seen, I rather prefe rthe appearance of the blocks over the HUGE arcing replacement leafs, but I'm curious what advantages justify the increased cost?
Very useful info here so far though - your efforts are appreciated.
Thanks,
- BB
06-27-2006, 10:20 PM
#57
BIGGER & BETTER in TEXAS!
Re: Lift Specs
So have we all decided on what lift drops the diff a full 6"s on the NBS? Or is 4.5" what you have to be happy with? Also have we decided on the "best" 6" kit for the NBS? I've read alot of threads already and everyone has their own opp.'s!
09-03-2006, 09:53 AM
#58
Re: Lift Specs
From my experience knee deep in doing the install myself:
-Tuff County 88-98 4x4
-Spindle lift
-Widens front track, looks like almost 2" per side, I'll measure later for you
-Welded single piece drop sub frame, not sure how big the diff drop is, LCA's dropped 5 5/8".
-Lateral compression struts
-4" lift blocks
-Add-a-leaves on 6" kit
-Mine came with shocks, maybe a new addition, because the instructions swear up and down that the kit doesn't come with them. The instructions that I printed off the internet and the ones that come with the kit are a little different?
-So far I am happy with the decision, essentially an RCD for 400 less.
'97 Tahoe
Tuff Country 6" Spindle lift
32x11.50 ProComp AT on 15x10
5% tint so you can't see up in my windows
11-15-2006, 08:52 PM
#59
Re: Lift Specs
can u add a lift spendal on the superlift 6-7.5 bracket kit to gain more lift?
12-08-2006, 10:00 AM
#60
Another lift to add to Lift Specs
This thread is really helpful. Tons of info.
While researching lifts I ran across this new product from Skyjacker. This should expand options for those wanting more than a TB crank but not wanting to do the body lifts.
I want a real moderate lift of 3" and crank the TB's about 1.5" - 2" to stuff 34" BFG's under it. Ok with trimming and pinning back rear sheetmetal under the fender well cover (not seen).
Skyjacker 3" suspension lift, knuckle kit with 1.5" block in the rear. Available in Jan of 2007.
http://www.skyjacker.com/
#C9381K for 01-06 GM 2500HD. Tech claims 3/4" wider on each side, max 4.5" BS per wheel.
#C9461K for 99-05 1500, Avy, Tahoe, Yukon, Escy, Denali, Suburban.
"Somedays you're the windshield, somedays you're the bug." - unknown
| Thread Tools |
| Display Modes |
Linear Mode
