11-05-2009, 11:37 AM
FSC FOR LIFE!
1979 Chevy Flatbed.
I have a friend who has a timing issue with his 1979 Chevy flatbed.
350 V8, 2bbl, Points HEI ignition, Pretty much stock.
Put all new ignition on it (Distributor, cap, rotor, coil, wires, plugs.
Idles rough, then when you give it gas it backfires out the carb. It did this before he did all the stuff to it. I'm still thinking it's not timed right. Any other ideas of what it could be? I'm not thinking it's a flat cam, or valve train?
1991 K1500 Silverado RCLB aka "The UFO"
1993 K1500 W/T RCLB aka "The beater"
11-05-2009, 05:57 PM
#2
Loving The 3 Speed
Re: 1979 Chevy Flatbed.
What is the timing at? Vac advance disconnected?
355ci-9.6:1 Compression-TBI mods-Vortec Heads-GMPP TBI Intake-Melling Cam-Roller Rockers-Flowtech Headers-MSD Ignition-Super 40's-TB Spacer-AFPR-6" Superlift-36"TSLs-Built Turbo 350
11-05-2009, 09:00 PM
#3
GMC RULZZ
if timing is erratic at idle, I would suspect internal engine damage or just plain worn out.
 Matching Ninja 500r
11-06-2009, 05:45 AM
#4
one of my trucks did that and i did evething i could think of well it was the hei module under the rotor did that truck ran great try it i think the part is cheap
11-06-2009, 09:49 AM
#5
FSC FOR LIFE!
I'm thinking it's a flat cam. I mean a 350 in that big of a truck!!!
11-06-2009, 10:03 AM
#6
RAMZ TRK
Timing chain got slack. On a big truck like that people use the engine to hold it back instead of brakes. Also check distributor gear and for slack. Does the timing jump around with a timing light on it?
2004 GMC Seirra ECSB 4X4 5.3 AUTO
Originally Posted by someotherguy
It's always easier to ask forgiveness, than ask permission!
Richard
11-06-2009, 10:59 AM
#7
Beef it up, put a new intake with Vortec heads on it and a 4bbl. Get some longtubes and do a full exhaust, let it breathe. With some work a 350 could do well in a truck that size, i'd imagine it's already got granny low gearing and axle ratio.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
Custom open air cleaner
11-06-2009, 11:26 AM
#8
RAMZ TRK
We had a c60 log truck like that with a 350. Loaded you will not break the speed limit but it got the job done. One guy use to haul logs with a inline 6. LOL.
Richard
11-06-2009, 11:33 AM
#9
I'd prefer an inline 6 over a 350 in a truck like that, a built inline 6 with proper gearing will pull like a diesel and last forever. There was an old Ford F-600 for sale near my house, I wanted to buy it and drop a built 300 into it with a 4-speed, it'd be more truck than I need though, right now my stripped minivan hauls everything lol.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
11-07-2009, 11:16 PM
#10
FSC FOR LIFE!
Turns out the guy who installed the wires got two backwards. Now it runs like a top. Still a little underpowered but gets the job done.
| Thread Tools |
| Display Modes |
Linear Mode
