View Poll Results: Better of the 2 shortys
Flowtech Emission legal Shortys 20 40.82%
Summit Racing shorty truck headers 29 59.18%
Voters: 49. You may not vote on this poll
Old 08-01-2007, 08:48 PM   #1
Flowtech Shortys vs. Summit Shorties
alrite... means i ahve a cracked exhasut manifold and not much really behind that im completly redoing my exhasut systehm
gonna go with shorty headers and dont want to spend much.
narrowed it down to
Some
Flowtech Shorty Emission legal headers which i can get for 202 thru summit.. or some summit racing shorty truck headers which go for 152
whihc is better? any one have either?
then after the headers, puttin on a brand new factory y-pipe i have sititn around, tghats gonn run into a Flowmaster Super 44 off-road series 3''inlet and 2.5 dual outlet, and the duals out the back.
so summit or flowtech?
1989 Chevy 1500
"A.K.A. the Silver Bullet"
5.7 TBI
3'' body lift
33'' Durango Radial M/T
Turbo 350 with shift kit
other little goodies.. and more to come
89SilverBullet is offline
Old 08-20-2007, 02:20 AM   #2
do sumthin.
BlazinX's Avatar
Re: Flowtech Shortys vs. Summit Shorties
I have teh Flowtechs, no complaints here.
94 BLAZER 4x4 350tbi
BellTech Drop 4/5.5, Hellwig SwayBars, 20" Panther 519 Vector Wheels, 275/45-20s, Airaid CIA, TB Spacer, Rebuilt TB, Edelbrock Intake, True Dual 2.5" Exhaust, Flowtech Headers, FlowMaster 50 Series, Stage2 Chip, TransGo Shift Kit, Vette Servos..
BlazinX is offline
Old 08-20-2007, 01:20 PM   #3
I have had 3 sets of flowtechs, on 3 different trucks of course. Only thing I can suggest is different gaskets. All of them leaked bad until I changed them. I tightened them often but they just don't seem to be a great gasket.
97gmcextcab is offline
Old 08-20-2007, 01:22 PM   #4
None...none more black
BackinBlack's Avatar
I had the Summit shorties on my 88 with no complaints. Good for the $$ imo.
BackinBlack is offline
Old 08-21-2007, 09:56 PM   #5
well i went with flotechs.. and so far.. they are great..
totally nite and day from my old exhasut system.
whcih was manifolds were had a crack on one. the gaskets leaked, donuts were shot. flanges on the y-pipe were shot.. went into like a 2'' glass pack..
now i have no leaks.. and that flowmasters sound!
1989 Chevy 1500
5.7 TBI
3'' body lift
Old 11-10-2007, 11:49 AM   #6
any numbers with the shorties?
goldlifter is offline
Old 11-10-2007, 02:09 PM   #7
no numbers.. just a big smile on my face...
noticed about 1-2 mpg better with the exhastu.. simply b/c i didnt really have anything before.. and im sure if i didnt use my heavy rite foot all the time i would see better....
notived a increase in excelleration... its a stop-light demon... took my buddy who has a 97 2500 w/ a 454.. took him at the lgiths.. and that truck is quick
1989 Chevy 1500
5.7 TBI
3'' body lift
Old 11-11-2007, 05:57 PM   #8
I bought the "summit" brand for my old 88 tbi 350 a few years ago and I remember them having a flow-tec emblem welded onto one of the tubes.
wolf396 is offline
Old 11-11-2007, 06:12 PM   #9
Diesel Nut
justy's Avatar
summit headers are made by a company called pacesetter. There the biggest piece of junk headers I ever tried. Had nothing but egr valve problems. And no low end torque. Tires wouldn't chirp any more through the gears. The stock manifolds had a better sound then these things. You get alot of hesitation on take off.
2007 3500HD NBS Duramax
justy is offline
Old 11-12-2007, 11:16 AM   #10
not the ones i had. they may have changed since i bought them (this was over 5 years ago).
wolf396 is offline
Old 11-13-2007, 10:30 PM   #11
^^NEEDS A SMOKE^^
chevy 86's Avatar
is it correct that you wont get the FULL potential out of headers if you dont port your heads????
chevy 86 is offline
Old 11-15-2007, 01:38 PM   #12
BumpinRST
honestly neither JBA shorties are the way to go if you're getting shorties i mean you can't beat the sound & performance...plus your getting your quality name & a quality part i hope your not just getting these based on their prices...if that's the situation then i would save up and go quality $650/pair JBA
but if i were forced to choose flowtech i suppose...i wouldn't ever go with the magazine brand
2004RegencyRST is offline
Old 08-13-2008, 07:21 PM   #13
I have the summit shorties(pacesetter).haven't had any problems with them, best part about them is how thick the flanges are no leaks even with the gaskets they sent with them.
chevy thunder is offline
Old 08-17-2008, 12:39 AM   #14
Biggreentank's Avatar
Are Edelbrock shorties any good? I have some for a TBI engine on ebay but I'm thinking about keeping them.
Biggreentank is offline
Old 08-17-2008, 02:23 AM   #15
Supporting Member
GreaseDog's Avatar
Fel Pro exhaust manifold gaskets FTW. i dont buy header gaskets, and none of my trucks have/will have manifolds. started using the exhaust manifold gaskets a few years back, and havent had a bit of problem. been using Flowtech headers for a little over 10 years. the set i just put on my 94 a couple days ago was the FIRST set i've ever had to do anything to in order to get them to fit perfect. ended up dimpling 2 tubes on the passenger header just slightly for bolt clearance. i'd also recomend the 11504 headers from Flowtech, and the 11504Y y-pipe to go along with them. MUCH larger tube than your stocker, and not crimp bent. blows the stocker out of the water!
GreaseDog is offline
Old 08-17-2008, 02:33 AM   #16
Supporting Member
GreaseDog's Avatar
big advertising, like JBA does in the truck mags, doesnt equal a superior product. like i said in my previous post, i've been running Flowtechs for years without issue. no sense in spending $350 on a set of headers just to restrict them with a stock y pipe. you can buy the Flowtech headers and the higher flowing Y pipe for $285. just doesnt financially make any sense.
as for buying Summit brand stuff... been doing that for years as well. i guarantee that EVERYTHING in the Summit catalog is available someplace else in that catalog with a different brand name on the box, and a higher price. Summit wont put their name on something that is a total piece of crap.
Old 08-18-2008, 08:18 AM   #17
TEE
The Edelbrock TiTechs are great and hold up well......
TEE is offline
Old 08-18-2008, 04:33 PM   #18
♠ FeliX ♠'s Avatar
go with summit shorties
I wake up in the morning and i piss excellence!
♠ FeliX ♠ is offline
Old 08-18-2008, 04:41 PM   #19
Runnin 15's at 5500 lbs
Hammerdown's Avatar
I ordered summit shorties for my 93 350 silverado, a flowtech box of headers arrived. When I installed them, they fit easy and I painted them with the 1200 degree duplicolor and it never burned off. The problem was no gains and the collector leaked like a sieve where there was not much weld in between the four tubes, kind of a toss up on summits or flowtechs.
2002 GMC Sierra SLE Z71 ext.cab 5.3L---Single 3" flowmaster 40 dumped, Spectre CAI, LT headers and ORY, Wheatley tune, Mid 15's
Hammerdown is offline
Old 08-18-2008, 10:50 PM   #20
Supporting Member
GreaseDog's Avatar
interesting, none of my Flowtechs have ever had a Flowtech emblem welded to them anywhere. i've got 4 sets right now, and have probably had 6 or 7 other sets.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
