Old 05-17-2008, 08:18 AM   #1
19doug90
19doug90's Avatar
Member ID: 41094
no cats how lean
if i delete my cats but still have the downstream 02's how lean is the computer going to put the motor because of this
would be nice if someone whos done this before could chime in.
its on a 97 yukon
Old 05-17-2008, 08:31 AM   #2
dave89iroc
dave89iroc's Avatar
Member ID: 73893
Re: no cats how lean
downstreams have no effect on the fuel/air mix, that is the upstreams, the downstreams are for cat monitoring only, you will get a check engine light until you get a tune though
1994 Z71 SCLB 355, Dart Heads, 10.5:1 CR, PM rods, CC XR270HR, CC Pro-Mag RRs, RPM Air-Gap , 4 barrel TBI, 7 qt. oil pan, Headman long tubes , not finished yet
Old 05-17-2008, 08:46 AM   #3
19doug90
19doug90's Avatar
Member ID: 41094
ah right on, i knew the downstreams monitored the cats but figured if it was reading the cat being seriously rich it would lean out the engine a bit. Guess not tho.
So could i just delete the downstream 02's completly and live with the check engine light? when i was going accross the country i lost an 02 and the truck went into a borderline limp home mode, gobs of fuel lost 1/3 of my gas mileage until i got it fixed. But the reader said both the upstream and 1 of the downstreams were bad.
Was this just caused by my upstream going out or if i completly disconnect the downstreams might this happen?
Old 05-17-2008, 09:32 AM   #4
PHATSPEED7x
NOBAMA 08!!!
PHATSPEED7x's Avatar
Member ID: 27429
I deleted the cats on my 98 and never got a SES light for some reason. And I never got a custom tune.
Old 05-17-2008, 09:33 AM   #5
19doug90
19doug90's Avatar
Member ID: 41094
did you still keep the downstreams in place tho?
EDIT: obviously you did or youd get an ses light, k im not real worried about it then
