View Poll Results: What do you have, Y-pipe or True duals ?
Y-pipe 32 41.03%
True duals 44 56.41%
Other Please explain 4 5.13%
Multiple Choice Poll. Voters: 78. You may not vote on this poll
Old 09-15-2009, 01:22 PM   #21
phantom member
zebra86's Avatar
Re: Y-pipe or True duals ?
currently have stock manifolds, stock y-pipe, 3" single to a mellowtone dual 2.5" out muffler & dumped.
later, i might go with longtubes, cats, h-pipe, & 2.5" true dual
zebra86 is offline
Old 09-15-2009, 04:11 PM   #22
88Vic's Avatar
Originally Posted by 1Sick1500 View Post
i couldnt run the x-pipe on my truck or else i would have. the problem with my 2-link and laying frame would have just caused me more headaches. true duals where well worth the money. i am very very happy with it and the sound is amazing.
You can fit an H-pipe into it, the pipes just run next to each other so just have a pipe wleded in the middle running parallel, you'll be amazed at how much it tones the exhaust and makes a deeper rumble.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
Custom open air cleaner
88Vic is offline
Old 09-18-2009, 10:48 PM   #23
#1 Dawg fan
GoDawgs's Avatar
Originally Posted by DRUSS25 View Post
I'd go with true duals.
dude i saw your truck on ebay. I think it was your video. the one with mud on the tires and when it was stock other than exhaust?
Btw nice wheels, what kind are they?
Id rather eat s**t than drive a japanese truck!
GoDawgs is offline
Old 09-18-2009, 10:49 PM   #24
#1 Dawg fan
GoDawgs's Avatar
wow lol i guess i had ebay on my mind. I meant youtube haha
GoDawgs is offline
Old 09-30-2009, 06:31 PM   #25
cancritter's Avatar
Originally Posted by 1989K1500 View Post
Duals are a waste for 99% of people on here, but if you do them at least put an x pipe in there.
ditto...had duals..lost torque...went back to single 3in..runs muchhhhh better
[Stole/FOUND 13/03/08 :O)
91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Hooker Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 bolt,Hooker LT,areofilter,Extreme TBI.msd and still adding
97/rclb/5.7/westers tune/stock
cancritter is offline
Old 09-30-2009, 06:37 PM   #26
5.7L JWL's Avatar
I cant vote because my set-up is not a choice. I have True Duals, into the muffler, but the "y-pipe" really is just a "Y" shape, and not a Y-Pipe in the real sense.
Dual 2.5" in and Single 3.5" out, into a 4" tip.
Jay
'98 ECSB, Edel Headers, Magnaflow Cats/CatBack
K&N,Pully, Ign.Kit, D/S Rotors, SS Lines
BB 89 Tune
http://photobucket.com/R3215T3R/
(Toyvrolet Drag Truck/S-10 Drag Truck)Pics.
5.7L JWL is offline
Old 09-30-2009, 07:13 PM   #27
94_c/1500's Avatar
My 94 has a V6. It has dual 2 1/4 pipes, dual Thunderbodt cats, dual Flowmaster 40s, dual 3 inch tips exiting behind the rear tires. It still has manifolds.
My Scrambler has a 1979 305 in it. It has 2 1/2 pipes, dual Thunderbolt cats, dual Cherry Bomb Extremes, turndowns past the cab. It also has Headman headers. I think this setup is one the loudest you can get and still be legal.
Is anyone using SLP Loudmouths? I heard they are the loudest you can get.
1994 GMC Sierra, 1982 Jeep Scrambler, 1975 Jeep J10
Drive a pickup truck, trustin' God and luck
http://www.fullsizechevy.com/forums/...my-trucks.html
94_c/1500 is offline
Old 09-30-2009, 08:29 PM   #28
On all of my previous vehicles i've run headers with no cats into an x-pipe with dynomax bullets and then dumped. On my 08 silvy i've got a Y with no muffler and dumped.
Most folks make the mistake of putting the X and H pipe too far back in the system to have full advantage of it.
LiveDakota is offline
Old 09-30-2009, 08:38 PM   #29
behind the wheel
The cheater way of finding where to locate the H is to use regular temp spray paint and paint both pipes then watch for what section burns out first. That's where the pipe needs to go. It's the location of highest turbulence in the down pipe.
X's tend to be located where you can fit them, but they act differently on the flow. An H allows a balancing of pressures across both pipes. X's act as venturi for the other bank.
I'd even go so far as to say that a properly sized Y pipe'd single exhaust might make more power than true duals with no connection. You're balancing two separate 4 cyl engines with regard to the exhaust banks. Either they can fight each other, or they can help. You gain scavenging by having both banks connected at some point (so long as it's in the right location to be properly phased for the pulses).
Jim
2000 NBS Tahoe 5.3 4wd crap hauler
Ported TB, MAF screen delete, Energy Suspension bushings (F/R), Detroit Locker
Loose Nut is offline
Old 10-05-2009, 09:51 PM   #30
gr8twhite's Avatar
1989 350 Silverado, Aftermarket Y pipe 3" collector, 3" ID exhaust, 3" Magnaflow catalytic converter, 3" in/out Cherry Bomb Elite, 3" tailpipe, side exit passenger side.
http://www.youtube.com/watch?v=FMiMdIGL7Q0
Works great, sounds better!
gr8twhite is offline
Old 10-06-2009, 08:05 PM   #31
Cars & Guitars
04SilveradoMykk's Avatar
^^^ haha
"can you position the camera further away..."
"No"
haha
Vortec 357ci SBC
Cardomain Link : YouTube Link : Myspace Link
Custom PCM Tuning
04SilveradoMykk is offline
Old 10-16-2009, 11:46 AM   #32
adamv7010's Avatar
i run true duals with an x pipe with 2.5" pipe on my 05
2005 Ext Cab Z71-T-bar crank, 295/70/17 Terra Grapplers,True dual exhaust, 2.5" pipe w/4" stainless rolled edge tips, 5% tint on all windows. HID Gate 9000k HIDS in lows and fogs
1984 Reg Cab K-10-33" free all terrains, No lift, no exhaust. Mild 350
adamv7010 is offline
Old 10-19-2009, 08:44 AM   #33
Mine is a Y pipe with a glasspack muffler in the stock muffler location. Sounds good but not loud.
amchev is offline
