Old 11-01-2009, 02:49 PM   #1
Mikes Paint and Body
Jimmy_D's Avatar
Cab Resonance!!
01 chevy 4.8 with headers no cats and a single in dual out with turndowns.. Horrible cab resonating at normal driving. Sounds good at wot and idle etc.. how to fix the really bad drone in the cab?
01 ECSB. pewter of course.4/6 drop,22in wheels,shaved:rollpan,taillights,tailgate handle,billet grille,cai,headers,tb spacer,shift kit,vette servos,flowmaster,4.11 posi,taylor 10.4 wires,2 Memphis 12s,fosgate bd1000 amp,pioneer tv,
Jimmy_D is offline
Old 11-01-2009, 03:53 PM   #2
94_c/1500's Avatar
Re: Cab Resonance!!
If you don't like the drone, maybe you could use Dynamat extreme.
1994 GMC Sierra, 1982 Jeep Scrambler, 1975 Jeep J10
Drive a pickup truck, trustin' God and luck
http://www.fullsizechevy.com/forums/...my-trucks.html
94_c/1500 is online now
Old 11-01-2009, 04:23 PM   #3
Tweaks's Avatar
Re: Cab Resonance!!
Everything about your setup is working together to create the resonance, especially the lack of cats. You didn't mention what brand or style of muffler you are using, but that will be the one thing you could change in hopes of reducing or eliminating the drone. The other option would be to get rid of the turndowns and run the exit all the way back or at least behind the rear axle.
00 RCSB Z71 / ss Spintech exhaust / Z71 Tahoe valance / EBC slotted&drilled brake rotors / Edelbrock headers / Blackbear tune/ 6000k HID low beam and fog lamps / Auto-headlight mod(nice)/ Vette servo
Wish List: E-fans
My allergies to these fans... has returned-Slapshot
Tweaks is offline
Old 11-01-2009, 10:39 PM   #4
Jimmy_D's Avatar
Re: Cab Resonance!!
flowmaster.. Yeah i've got to do something its the worst out of all my vehicles i've had in the past with the same setup
Jimmy_D is offline
Old 11-01-2009, 10:45 PM   #5
--Tyler--
Underpowered's Avatar
Re: Cab Resonance!!
flow master.....check
no cats.........check
turndowns.......check
sounds like the perfect recipe for killer drone!
i am nearly drone free with my headers, no cats, and i have a hooker aerochamber muffler. hardly any drone at all compared to my old CB extreme, which had less drone than my flow 40
2003 Z71 slightly modded.
^^courtesy of xZoomerZx
Underpowered is offline
Old 11-01-2009, 10:53 PM   #6
LR4
Re: Cab Resonance!!
extend those turndowns past the rear axle and that will help. Swapping that flowmaster will really help. I have longtubes, no cats and slp loudmouths with no drone, dumped just over the rear axle.
Outlawz2004 is offline
Old 11-01-2009, 11:28 PM   #7
Re: Cab Resonance!!
I have Hooker LT, Dynomax race bullets, exits in front of rear right tire, no drone.
1990 Chevy C1500 Cheyenne RCSB; 355 TBI/700R4 transmission Hooker LT headers/H-pipe/Dynomax Race Bullet mufflers. 16146299 AWLD ECM
Join My Mafia: http://apps.facebook.com/inthemafia/...00000157357507
Chris_Harper is offline
Old 11-01-2009, 11:39 PM   #8
DUH! Big Red Truck!
GreaseDog's Avatar
Re: Cab Resonance!!
i've got 2 of 3, and no drone. put a tailpipe on it.
GreaseDog is offline
Old 11-03-2009, 05:37 PM   #9
Jimmy_D's Avatar
Re: Cab Resonance!!
ill try the tailpipes. its a si/do.. i wonder if i can run a single pipe back and then have the muffler and turndowns?.. easier to run one pipe then two and the turn downs are already on it
Jimmy_D is offline
Old 11-03-2009, 05:40 PM   #10
Jimmy_D's Avatar
Re: Cab Resonance!!
straight pipes might have less drone lol... geees its bad
Jimmy_D is offline
Old 11-03-2009, 05:41 PM   #11
F4MOU$'s Avatar
Re: Cab Resonance!!
If you don't want drone in your truck, put your cats back on and ditch the blowmasters
♠ Dumped Magnaflow ♠ Rough Country 3" ♠ 33 x 12.50 Cooper STT's ♠ Blackbear ♠ K&N ♠ Keystone Hood ♠ Carriage Works Grille ♠ Painted Handles ♠ 6000K HID's ♠ 35% Tint ♠ 17x9 XD Hoss's ♠ Bedrug ♠ Smoked Tails ♠
F4MOU$ is offline
Old 11-03-2009, 06:16 PM   #12
Re: Cab Resonance!!
I happen to have the same problem. Can someone point out the cheapest way to fix it....add cats or get new Delta Flow 50 series? Cats are about $50 each and Flowmaster are $97. I'd really hate to put new mufflers on it and still have the drone. Delta flow 50 series is supposed to be quiet but I'd rather get the info from you guys than spend the dough for nothing.
1993 Chevy 5.7 tbi Z71, vortec heads, GMPP tbi vortec intake, 2" TBI and intake, TBI spacer, Comp Cams 08-409-8 XTREME 4x4 roller cam conversion, S10 stall, Hedman full length headers, true duals, 3" body lift, 33" tires, Paxton Performance tune (aka 94Blazer383), 4.10's, Hypertech powercharger.
93ChevyTBI is offline
Old 11-03-2009, 06:37 PM   #13
94_c/1500's Avatar
Re: Cab Resonance!!
Flowmaster 50s are quiter than 40s.
If you get a good high flow cat, the noise level really won't go down.
Old 11-03-2009, 08:21 PM   #14
Tweaks's Avatar
Re: Cab Resonance!!
Get anything other than flowmaster and you're probably heading in the right direction. How loud or quiet isn't as important as the muffler's ability to cancel out the really low frequencies that create the drone.
Wish List: E-fans
Tweaks is offline
Old 11-04-2009, 08:48 AM   #15
Re: Cab Resonance!!
I don't have a problem with noise with my flowmaster super 44s. put some tailpipes on it and you'll be fine.
96gmctruck is offline
Old 11-04-2009, 09:07 AM   #16
Forum Leader
oneloudz71's Avatar
Re: Cab Resonance!!
The further back you can move the muffler and the turn downs the less drone you will have.
Here is an example. I have a crew cab with a cat back magnaflow system that exits before the rear tire. I have quite a bit of cab drone. I have a customer with the same truck that has a magnaflow cat back system with the same muffler and his exits out the rear, no drone. The reason I have so much drone is my muffler sits right under the rear of the cab, his sit under the front of the box out from under the cab. Also mine exits 3+ feet closer to the cab than his. Like I said, same exact muffler, same exact trucks, different muffler location and exit, night and day difference in cab drone.
Like to photoshop? Check this out...http://www.fullsizechevy.com/forums/...k-contest.html
oneloudz71 is offline
Old 11-04-2009, 02:58 PM   #17
94_c/1500's Avatar
Re: Cab Resonance!!
Like it was mentioned before, tailpipes.
My old shop teacher had a 5.7 Hemi with a Flowmaster 50 and no drone.
Old 11-04-2009, 03:01 PM   #18
Forum Leader
oneloudz71's Avatar
Re: Cab Resonance!!
Ok...What does the Hemi and your shop teacher have to do with anything?
Old 11-04-2009, 03:08 PM   #19
94_c/1500's Avatar
Re: Cab Resonance!!
Stating it has a 50 and no drone.
Old 11-04-2009, 03:10 PM   #20
Forum Leader
oneloudz71's Avatar
Re: Cab Resonance!!
Ahhh. Yeah, not every vehicle with each setup will have drone.
