Old 11-03-2009, 02:51 PM   #1
ZONKED's Avatar
2000 4.8 lt header question
i am looking into getting a set of long tube headers for my 2000 silverado with a 4.8... they have one flange on the passenger side for egr however i have air injection and egr on passenger side and a flange on the driver side too is the air injection needed i heard i can block it off or should i add the extra flanges to the headers myself .. i have a machine shop so that would be easy thanks for the help in advance
ZONKED is offline
Old 11-03-2009, 03:21 PM   #2
--Tyler--
Underpowered's Avatar
Re: 2000 4.8 lt header question
you are in CA, they have all that stupid crap on their trucks out there.
those appear to be OBX headers. had mine for over a year, so far so good.
as to your question, i really can't answer it as i have never had to deal with the AIR system on any vehicle.
2003 Z71 slightly modded.
^^courtesy of xZoomerZx
Underpowered is offline
Old 11-03-2009, 03:40 PM   #3
ZONKED's Avatar
yea and i believe they only put the air injection on 99 and 00 models i was told i could put on a block off plate but would need to get a tune ..
i'm not worried about it passing smog cause it wont with these headers i just want it to run correctly without setting off my check engine light
ZONKED is offline
Old 11-03-2009, 03:53 PM   #4
--Tyler--
you will need to have a tune for sure. have to have the rear O2 sensors tuned out for sure
Old 11-03-2009, 07:57 PM   #5
ZONKED's Avatar
i dont understand why i have to have the rear 02's tuned out aren't there cats in the above picture
ZONKED is offline
Old 11-03-2009, 08:01 PM   #6
KTMRACER's Avatar
They're dummy cats, they will pass the visual inspection, but not the sniffer test
Originally Posted by TheMaroonBaboon
because this thread like an OBS will never die
2003 GMC Sierra 1500 2wd, 5.3L, 3.73 gears with locker RCSB
Stock 98 C1500 RCLB Vortec 305
KTMRACER is offline
Old 11-03-2009, 08:04 PM   #7
ZONKED's Avatar
ok thanks that makes sense now
2000 silverado 4.8L, cst long travel kit in the front with king coilovers, deaver leaf springs with fox shocks in the back
ZONKED is offline
Old 11-04-2009, 07:49 PM   #8
ZONKED's Avatar
after looking further into this i think since i need a tune anyways i may just remove the air injection rather than cut and weld the air injection flanges on a new set of headers
ZONKED is offline
Old 11-10-2009, 12:43 PM   #9
1CLNY2K's Avatar
You can remove the EGR by buying the block off plate from the dealer or gmpartsdirect.com. The part number is 12558346. Just have a tune made to cancel the EGR, AIR injection, and the rear O2 sensors.
2000 ECSB, 4.8 5 speed NV3500, man t-case,tru-trac, W4M tune. 3/4 drop brought to you by Belltech, 285/55/18 coopers on matte black titans. Maybe working on a 4/6 drop
1CLNY2K is offline
