Old 11-03-2009, 09:59 PM   #1
formerly afitx84
daemanisameanman's Avatar
Jingle between cat and headers
When I start my truck, or just at idle, a jingle sound comes from the area near the cat. Nothing is loose, all is tight as can be... but i just cannot understand why it sounds like this. Took off entire cat back and it still continued.
Any suggestions?
2000 Z71, 6" Procomp Full Drop, Cooper STT Discoverer 35x12.50, Mickey Thompson Classic II 16x10, Rear Leaf Pack, keys,
daemanisameanman is offline
Old 11-03-2009, 10:02 PM   #2
sw45's Avatar
Re: Jingle between cat and headers
sub'd. Ive got this jingle as well. Truck in sig.
98 rclb silverado z71,121k miles, dual 25" thrush glasspacks, 5.7l Vortec, cobra 29 CB, rebuilt 4l60e at 118k miles-(2000 stall converter, shift kit, vette servo, heavy duty clutches), mastercraft 265/75/16 Courser C/T's, JVC KD-300 Hu, MB Quart 12 400rms, hitron HA-1000.1 amp 600rms @ 2ohms
sw45 is offline
Old 11-03-2009, 10:08 PM   #3
--Tyler--
Underpowered's Avatar
my best guess is your cat itself.
this is a sign your cat is going bad. min had a jingle/rattle for a month or so before it clogged up and the truck would not even run.
but to be safe, look at your collectors, make sure they are still in tack, i have seen some of them break a bolt or two and cause a jingle as well
2003 Z71 slightly modded.
^^courtesy of xZoomerZx
Underpowered is offline
Old 11-04-2009, 08:44 AM   #4
Turn and Burn
header tick? mine ticks from the LT's. they all do.
Thanks xZoomerZx
1995 GMC 4x4, 350, w/A/T's,3.73's,Debaged, Heddman LT's w/ Thunderbolt cat and Thrush muffler, TB & Inj. spacer, Big 3 Upgrade, Ultimate TBI mods, AFPR, U D pulleys
5200 lbs. at 14.0MPG
1988 GMC SOLD
1988 GMC 355 is offline
Old 11-04-2009, 03:03 PM   #5
Tweaks's Avatar
When the exhaust is cold, crawl under and pound the cats with your hand. I bet your driver side cat will replicate the sound. A friend of mine who has a 99 NBS with the 5.3 rattles at idle and it's coming from the driver side cat. Mine doesn't rattle at idle, but I can replicate the sound you describe by hitting the exhaust in that area with my hand. It's the internal brick of the cat that is rattling in there and it's a non-issue until either a check engine light comes on with a code indicating that a cat is bad, or a portion of the cat's internal brick becomes detached and lodges itself sideways in there and prevents flow. If that happens, you will know because your symptoms will be similar to what Underpowered mentioned in his reply.
00 RCSB Z71 / ss Spintech exhaust / Z71 Tahoe valance / EBC slotted&drilled brake rotors / Edelbrock headers / Blackbear tune/ 6000k HID low beam and fog lamps / Auto-headlight mod(nice)/ Vette servo
Wish List: E-fans
My allergies to these fans... has returned-Slapshot
Tweaks is offline
Old 11-04-2009, 03:08 PM   #6
has been "had"
bhookxen's Avatar
+1 on it being the cat itself. seems they like to break down inside of themselves, thus hearing the rattling noises.
- i'm new
<-thanks again, xZoomerZx
96' burb - 6-inch RC, 4.56's, 35's, detroit, SYE, realift, flow 50's, w4m, 06' 17's, other stuff
98' silvy - z71, 285's, flow 50's, 1" block, some crank, blackbear
bhookxen is offline
Old 11-04-2009, 07:47 PM   #7
88Vic's Avatar
It seems that the stock cats on these trucks aren't very good quality. Mine has already broken up and was shooting out pieces when I got it so I put a pipe in it's place which got rid of the clunking sound and not to mention made me finally hear the 24" Magnaflow.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
Custom open air cleaner
88Vic is offline
Old 11-05-2009, 06:55 PM   #8
formerly afitx84
no check engine light. It isn't a crazy loud sound, most of my friends dont pay attention to it unless i point it out, and only happens when i let off the gas or have it at idle.
Also, when I drive around town for a while and park to go in somewhere, while the engine is still warm, the noise goes away when i start it back up again.
Old 11-05-2009, 07:07 PM   #9
I had the same problem on my 99 NBS. It turned out to be a flange ear (or something like that) that holds the exhaust system on was loose and I had both of them replaced and it went away.
OR
The honeycomb inside your cat has come loose or broke?
99 Chevy 1500 z71
6" Suspension Lift
37x13.50 Nitto Mud Grapplers on 20x9 Pro Comp Xtreme Alloys
5% Tint stacked all around
2.5" Ford Keys
Straight Pipes X-pipe true duals 45 out 45 dumped
More to come...
BAP56049 is offline
Old 11-05-2009, 09:34 PM   #10
I had the same issue on a 03 Avalanche with the 5.3L. Took it to the dealer, and something had come loose in the cat itself. They had to replace the cat (under warranty, thank goodness!) and that took care of it.
Mr. Orange 645 is offline
Old 11-05-2009, 09:54 PM   #11
NBS Owner
IwannaSS's Avatar
yep sounds like the cat to me. my obs made a rattle sound and it ended up bein the cat. had that sucker cut out!
2002 Chevy C1500 ECSB, 5.3L, White, Tint, 2" Springtech Spacers, 265 Hankooks on 18" Gunners, Cherry Bomb Extreme, Infinity Reference Components, JL Audio subs, a little colormatching, Eskys, and a speed grille
IwannaSS is offline
Old 11-06-2009, 12:21 AM   #12
formerly afitx84
oh boy, just what i want to hear when im trying to sell it.
thanks for the help guys
Old 11-06-2009, 07:55 AM   #13
Take a look at the little metal collars on the o2 sensors.miNe does it too.
Drivin' Chevys and Ridin' Harleys!!
DUALLS is offline
