Old 11-04-2009, 05:24 PM   #1
Flowmasters
Flowmasters website says that their mufflers can increase gas milage my 1-2 mpg. Is it true??? Im lookin to put a true dual super 44 cat-back on my 99 1500 5.3 V8
Zbec is offline
Old 11-04-2009, 06:04 PM   #2
94_c/1500's Avatar
Re: Flowmasters
On my V6, I got 1 mpg better going with true duals and Flowmasters.
My dad had a '97 with a 350 and got 3 mpg better.
1994 GMC Sierra, 1982 Jeep Scrambler, 1975 Jeep J10
Drive a pickup truck, trustin' God and luck
http://www.fullsizechevy.com/forums/...my-trucks.html
94_c/1500 is offline
Old 11-04-2009, 06:31 PM   #3
KTMRACER's Avatar
Re: Flowmasters
IIRC most people claim better mileage with magnaflows moreso than flowmasters. I have heard from some people that flows decreased their mileage slightly on a single pipe system, magnaflow was the opposite.
Originally Posted by TheMaroonBaboon
because this thread like an OBS will never die
2003 GMC Sierra 1500 2wd, 5.3L, 3.73 gears with locker RCSB
Stock 98 C1500 RCLB Vortec 305
KTMRACER is offline
Old 11-04-2009, 07:00 PM   #4
Re: Flowmasters
Ok, i just dont wanna have a huge decrease of like 2 mph or over that
Zbec is offline
Old 11-04-2009, 08:07 PM   #5
94_c/1500's Avatar
Re: Flowmasters
You should never loose mpgs by reducing backpressure.
Old 11-04-2009, 08:44 PM   #6
88Vic's Avatar
Re: Flowmasters
You won't lose any with a Flowmaster, you'll just gain more with a Magnaflow.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
Custom open air cleaner
88Vic is offline
Old 11-04-2009, 08:45 PM   #7
94_c/1500's Avatar
Re: Flowmasters
Dyno results?
Old 11-04-2009, 08:48 PM   #8
crossy's son's Avatar
Re: Flowmasters
no dyno results needed...
vs.
91 RCSB|350|5 speed|3.42 G80|400k miles+|stock...15.67 @84
^ 89k 350,tbimods,Spacers,headers,Southbend clutch,AFPR...soon to be dropped in.:)
Dad's-87 SWB 2wd|305tbi
stuff-4 cummins powered dodge rams
& 81 C10 swb 13.54-1/4 ET,5/8 drop
94 K1500 ECSB 4x4,5.0L,4L60E,3.73's,Magnaflow
crossy's son is offline
Old 11-04-2009, 08:50 PM   #9
88Vic's Avatar
Re: Flowmasters
Since when is fuel economy measured on a dyno?
Magnaflows put out better CFM numbers in flow tests, therefore flowing more and decreasing restrictions which in turn will increase exhaust velocity, increasing torque meaning less throttle needed to move the truck. Therefore, Magnaflow is better for economy.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
88Vic is offline
Old 11-04-2009, 09:10 PM   #10
94_c/1500's Avatar
Re: Flowmasters
You are comparing an x muffler to a single in/out. The muffler you are showing is a glasspack.
Old 11-04-2009, 09:11 PM   #11
94_c/1500's Avatar
Re: Flowmasters
How much cfm does it take to change 1 hp? 1 ft-lbs, or 1 mpg?
Old 11-04-2009, 09:13 PM   #12
Re: Flowmasters
thats the way all magnaflow mufflers are made..
if you think its a glasspack then type in "magnaflow cutaway" on google image search and you see what comes up...
Old 11-04-2009, 09:15 PM   #13
94_c/1500's Avatar
Re: Flowmasters
I didn't google it, but if it is not fiberglass then it is stainless. It still has the same design as a glasspack. Perforated tubing
Old 11-04-2009, 09:18 PM   #14
94_c/1500's Avatar
Re: Flowmasters
No X pipes in these mufflers. http://www.magnaflow.com/02product/u...asp?shape=oval
If you want the best MPGs for your 5.3 by changing your exhaust and use Flowmasters, use Super 44s. They are supposed to be better than 40s. Not sure, I haven't bought mine yet to see how they do. Also, thunderbolt cats work great. You might want to get an x-pipe or an h-pipe. The x-pipe is the better choice. If your plans for the truck are to keep it mostly stock, use 2 1/4 dual pipes.
Old 11-04-2009, 09:20 PM   #15
88Vic's Avatar
Re: Flowmasters
The difference being glasspacks generally use louvers, not perforated tubing. The packing in a Magnaflow will slightly distort within the first few hundred miles but after that it muffles the sound greatly and produces a very deep and toned rumble, much unlike the popping and snapping of standard glasspacks. Also perforated tubes flow better than louvers as they don't create as much turbulance.
And where on that page does it say the dual in dual out mufflers don't have x-pipes inside?
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
88Vic is offline
Old 11-04-2009, 09:24 PM   #16
Re: Flowmasters
you seriously don't think thats a magnaflow
Its called...Dual in/dual out... its designed to do all the crossing inside so you don't have to run a Xpipe/Hpipe when running true duals. MAGNAFLOW takes care of that for you inside their mufflers !!!
Old 11-04-2009, 09:29 PM   #17
94_c/1500's Avatar
Re: Flowmasters
I am not saying it is not a Magnaflow. I am saying not all Magnaflows are made that way. Lets get back on topic.
Old 11-04-2009, 09:56 PM   #18
88Vic's Avatar
Re: Flowmasters
That's not an issue, any of the Performance model Magnaflows are straight through, and it;s a much better design than a louvered asspack.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
88Vic is offline
Old 11-04-2009, 10:13 PM   #19
Re: Flowmasters
how are flow masters on a 6.0?
jbreshears is offline
Old 11-04-2009, 10:17 PM   #20
Re: Flowmasters
Alright soo does dual 44s with an x pipe sound good? Im not really lookin to increase even tho itd be nice mostly i just dont wanna decrease
Zbec is offline
