11-04-2009, 11:38 PM
magnaflow set-up??
okay so im ordering mu magnaflows Friday, have one question i have quad tips out the back right not but what would the sound difference be between running true duels 2 tips versus this??
11-05-2009, 08:15 AM
#2
Re: magnaflow set-up??
not much, mufflers,cats, resinators,pipe diameter and cross pipes will change sound, as far as the tip it all sounds the same, mostly just for looks.
  SLAMMED
11-05-2009, 08:23 AM
#3
Forum Leader
What are the size of the 4 tips, diameter and length?
What are teh size of teh 2 tips, diameter and lenght?
There wont be a big difference but if the 4 tips are alot smaller than the 2 tips, you would notice a tone difference.
11-05-2009, 05:37 PM
#4
Ill be running RBP 4" to 5"x12" double wall black tips, my questions will running duel SI/DO with 4 tips sound cooler then running duel SI/SO with only two tips or will it just be for looks??
11-05-2009, 06:55 PM
#5
I say get rid of the H-pipe.
And just run a DI/DO magnaflow muffler, (does all crossing inside)
and run tailpipes back off the muffler. would save $$$$ and be easier.
91 RCSB|350|5 speed|3.42 G80|400k miles+|stock...15.67 @84
^ 89k 350,tbimods,Spacers,headers,Southbend clutch,AFPR...soon to be dropped in.:)
Dad's-87 SWB 2wd|305tbi
stuff-4 cummins powered dodge rams
& 81 C10 swb 13.54-1/4 ET,5/8 drop
94 K1500 ECSB 4x4,5.0L,4L60E,3.73's,Magnaflow
11-06-2009, 08:49 PM
#6
I already ordered my 2 SI/DO 4x9-18" oval magnaflows so Im gonna give it a shot and when the time comes redo it when i've ordered everything for the truck :)
11-07-2009, 08:14 AM
#7
What truck is this for?
Isnt your gas tank going to be in the way of the drivers side pipe?
I like the idea, thats what I'm going to do when I build mine but will use si/so magnaflows.
99 Tahoe 2dr 2wd 5.7 Vortec, FLT lvlV, Yank, TruTrac, K&N fipk
11-09-2009, 12:37 AM
#8
haha its a 96 burban thats im building right now into a CCSB prerunner, but nah it has a center mounted 40gal tank behind the receiver, Okay I've been thinking will running duel SI/DO magnaflows having four tail pipes with four tips ruin the sound or will it not make a difference or will it make it sound better??
11-09-2009, 09:17 AM
#9
Forum Leader
Are you running 4" pipe? That is overkill to say the least! Is it just 4' out of the muffler?
11-09-2009, 09:18 AM
#10
Forum Leader
You wont have much of a sound difference between 2 and 4 tips on an exhaust system that is that open (4" pipe).
11-09-2009, 11:13 PM
#11
haha no its all 2.5" just the tips will be RBP 4" to 5"x12" double wall black tips
11-10-2009, 04:59 PM
#12
I have 24" long tips that make the tone a lot deeper, more rumble. Shorter tips aren't quite as deep, 18" is the shortest I would use but I love my 24"ers. I don't think 4 short tips will be as deep as 2 long tips, but give it a try if you want.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
Custom open air cleaner
11-10-2009, 07:27 PM
#13
thanks 88vic that makes since man, so RBP make both a 4" to 5"x12" tip and a 4" to 5"x18" tip, so your saying the 18" would make the tone deeper and a more ground shaking rumble
11-11-2009, 07:11 PM
#14
I think it would, not a huge difference but noticeable. What's really noticable is a long tip versus a short one. When I cut off my tailpipes I had 3"x6" tips coming off the muffler, not deep like my 3.5"x24" tips I have now. The short tips are really just to look good instead of the piping just cutoff.
95 Sierra C1500
TBI 305, NV3500
10-Bolt 3.42 Open
| Thread Tools |
| Display Modes |
Linear Mode
