Old 05-24-2008, 03:48 PM   #81
94383Z71
Member ID: 65782
Re: Rebuilding a Salvage Crew Cab Dmax 4by
Originally Posted by White_Stealth
agreed.
You have taken your time and it really shows. Body work looks awesome. Now hurry up and finish that cab.
Thanks everyone, for the kind words, especially White_Stealth, it means alot coming from someone with your talents. Working on finish blocking the cab(with 600), I have a couple of small issues (door dings)to deal with on it, nothing big left.
I will have two more paint sessions, one for the cab, and another for the hood, lower bumper cover and plastic stuff.
How does tinting the tailights work?, wetsand with 800, light coat of base, then clear?
1994 ECSB Z71 (Black / Gray int.)
GMPP 383HT crate motor.
GMPP TBI to Vortec intake bored to 51mm.
7.4L TBI and fuel pump.( Ben Riggs chip)
Built 4L65E deep pan, with temp gauge.
1999 Cadillac Escalade
5.7L Vortec, (383 in the future)
Old 05-24-2008, 04:32 PM   #82
BuiltOilPatchTough
Formerly RonDog
BuiltOilPatchTough's Avatar
Member ID: 77333
Just came across this build, looks amazing what you've done, box looks awesome, nice finish on that. So are you just spraying outside in open air, or in a shop or what? I'm thinking about doing bodywork and painting my old '91 sierra too, we got a "paintbooth" in our shop, plastic walls we can let down and fans in the walls. Or it's just gonna happen outside when there's no wind.
About smoking your taillights, mix some black basecoat with clearcoat in your gun, spray that on the taillight, add coats untill your happy with the darkness, then a couple clearcoats and you're done. Gonna do mine too on my 2003
2003 GMC Sierra 1500HD SLT 4x4 | DC-1 Wheels wrapped in Toyo A/T | LevelKit + 2" Blocks | Aries Bullbar | Vert. Billet Grille | Black Bear PCM Tune | 2 Kicker CVT's
1991 GMC C2500 ECSB "Low An' Easy" Bagging Project
Old 05-24-2008, 07:11 PM   #83
94383Z71
Member ID: 65782
I have a garage/shop in the back that I work in, no paint booth. I hang plastic sheating, from Home Depot, over most everything that I don't want overspray to settle on. Then I put a box fan in the window(blowing out), seal it in as best I can, wet the floor down with a hose to keep the dust down. I have a back room addition that housing that the compressor, so its not kicking on and stirring up dust.
If you saw the finish in person, you can see some dirt specks in it, I wet sanded them with 2000 before wheeling it out.
Thanks for the advise about shading the tail lights.
Old 05-25-2008, 09:31 AM   #84
kev2809
Member ID: 79594
great work man, its coming along pretty good. so out in the light did those "areas" you had problems with show up?
Old 05-25-2008, 10:34 AM   #85
Chevyman247
Obama = Bill Ayers!!!
Chevyman247's Avatar
Member ID: 67976
subscribed!
91' Chevy 1500, 9" total lift with 38.5" Ground Hawgs, Dual Super 44 Flows, Carbed 357 Magnum
"Estmated Power at crank-300hp and 400 Torque"
Old 05-25-2008, 06:38 PM   #86
94383Z71
Member ID: 65782
I can't see them, and I keep looking real close.
Old 05-25-2008, 10:25 PM   #87
WildChevys
Premium Member #122
HEROES LIVE FOREVER
WildChevys's Avatar
Member ID: 27818
you have done an absolutely amazing job and have so much to be proud of here!
James
2008 Chevy Silverado LTZ Vortec Max w/6" Superlift
2005 Chevy Silverado Z71 w/6" Superlift FIT kit **SOLD**
2001 Chevy Camaro SS 12.44@107.92 **SOLD**
Old 06-03-2008, 01:09 PM   #88
94383Z71
Member ID: 65782
I hit the garage @ 8:30am yesterday, sprayed the last coat of clear @ 11:30pm. But the cab is all one color. I plan to do the hood, lower bumper cover and fender flares in one last paint session. Two issues with the cab;
1. Two small dings in the cab corner that was replaced, not sure how I missed them, but their there.
2. When peeling the masking tape off today, I accidentally peeled some paint off of the rocker, it went down to the previous coat of clear. Not sure what to do about it, when the camera battery finishes charging, I'll get some pics of it.
Till then, here's what I took before the battery died;
I'll have to decide what to do about the rocker, then break out the 2000 grit.
Old 06-03-2008, 01:26 PM   #89
MC
Less=More
MC's Avatar
Member ID: 82510
Shiny! Looks great as usual.
It's bound to be more fun than slide sex. Bare-ass going down a stainless slide = bad idea... Especially when the berries are hangin' low. Stuff gets caught up in the undercarraige, and you're not sure if it's gonna rip off, and everything's getting hot, and overheating.... -thekl0wn
Old 06-03-2008, 03:07 PM   #90
94383Z71
Member ID: 65782
Masking off, outside garage;
Now for where it peeled, not real sure what to do here. I guess I'll have to mask it off, wet-sand the rocker with 800 and re-clear the whole rocker. I don't know if it's possible to spot just that area in, or not.
Here's a link to the products I'm using, first the clear
http://www.matrixsystem.com/docs/tec...ch%20sheet.pdf
Then the base;
http://www.matrixsystem.com/docs/tec.../Paint/MPB.pdf
Old 06-06-2008, 04:55 PM   #91
Crazed179
Harley
Crazed179's Avatar
Member ID: 70676
wow.. hey where it peeled is that metal or primer underneath? primer needs somewhere around 180 for it to stick good. I'm sanding mine tomorrow with 800 before I paint it but I personally think its too fine.. guess I'll figure it out tomorrow.
but dude... after seeing my bed in primer for so long..to see that black on yours made my heart skip a beat. I'm too excited to sit here after seeing that. I can't wait man...that bed came out awesome though.
and don't be so hard on yourself about the body work and all..I mean it looks damn good, I still can't get over that bed. and I'm spraying my brake lights with the bed. screw 'em, if I can't see light coming through good, then I need to get some anyways.. cheap things trap moisture like crazy. pics up tomorrow of the bed. love the progress man keep it up
Old 06-06-2008, 05:05 PM   #92
F4MOU$
Professional A$$hole
F4MOU$'s Avatar
Member ID: 84471
simply amazing. the whole thing. awesome.
'08 ECSB Z71 5.3L
Corsa RSC Sport, K&N CAI, Keystone Hood, Gaylords X2000,
Readylift, Edge Evolution
Old 06-06-2008, 05:30 PM   #93
94383Z71
Member ID: 65782
Believe it or not, what your seeing under there is the previous clearcoat, wetsanded with 600. I was told 800 was too fine to provide proper adhesion. What your seeing on my bed is 600grit, base, clear, 2000grit, med compuond with a wool wheel, glaze with foam wheel.
Thanks for the supportive comments, its coming along.
Old 06-06-2008, 06:17 PM   #94
DarkCharisma
total smartass #1
DarkCharisma's Avatar
Member ID: 72673
All I have to say is, wow. It looks GREAT. I want to re-paint my truck so bad.
'00 ECSB 4x4 | Built 4L65e | 5.3 | 2% Tint (RIP 10/1/08) | K&N | Magnaflow | BFG | Wait4Me
Old 06-10-2008, 09:59 AM   #95
Bad Ass Z71
formerly shortbox
Bad Ass Z71's Avatar
Member ID: 48980
Awesome build to be following. Dunno why you're so hard, on yourself, about the bodywork though. Its looking really good.
SSSHHHHHHH! I'm on a secret mission!
Old 06-11-2008, 08:07 AM   #96
94383Z71
Member ID: 65782
Thanks for the compliments.
As far as being hard on myself, it comes from things like what I realized last night. I ran out of the 2000 grit paper, that I'm using before wheeling out. I went to a supply house that I found that was closer to my house. I tell the guy I need some 2000 grit wet/dry paper. He comes back with the ten sheets I asked for, it's from a different manufacturer than the previous stuff, and it's a different color, but hey it's 2000 grit.
I go home, finish wetsanding the cab. Right away I'm impressed with the new stuff, it cuts faster lasts longer etc. Then I break out the wheel, wool bonnet, medium cut compound. I start wheeling in the same sequence that I sanded in, left front fender first. I work over to the pass door, and notice some sand scratches not wheeling out. Well I must not have finished the prepaint blocking well enough.
Then I get to the pass rear door, it looks like crap after wheeling, sand scratches everywhere. I soon realizze that this was the first panel that I used the new paper on, I jump to the next panel, same thing, looks like ****.
I do some research on the paper I bought, my original paper was 3m imperial(sp?). The new stuff is Rynowet and instead of saying 2000 on it, it say's P2000. Well after my wife does the internet research, there is a conversion chart for the "P" paper to the "old" style. It seems that a P2000, is really like a 1000 grit in a 3m rateing. So now I've sanded the cab in 1000 grit, I have to go back over it with 2000. Will I cut through the clear? Thats the question that kept me up all night, last night.
http://en.wikipedia.org/wiki/Sandpaper
Live and learn, school of hard knocks.
Old 06-11-2008, 12:43 PM   #97
blh
blh's Avatar
Member ID: 62666
You are doing a fantastic job. It's guy like you who have the balls to undertake a job like that that inspire guys like me to say Hey I can try it too.
"Beer is living proof that God loves us and wants us to be happy"- Benjamin Franklin
Old 06-11-2008, 12:48 PM   #98
Chevyman247
Member ID: 67976
Dont let this get you down! You will make it. Everything that can break, can be fixed.
Old 06-11-2008, 02:01 PM   #99
Beyond Static©
Xcentric Customs
Beyond Static©'s Avatar
Member ID: 7315
Originally Posted by 94383Z71
As Will I cut through the clear? Thats the question that kept me up all night, last night.
Only one way to find out.....lol. You shouldn't remove much material going from 1000 to 2000. Start down low on a panel, and test it out first. Just be careful on your edges.
Old 06-11-2008, 07:41 PM   #100
Crazed179
Harley
Crazed179's Avatar
Member ID: 70676
well hey, I get to repaint the whole left side of my bed if that makes you feel any better, all cause of one demonic run. there was solvent pop all in it...had to sand down to the base coat for it to finally get out, now I gotta prime it and spray it again!
how many coats of clear did you put? I think 3/4 coats and you'll be alright. I put 4-5ish on mine in order to block it out with 1500, 2000, then finish with 3 and buff. I think I might try that later down the road though cause I'm more concerned with the cab..
we'll be adding two to the unofficial black thread soon!
