#41 |
lay'n hard
Member ID: 72841
Re: Boz's Nbs Ecsb Frame Laying Build
hey man its lookin awesome...im doing the exact same thing right now. i got my 6 link in and now im startin on the kp notch. i got a couple questions..did u end up cuttin that top part of the notch because mine looks to big when i set it on top of the sides? and why did u make the notch so high and not cut it down??
03 silverado, layin frame, kp 6-link, mcgaughy spindles, slam re7's, 5 gallon, 2 480's, devious gas tank, 3/8 smc valves, 1/2 line, raised tranny crossmember and y pipe
DROP & DESTROY ______||_\\___ |_( )_|____( )_| GROUND UP |
#42 |
Car Audio Junkie for 22yr
Member ID: 79372
Are you talking about height or width of the cap. I trimmed the ends some to get it to sit down on the side plate! I left it tall because we may go to a 22 at some point. I really don't think it is much over notched anyway. We also drilled a hole and welded a nut on the inside of the bottom cap to be able to run a bump stop! When you dump it its about 3 inches from the notch and we are just now raising the tank. As far as width of the top plate I would let it over hang the side about 1/4 inch to give you something to weld to. I didn't do that on the top plate but did on the bottom.
Hope this helps let me know if I can help on anything else.
Kevin Tolliver
67 SWB Drag Truck Best 1/8 5.78 Best 1/4 9.16 Car Stereo Guy Mobile Disc Jockey Drag Racer |
#43 |
Member ID: 79372
We had a pretty good weekend of workin on the truck!
We wanted to tie the notch together before we cut out the crossmembers. ![]() ![]() Preping to mount the tanks. ![]() We cut a single set of bracket like a few before us. Those brackets are major overkill! ![]() ![]() ![]() ![]() ![]() ![]() ![]() We cut the cab to roll it under for a little more tank clearance! ![]() Starting to raise the tank. ![]() Cleaned up the frame where the rear tank mount was! ![]() ![]()
Kevin Tolliver
#44 |
lay'n hard
Member ID: 72841
im talkin about the top pieces width...did u have to trim that down at all? cause i think i got like half inch or so that hangs over? by the way i like ur notch cross section did u buy that or make it?
#45 |
Member ID: 79372
I did trim that down flush but if I had it to do over I would leave about 1/4 inch on each side just to give you more to weld to.
The bars on the notch I had made at the local race car chassis shop.
Kevin Tolliver
#46 |
Project started
Member ID: 68024
Turned out awesome. Good job.
![]() 2007 Silverado Classic, KP 6-link, KP watts link, Slam bags, Belltech Spindles, EDC, 10 gallons of air, 3/8" SMC valves, 1/2" DOT line, 22" Boss 315 +40 offset wrapped in 265/40/22 |
#47 |
Member ID: 79372
Thanks for the props guys!
Kevin Tolliver
#48 |
Member ID: 81725
looking good dude
#49 |
OBS FREAK
Member ID: 18959
WOW nice clean bag job, nice setup!
92 Chevy Silverado Z71 - daily driver - cutout flares 6.5" DC, 3" BL, 38.5/15.00/15 BOGGERs.
91 GMC black RCSB 2wd bagged -might be for sale, looking for a OBS Prostreet truck. TRADE?
#50 |
Member ID: 79372
thanks!
Now its time for check valves and lots of plumbing. Have any of you had problems with the water seperator that comes with the Airlift EDC?
Kevin Tolliver
#51 |
Member ID: 79372
making a little more progress!
Here's the tanks with some cool drain valves. They have cables that will be routed to the rear you will just pull each cable to drain each tank! ![]() here's the engine driven mounted ![]() Here's how tight the pulley is to the ecm computer even after we moved it forward an inch. ![]() Got a little plumbing done for the rear! We are gonna redo the inputs to the valves the lines are so short we will probably use a braided hose! ![]() ![]() ![]() We are going to the world of wheels today so no more progress this weekend!
Kevin Tolliver
67 SWB Drag Truck Best 1/8 5.78 Best 1/4 9.16 Car Stereo Guy Mobile Disc Jockey Drag Racer Last edited by djracer : 02-10-2008 at 09:13 AM. |
#52 |
warranty killer...
Member ID: 62969
Nice work Kevin.You guys are goin all out for this one!All the work looks super clean.Good Luck w/the wheel shopping.
#53 |
Member ID: 82091
Man, thats alot of fittings and adapters. Cant wait to do mine.
Jeff
99 3/4 Static
84 Regal 3" Ground Clearance |
#54 |
Member ID: 82959
looks good. somebody? has been working
#55 |
Member ID: 70396
What you talkin bout Willis!
Laying Frame....I just wanna lay down! Last edited by onetonk5 : 02-11-2008 at 06:59 PM. |
#56 |
Member ID: 79372
got some sexy patch cables and a distro block for the wiring. You got to love free samples.
![]() I think I got some of the edc plumbing figured out. ![]() ![]() ![]() Got some sexy needle valves for dump Control ![]() ![]() replumbed the inputs to rear valves ![]() Anybody know what this is it came with the airlift edc? ![]()
Kevin Tolliver
67 SWB Drag Truck Best 1/8 5.78 Best 1/4 9.16 Car Stereo Guy Mobile Disc Jockey Drag Racer Last edited by djracer : 02-14-2008 at 05:24 PM. |
#57 |
Premium Member #69
I have a mexican truck
Member ID: 47427
![]() I think thats for the iron cross to bolt the assemble to the firewall. ![]() http://www.cardomain.com/ride/2208434 "When you change the way you look at things, the things you look at change" |
#58 |
Member ID: 79372
I kinda thought that but it seems a little gay!
Kevin Tolliver
67 SWB Drag Truck Best 1/8 5.78 Best 1/4 9.16 Car Stereo Guy Mobile Disc Jockey Drag Racer Last edited by djracer : 02-15-2008 at 08:58 AM. |
#59 |
Member ID: 79372
Well here is the final design of the Edc plumbing with the Square D pressure switch/unloader. We eliminated several pieces and did a little tap work!
![]() ![]() ![]() Mounted to the passenger side firewall. ![]() ![]() ![]() Here's a few pics for those that say we are crazy over notched! Keep in mind we are only on a 20 for now. ![]() ![]() ![]() ![]()
Kevin Tolliver
#60 |
warranty killer...
Member ID: 62969
Are you going to run a rubberband tire in the front?I noticed you still have all the inner fenders,fuse box,air box,rad.fill tank.I had multiple contact points w/my nbs and its only a 3/5 drop.
