Old 03-18-2008, 03:06 PM   #1
Murf
Member ID: 49246
OBS CC longbed to Shortbed conversion Info
I was considering converting an OBS long bed crew cab to short bed. I have seen this done on OOBS Chevy's with good results. But the OBS has alot more curves in the frame at that area. I realize I will have to modify the drive shaft and use a shortbed gas tank and brake lines and all that stuff. In 99 and 2000 these trucks were available in this configuation but finding a frame has yielded nothing and the trucks are still going for more than I am willing to spend for a clean one. This is a 4x4. If anyone has done this or know of anyone or have a link or info to it I would much appreciate it. My search's have not turned up much.
Old 08-09-2008, 05:16 PM   #2
omar2guy
Member ID: 92973
Re: OBS CC longbed to Shortbed conversion Info
im in the same boat as u are but cant seem to find any info on here
Old 08-09-2008, 06:15 PM   #3
Blue Bowtie
Blue Bowtie's Avatar
Member ID: 91772
I saw a website where somebody did this, but I can't remember what the site was, off the top of my head, but I think I can probly find it again.
Old 08-10-2008, 01:24 AM   #4
DRAGGIN95
Premium Member #83
DRAGGIN CREW CAB
DRAGGIN95's Avatar
Member ID: 22845
Hello, its a different route, but you could take a 1/2 or 3/4 ton extended cab short bed frame, and add 13 inches in between the middle and back set of cab mounts. The cab mounts are the same height for ext. cab and crew cab, the only difference is the middle cab mounts are spaced a 1/2 inch further towards the outsides of the cab, you could recut your stockers, or if you have the skill to lengthen the frame, just build a new set of middle cab mounts. As for the driveshaft, you can use a stock ext. cab front half of the two piece driveshaft, including the carrier bearing and crossmember, in its stock location, but swap out the rear stock ext. cab shaft for a driveshaft out of RCSB, with a 700R4/4L60E, it fits right in without having to get a custom built driveshaft. Also using this method, you can use a stock 1/2 ton gas tank. All of the descibed method above works on 2WD automatic trucks with a 700R4/4L60E trans, I do not know about 4WD, obviously the driveshafts would have to be different, but the rest I am not sure. Good luck with your projects!
If you do what you have always done, expect to get what you have always gotten!
Old 08-10-2008, 04:51 PM   #5
omar2guy
Member ID: 92973
but as far as using the stock crew cab lwb frame and just shortnin it which i think sounds pretty easy to do nobody know the lentgh to cut the frame behind the cab and at the end of the frame, how did u do it draggin95
Old 08-10-2008, 05:24 PM   #6
DRAGGIN95
Premium Member #83
DRAGGIN CREW CAB
DRAGGIN95's Avatar
Member ID: 22845
Sorry man I don't know about shortening a LWB frame, as far as what I did, I stretched an ext. cab frame. Take it easy
Old 08-10-2008, 08:54 PM   #7
omar2guy
Member ID: 92973
do u have any pics of ur setup?
Old 08-13-2008, 06:44 PM   #8
omar2guy
Member ID: 92973
would this be the same for a obs crew cab? http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Old 11-08-2008, 05:14 PM   #9
wildmanaaron
Member ID: 3386
Anybody find anything on the 88-Up trucks specifically?
1981 Blazer K5 2WD w/Full Convertible Top- Just complete LS-1/4L60E Swap
