#1 |
Member ID: 82239
Project replacement
My shop/show truck got total a week before paint so I figured i'd try a fullsize. her are some picks so far.
#2 |
rattle-can that beash!
Member ID: 84362
Re: Project replacement
looks good man, love that color..keep us updated.
![]() 1992 5.7/700r4 RCSB Silverado 180k+ 2/3 drop with 275/55/20's
#3 |
Member ID: 82239
quick update
#4 |
Donations Accepted
Member ID: 7291
looks good! you must have a lot of fun with your pipe bender
#5 |
Member ID: 41849
looks like your bender kinks the tubing alot
65' GMC, BAGS, 6-SPEED, TBI, LOW AND SLOW
04" STi (sold) 05' GTO M6 (sold) Syclone #1060 |
#6 |
Member ID: 82239
doesn't really kink it, turns out where it holds the pipe while you bend it puts lil dents it. think i might just try thicker walled tubing.
#7 |
Member ID: 33760
are you using the HF bender? you should look into a pro tools 105 if you are gonna do allot of work with tubing.
#8 |
Premium Member #55
Satans on back of my neck
Status:
Online
Member ID: 2731
If you're using the pipe bender that's in the background that is your problem. It is made for bending pipe, you need a tubing bender. Pipe and tubing is two different things.
2" Pipe is measured by inner diameter, so the overall outer diameter is larger than 2". 2" Tubing has a overall diameter so the dies for a pipe bender do not support the walls of tubing because they are made for larger diameter pipe. |
#9 |
Member ID: 82239
it will work, just need to use thicker walled tubing. figured i would give the smaller stuff a try because its all my steel guy had left. shop down the street bends twice the amount i do and havn't had a problem with the same bender. the pro tools do look nice, like the 302, just need more money. hf bender was $80.
#10 |
Member ID: 82239
getting closer, only 10 days or so to finish it before Unite in FL.
#11 |
Member ID: 82239
almost there just need to take the cross bars off.
#12 |
Member ID: 82239
#13 |
King Of The Hill
Member ID: 21917
improper tools FTL
#14 |
Wuuuazuuup!!!
Member ID: 326
i like the rear suspension work, looks familiar! lol only thing i could suggest is making your watts link bars parallel to the ground at ride height. have you checked side to side movement with vertical travel?
looking good though
REBUILD THREAD
Wreck Thread My StreetSource ![]() "Lifes all bout making mistakes, It's how you learn from them that counts" |
#15 |
Member ID: 82239
they are parallel at my most common ride height (half travel), the pic is laid out. FTL means?
#16 |
Premium Member #55
Status:
Online
Member ID: 2731
FTL= For the lose
#17 |
Member ID: 82239
ok
#18 |
Wuuuazuuup!!!
Member ID: 326
hmm... ok
anyways good deal, couldnt really tell in those pics..
REBUILD THREAD
#19 |
Member ID: 3382
looks good, have any pics of the 4 link setup including the mounts? i'm in the process of doing this also, and always like to see other ideas
#20 |
Drives an OBS
Member ID: 81358
what color is that?
| Advertisements |
| Thread Tools | |
| Display Modes | |
