Old 05-28-2008, 07:36 PM   #1
shane_k1500
shayne...not shane
shane_k1500's Avatar
Member ID: 87458
1989 stepside rebuild *better , smaller pics*
G'day , i thought id post my small project up on FSC.1989 chevy step side 1/2 ton 4x4.
This is what the truck forst looked like when i first got it in november
This is what the frame looked like after cutting it , its was really rusty and there was a few cracks in teh baack part that is cut off.
[IMG][/IMG]
This was the ol' greasy gas tank looked like (real rusty , sending unit was all brittle)
[IMG][/IMG]
Took inner fenders and outter fenders off for brand new inner and outter fenders.
[IMG][/IMG]
The box rails where all rotted so i tore them off and got new ones made.
[IMG][/IMG]
Now i started putting it back together slowly , so i started with new plugs , plug wires , distibutor rotor and distributor cap.
[IMG][/IMG]
Now i got into the bigger stuff, frame repair , brand new gas tank , sending unit and fuel pump, New KYB shocks , and i installed my homemade blocks with new u-bolts. I also painted the frame and diff.
[IMG][/IMG][IMG][IMG][/IMG][/IMG]
[IMG][/IMG]
painted the part behind the grill
[IMG][/IMG]
this is all i have for now. I've done a lot more to the truck like changing all u-joint , new pittman arm cleaning , and other small things here and there.Next step is doing a bit of body work on cab corners, installing front shocks , putting fenders back on, installing 3" body lift and RC levelling kit. And I also Have more work to do on the box.
6-"RC suspension lift
-3"body lift
I'm Canadian, there's no doot aboot it!!!
Old 05-29-2008, 07:48 PM   #2
44gmcnewf
285's look small
44gmcnewf's Avatar
Member ID: 56336
Re: 1989 stepside rebuild *better , smaller pics*
what size tires are you plan on running? I got a 88 long box thatis in a similar phase to yours at the moment. I have some family up in NB, one is acutal home for 2 weeks.
88 GMC Serria RCLB 4wd
Cool thing about a truck is you can put stuff in the back, Cool thing about a Jeep is ...... Nothing
Old 05-29-2008, 08:14 PM   #3
shane_k1500
shayne...not shane
Member ID: 87458
im planning on runnin 33's or 35's, where are you from?
-3"body lift
Old 05-30-2008, 04:53 PM   #4
44gmcnewf
285's look small
44gmcnewf's Avatar
Member ID: 56336
I am from St johns Newfoundland.
the old stepper looks nasty... you plan on fixxing that one or replacing it?
