Old 07-22-2008, 01:05 AM   #1
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
88GMCtruck's SAS Build Thread
As some of you know, since I got my new truck I decided to replace the inadequate IFS in my 88 Sierra and install a Dana 44 Solid Axle. The goal is to keep it all GM, run 35's, and make it look like it rolled off the assembly line with the solid axle. I also want to keep the bill under $2,500 (will add costs later).
The Plan:
Front Axle: Dana 44 from 1977 GMC K15, 3.73s, trussed, flat top knuckles, HD shafts, spicer joints, Warn Premium hubs.
Rear Axle: 14 Bolt SF from 1993 C2500, 3.73s, G80
Transfer Case: Passenger drop NP241-C from a 1990 1500 Suburban
Steering: DT machine steering arms, Full crossover and hi-steer, Superlift 1104 Pitman
Front Suspension: Custom front spring mounts, 1977 GMC rear spring mounts, 52" springs & shackles with overloads removed from the rear of the 1977
Rear Suspension: ORD shacke flip, 4" block, Stock 64" springs
Brakes: Stock 1977 front discs, Stock 1993 rear drums, teflon/kevlar/stainless lines from ORD
Shocks: Rancho RS5000
Tires: Q78-15LT Gateway Buckshot Wide Mudders (CHANGED)
315/75R16 Mickey Thompson MTZ
Wheels: GM Factory 15x8 Rallys (CHANGED)
16x8 Raceline Renegade 6
88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 168k. 9" SAS, D44 on 35's
02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 16k. Sierra HT package: 1 of 234 Trucks.
Old 07-22-2008, 01:05 AM   #2
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
Re: 88GMCtruck's SAS Build Thread
Tonight the teardown began. Out goes the IFS:
Inadequete parts:
Old 07-22-2008, 01:23 AM   #3
FordeatinZ71
FSC Drunkin Teem
FordeatinZ71's Avatar
Member ID: 2427
Location: Hooks, Texas...i keep working closer and closer to 'Bama!
subscribed!
<---thanks 454SS!!
1991 Chevy Silverado K1500 extended cab, 350, 700R4 with shift kit, exhaust work...in need of body work...lol...
1983 GMC Sierra K1500 sold...
Old 07-22-2008, 01:14 PM   #4
vic_V8
bikes cars trucks women
vic_V8's Avatar
Member ID: 11278
turn all that stuff in for scrap money, it will be worth a couple hundred for you. help offset the cost of the SAS
91 GMC 350 5 speed, SAS started, HP 44/14 bolt
91 camaro, more mods than you
'00 ZX9R, 150 RWHP
,02 AVY leveled
'63 CJ5
Old 07-22-2008, 01:23 PM   #5
MC
Less=More
MC's Avatar
Member ID: 82510
I'd go with lower gears... Looks good though. Subscribed.
RIP America 1776-2008
Old 07-22-2008, 01:39 PM   #6
muddychevy98
Supporting Member
muddychevy98's Avatar
Member ID: 59229
this is gonna be a good build, subscribed
^Thanks ILD
01 Silverado 5.3 ECSB 3in block/3in BL/315 75 16 Cooper STT's/black DC-1s/PATC Raptor Jr/dual 4' firestik cb antennas/Blackbear Performance tune
Future Mods: 03 tails/u-bolt flip
Old 07-23-2008, 08:53 AM   #7
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
I'm going to try selling the front diff and transfer case, but the rest is pretty much scrap. Good Idea to sell it as scrap! I also have the rest of the 77 frame too.
I'm planning on getting 4.56's next year. I can't afford to do the gears yet, so 3.73's will have to do for now.
Last night Dad and I cut all the brackets off the frame, ready to be ground smooth.
Old 07-23-2008, 08:56 AM   #8
F4MOU$
♠MOB♠
F4MOU$'s Avatar
Member ID: 84471
nice! I like the fact that you are doin the SAS and only running 35's. I think itd be sick, normally people do SAS's and run 37 + and that is huge at that point. itll be sick on your truck as well as I am subscribed to watch the build!
good luck!
♠ Corsa RSC Sport ♠ K&N Intake ♠ Keystone Good Hood ♠ Gaylords X2000 ♠ Readylift ♠ Bedrug ♠ PIAA SMR ♠ Smoked Tails ♠
Old 07-23-2008, 09:00 AM   #9
daved931
daved931's Avatar
Member ID: 87774
Cool build. Def subscribing.
1999 Tahoe LS 2-Door 4x4 w/ 3.73 G80. Custom tune from Justin @ Black Bear and a Vette 1 - 2 servo.
14 Bolt SF Project Underway
Proud member of the OBS Hood Whacker Club
Old 07-23-2008, 09:03 AM   #10
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
Yeah my intent is to basically to make the truck more capable and stronger than it was with IFS. I'm not going to wheel the living ell out of it which is why I'm only going with a D44, and I don't need it to be huge by any means. Honestly the choice of 35's basically boils down to the fact that I'm going to still be driving this regularly and large tires cost big bucks!
Old 07-23-2008, 09:23 AM   #11
F4MOU$
♠MOB♠
F4MOU$'s Avatar
Member ID: 84471
yeah, whether your choices were caused by not having the funds for it, or just to do it, I think this is definatly a good thing your doin, itll be nice. cant wait to see the bitch done, whens the plan date to be done by?
Old 07-23-2008, 09:25 AM   #12
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
Should be complete in about 3 weeks, I hope.
I plan to have the transfercase in tonight and the axle under it by this weekend.
Old 07-23-2008, 09:29 AM   #13
F4MOU$
♠MOB♠
F4MOU$'s Avatar
Member ID: 84471
sounds good! cant wait to see it done!
Old 07-24-2008, 04:46 PM   #14
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
More parts arrived!!!
ORD Teflon/Kevlar/Stainless Brake Lines
ORD 4" Shackle Flip
I started removing the transfercase, and started mounting the front springs.
52" spring with overloads removed
Front Spring mount built and welded
Spring hanging from front at approx. unloaded height.
Old 07-25-2008, 12:51 AM   #15
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
Update on what was done tonight. Started grinding the remaining metal off from the old IFS brackets. We have added additional to the inside of the frame under the cab and one spring is fully in place We did not finish the other side as the welder ran out of wire. Tomorrow the other spring will be in and I want to start the transfercase swap and build the new crossmember for it.
Old 07-28-2008, 12:28 AM   #16
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
Well I know I`ve been leaving you guys kinda hanging all weekend, so here is the update. Dad and I have worked our tails off all weekend.
The transfercase is in waiting for a new crossmember and shift linkage. We removed most of the old IFS crossmember and 1/4" plated it, and made a new set of spring hangers 1" forward and 1" lower than the previous also 1/4". The axle was fully stripped and painted.
The springs are a custom pack made from two sets of 5 leaf 1/2ton 73-87 chevy truck rear packs. Two shorter leaves were made from one pack and added. All were painted individually as well. They were installed with engergy suspension bushings.
We have everything tacked on and she is now sitting! These tires are only 29" but after measuring I think the truck is sitting at 7-8" of lift.
We are going to add an additional crossmember between the front spring perches. and build my steering soon. I have all my parts now except shocks.
She sits on her new suspension!
Front 1/4" spring hangers, boxed
Rear spring hangers from 77 GMC (they will be fully welded soon)
Flat plated crossmember
Custom 7-leaf pack
New t-case installed, waiting for custom crossmember
Old 07-28-2008, 04:46 PM   #17
alfredov
alfredov's Avatar
Member ID: 92162
nice 88
Old 07-28-2008, 05:10 PM   #18
GMC Sierra
Redneck
GMC Sierra's Avatar
Member ID: 29014
nice build
2004 Chevy Silverado ECSB Z-71-----LOUD PIPES...SAVE LIVES D.F.W.A
NEW RIDE http://www.cardomain.com/ride/2595281/1
TRADED http://www.cardomain.com/ride/2300960
Old 07-31-2008, 10:44 AM   #19
88GMCtruck
02GMCtruck
88GMCtruck's Avatar
Member ID: 13211
I will update with pictures tonight, but, here is the update.
-Crossover steering finsihed (might change pitman arms though)
-Drop transmission crossmember finished
-New front crossmember and shackle mounts finished (needs welded in)
-Figured out shocks and mounts
-Figured out tires and wheels (16x8 w/ 4.5" BS & 315/75R16)
-Found out where to grind for my CV driveline to have enough workable angle and not bind
More to happen tonight and I have tomorrow off so much more will happen then! It should be moveable by this weekend.
Old 07-31-2008, 01:14 PM   #20
FordeatinZ71
FSC Drunkin Teem
Member ID: 2427
Sweet!
<---thanks 454SS!!
