#21 |
Made In Canada
Member ID: 60163
Re: Project: Sub Urban Assult v2
Cant wait to see this thing done. V1 was one of my favourite projects and I loved seeing progress updates on it, so cant wait till this ones done.
![]() No Replacement For Displacement |
#22 | |
Member ID: 70108
+1, bends on mine don't look like that. I also noticed those NFabs have closed ends, min are open ended. Are they NFab rip-offs? ![]() AllBlackedOut '07 Chevy Silverado | 5.3L V8 LT1 4WD|3" BL/2.5" Level Kit Black Corsa Exhaust 5" Tip | Fab'd GrilleGuard | Hella Black Magics LineX'd Bed/Bumper/GG/NFabs | Black Powdercoated Wheels | 33" Cooper STT's |
#23 |
MATT
Member ID: 42567
He welded them up. Read below the pictures.
2004 1500 Silverado Z-71 ECSB 5.3L 3" body lift, 305/55R20 Nitto Terragrapplers on 20x10 Helo's, and a few bolt-on's.
#24 |
Member ID: 70108
Ah..ok missed that. They're left open on purpose though, so the inside of the tubing can dry, helps to dissipate any moisture.
#25 | |||
Trumpets Rock!
Member ID: 28017
Wow.
#26 | |
Member ID: 12842
yeah it also helps rust them from the inside out so one day you can step on it and watch the welds break. |
#27 | |
♠MOB♠
Member ID: 84471
I was just gonna say that. unless you somehow COMPLETELY seal em off, you might be good. but moisture is a tricky SOB |
#28 | |
Member ID: 70108
I dissagree. They should be left open, so they air dry faster. Even when they are sealed they will get moisture in them, and they'll stay moist which is bad. I should've left the bottom of the slash cut fangs on my gg open. ![]() AllBlackedOut '07 Chevy Silverado | 5.3L V8 LT1 4WD|3" BL/2.5" Level Kit Black Corsa Exhaust 5" Tip | Fab'd GrilleGuard | Hella Black Magics LineX'd Bed/Bumper/GG/NFabs | Black Powdercoated Wheels | 33" Cooper STT's Last edited by AllBlkdOut07 : 07-30-2008 at 11:33 AM. |
#29 | |
♠MOB♠
Member ID: 84471
thats what he is saying I believe, that if they are welded shut, the water trapped inside helps start rust and they will eventually rust from the inside going outwards... it speeds up the rusting process. |
#30 | |
Whore Whisperer
Member ID: 89340
im well aware of how moisture works...this isnt my first rodeo. thats why i drilled 1/4 drain holes in the bottoms at each end and have rubber plugs for them. ill leave them open in the summer, and plug them in the winter. there is no reason to leave the ends WIDE open like N-Fab does. it leaves the entire interior of the tube exposed, uncoated, and unprotected. plus, they fill up with mud fast. my Go Rhinos were the same way. this is the last set of Nerf's i buy from any company...IMO all mass marketed bars are crap for what they cost. ill be building the next set. as for the bends.... i couldnt tell you, you'd have to ask them!?! id bet they are outsourcing them... Last edited by bonedust : 07-30-2008 at 12:35 PM. |
#31 | |
♠MOB♠
Member ID: 84471
wait, do you still have the go rhinos? |
#32 | |
Member ID: 70108
Ok, gotcha. ![]() AllBlackedOut '07 Chevy Silverado | 5.3L V8 LT1 4WD|3" BL/2.5" Level Kit Black Corsa Exhaust 5" Tip | Fab'd GrilleGuard | Hella Black Magics LineX'd Bed/Bumper/GG/NFabs | Black Powdercoated Wheels | 33" Cooper STT's |
#33 | |
1981 Chevy 4x4 Owner
Member ID: 90985
well damn son, im about 15 miles off of 71, if you all dont mind, when you go wheelin, you mind if i come too? and by the way, this new project is lookings great. and i too say to put black flares on it instead of the color matched ones. the black grill looks good. once the front bumper and the N-fabs are put on, it will look killer. i say, expecially how winters can be up here, to Linex the rockers from the body line down, IMO it matches and looks tough, would totally match the project. i found some stuff at walmart the other day that is the knock off brand, but for $42 a gallon.. thinkin about doing the floors of my cab and bed with it... and the bullet door handles will look sick you still have them!![]() ![]() My future ride... I hope!!!- If You Ain't Haulin A$$, You're Waistin Gas!!! |
#34 | |
Whore Whisperer
Member ID: 89340
nope, those were on my 01 Tahoe. lol...ive had a ton of chevys! 96 1/2 ton regular old truck. 99 z71 ecsb 00 z71 4dsb 01 z71 tahoe 03 3/4 burban 06 3/4 burban |
#35 |
Whore Whisperer
Member ID: 89340
well, its been a long morning! I got up early and gave the truck a MAJOR chassis bath. While the underside was drying i installed the black billet gas door. I kind of expected this to be a cheap-o tunerish part, but much to my surprise its very well made and installed flawlessly! Sure, it wasnt the cheapest gas door out there, but still i was pleasently surprised! I got the N-Fabs on with very few issues. the drivers side is cake, but the rear A/C lines make the passengers side a tad tricky. the bars and bolts clear all the lines, but you have to be VERY careful you dont drill into or hang up on them during install. From there i moved on to the front bumper. WARNING: this is a 3 person job!!! nevermind the stupid bumper weight 300lbs, but getting it in place with 1 person and 2 floor jacks is insanity. its still not perfectly level...or even close. Not a big deal, cause the bumper will have to come off again when my 16t winch arrives. Ill make sure i have appropriate manpower on hand then.
![]() ![]() ![]() ![]() This weekends project: roof rack and lighting (and looooots of it) |
#36 | |
looks awesome!!! but that front sags a bit with that bumper. what lift are you gonna end up going with?
![]() ![]() Quote:
#37 |
♠MOB♠
Member ID: 84471
man that burb is sick!!! and yeah, I will definatly shoot down there in Sept, I am gonna be hunting this year for the first time, so I need to pick up some sorta shotgun for it, I am goin duck hunting and deer huntin, but aint lookin to spend that much either. and are the Nfabs supposed to stick down that far??? and be VERY careful in the winter with that billet gas door. make sure it is ALWAYS clean or it will start to pit. Trust me I know this because I sell them all the time and here that from customers.
#38 | |
MILF lover
Member ID: 72673
Sh1t dude! I'm sorry to her about the accident. How'd you go flying, what kind of car was she in? Looking bad ass, I like the gold/black a lot, actually.
'00 ECSB 4x4 | Built 4L65e | 5.3 | 2% Tint (RIP 10/1/08) | K&N | Magnaflow | BFG | Wait4Me
![]() Quote:
#39 | |
Whore Whisperer
Member ID: 89340
yeah, ill turn up the keys a bit for now to accomodate. ill be running the Cognito 10-12" |
#40 | |
Whore Whisperer
Member ID: 89340
she was in a Taurus. they took it away in Heafty bags... |
| Advertisements |
| Thread Tools | |
| Display Modes | |
