Old 09-03-2008, 08:21 PM   #1
bDBlaCk13
siR SmOkEs aLoT
bDBlaCk13's Avatar
Member ID: 94684
Bare Naked Frame
Hey,
This is my first post. I have a 1/2 ton short wide stripped to the frame. I will be sand blasting and repainting pretty soon and would like to know if anyone has a suggestion for paint.
I would like a semi gloss durable finish that is easy to apply.
Thanks
B Black
Old 09-03-2008, 08:31 PM   #2
LPG PWRD
Cowboy From Hell
LPG PWRD's Avatar
Member ID: 79183
Re: Bare Naked Frame
I have PPG on my frame but she is shinny as hell
DD: 2001 Silverado 1500 ECSB 5.3L
Project: '94 GMC ECSB - SAS resto project My stupid space
Old 09-03-2008, 08:35 PM   #3
bDBlaCk13
siR SmOkEs aLoT
bDBlaCk13's Avatar
Member ID: 94684
Is the PPG a frame coating or is it just gloss black with a primer
Old 09-03-2008, 08:40 PM   #4
LPG PWRD
Cowboy From Hell
LPG PWRD's Avatar
Member ID: 79183
2 part epoxy primer then gloss black paint, but this chit is thick, had to grind some areas down to add weld on parts and it did not come off easy or fast
Old 09-18-2008, 05:04 PM   #5
bDBlaCk13
siR SmOkEs aLoT
bDBlaCk13's Avatar
Member ID: 94684
I used a rattle can product that worked really well. After sandblasting and preping the frame, the rustolium covered really well.
Old 09-18-2008, 06:59 PM   #6
Derek1387
Member ID: 93004
POR15 is a good one too
Old 09-18-2008, 08:15 PM   #7
shave05
Member ID: 70752
por15 is a very tempermental product. if not applied correctly to the T it will chip off very easily. i applied mine in bare metal after a wax and grease remover and it still chipped off
Old 09-18-2008, 09:03 PM   #8
Derek1387
Member ID: 93004
ive never had a problem with it... just follow directions and it will work out just fine.
Old 09-18-2008, 10:18 PM   #9
Toolman
No more F'n Bailouts!
Toolman's Avatar
Member ID: 1089
Photos!?!?!?!
You get what you pay for......nothing is free.
Old 09-19-2008, 12:15 PM   #10
DjLunchbox
king rigger reppin CAF I
DjLunchbox's Avatar
Member ID: 7624
i hate por15. i spent a mint on their products, prepped exactly to their specs, and my engine bay is peeling all over the place. i will never purchase their coatings again. on the flip side, i used cheap arse rustolium spraybombs on my rear frame, and it is sticking better to a clean frame then the POR. obviously it should be touched up after time, but it is easy to go get a can of the oil based rustolium and do your touch ups that way, then to restrip and reapply the POR. just my 2 cents. at ome point i may try eastwoods chassis products and see if i have better luck. who know, it may be POR in a different can.
Old 09-19-2008, 12:37 PM   #11
Inverter
warranty killer
Inverter's Avatar
Member ID: 62969
I dont know if your planning on a show truck finish but Ive had some good results w/oil base Rustoleum from Home Depo.If you sand the bare metal and wipe it down,,when this stuff dries its hard to get off w/a cup brush. I recommend 2 or more coats. Its cheap and it seems to work well,and it looks great.Buy 1 gal. and the rest is all labor.
Old 09-19-2008, 01:30 PM   #12
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
i found your problem. POR isnt meant to be applied to a completely clean surface. it needs some surface rust in order to adhere well. its moisture curing, so it needs the rust underneath to cure properly, without it, it will flake off.
i have a friend who deals in the stuff.
Old 09-19-2008, 04:06 PM   #13
91blkstpsd
Slow Truck
91blkstpsd's Avatar
Member ID: 22825
I went to O'Reileys and bought a gallon of semigloss black implement paint. It goes on thick and adhears good. It was only like $30 and covered my entire frame in about 2 coats.
before
after
http://www.myspace.com/newdrewman
'06 CC Z71, RC leveling kit
'91RCSB:LT1 & 4L60E swap,Hotcam,1.6RR,52mm TB, headers,MSD,,Built trans,TransGo,TCI stall,Ultralite Gauges,leather+suede,billet,shaved,4-6 drop,20"s
BUILD THREAD
Old 09-19-2008, 05:34 PM   #14
Inverter
warranty killer
Inverter's Avatar
Member ID: 62969
Yep...Tractor paint.That stuff is tough,same type as I used.You can reduce the gal. and spray it or just brush it on in light coats.
Old 09-22-2008, 01:46 PM   #15
91blkstpsd
Slow Truck
91blkstpsd's Avatar
Member ID: 22825
Yeah, I just used a 1.8 tip and sprayed it on in two medium coats. Came out great IMO. Next stuff I may use on another project is that ceramic chassis black from Eastwood Co. Supposed to be the stuff!
BUILD THREAD
