Old 09-27-2008, 12:58 AM   #41
Remember the 343 and 9/11
Chevyman247's Avatar
Re: My SAS Resto Project -
Originally Posted by GreaseDog
so long as the pickup in your propane tank is positioned correctly, you can flip your truck upside down and it will still run.
But then the oil pump pick up would be uncovered and fry the bearings. Besides, who wants to run their engine/truck upside down anyway, not like your going anywhere. lol
If I was to flip my truck, I would want the engine to shut off, and atleast save the engine.
BTW LPG POWRD,
How are you planning on introducing the LPG into the engine? TBI, MPFI, Carb?
How much is LPG per gallon? So, with more BTUs per gallon over gas, LPG should give more power and MPG?
91' 1500HD 4x4, 9" total lift, 38.5" Ground Hawgs, Super 44 Flows, 14 Bolt 9.5" Rear, Carbed 357 "Magnum"
"Estmated Power at crank-300hp and 400 Torque"
Chevyman247 is offline
Old 09-27-2008, 02:09 AM   #42
DUH! Big Red Truck!
GreaseDog's Avatar
dry sump oiling system will solve that. more than one comp crawler running pane and a dry sump. there are no points issued if you can flip yourself back over. crank the wheel and give 'er hell, hope she'll flop back over on all 4s.
GreaseDog is offline
Old 09-27-2008, 02:16 AM   #43
fer79's Avatar
very very nice, congrats, check out my resto c/10
MEXICAN SILVERADO STEPSIDE 2005
heads #243 ls6, camshaft ls6, diablosport predator, msd, k&n, headers, shiftkit, flowmaster...
fer79 is offline
Old 09-27-2008, 07:32 PM   #44
Cowboy From Hell
LPG PWRD's Avatar
Re: My Propane Powered SAS Resto Project
Here is a quick list of parts so far:
Engine-
Good ol' 2 piece rear main seal block, custom 13.5cc dome JE pistons, comp cams roller conversion w/ fully roller rockers, dart iron eagle platinum heads, LT1 powdered rods. The engine has a 13.2:1 compression ratio gotta love propane
Trans-
NV4500 w/ 6.34 first gear
Tcase-
241 Passenger Drop 32 spline w/ JB SYE kit
Front axle-
Dana 60 (chevy) King pin axle, 5.13 superior gears, lock-right locker, warn premium lockouts, all new everything.
Rear axle-
14 bolt full floater, 5.13 yukon gears, detroit locker, disc brake conversion (3/4 ton fronts), all new everything.
Tires-
ProComp Xtreme AT's 38.5x14.5x18
Rims-
Eagle Alloy 197 18x9 superfinish
Sas kits-
ORU solid axle conversion kit 32.5" SPW
Steering-
ORU crossover steering, hydralic assist, ORD heavy duty rod ends w/ custom 1 1/4" x 1/4" wall DOM tierod tube
Exhaust-
92 camaro long tube headers w/ 3" collector, 3" true duals w/ h-pipe, electronic cutouts, and flowmaster delta 40s, getting side outputs infront of rear tires, no cats... its a clean burning fuel
(I will edit this post as things get added)
DD: 2001 Silverado 1500 ECSB 5.3L
Project: '94 GMC ECSB - SAS resto project
LPG PWRD is offline
Old 09-27-2008, 07:55 PM   #45
HAPPY JUICE
itcantbestephen's Avatar
Can't wait to see this thing finished, do you have any kind of timeline, or schedule, or is it kinda do what you can when you can and hope it gets done sorta thing?
Thanks xZoomerZx!
1993 GMC Yukon 4x4
Originally Posted by daved931
I'd push my mom off a bridge before my FSC.
itcantbestephen is offline
Old 09-27-2008, 08:35 PM   #46
Cowboy From Hell
LPG PWRD's Avatar
Carlisle at the latest, if not, she gets the match
LPG PWRD is offline
Old 09-27-2008, 08:52 PM   #47
No room for my brilliance
mybigwarwagon's Avatar
Before you burn it call me I will come get it for free.
Looks good so far.
William
Read My Mind
Click Here
mybigwarwagon is offline
Old 09-27-2008, 08:57 PM   #48
bggrnchvy's Avatar
LPG has less BTU's per gallon than gasoline. In like motors, meaning the same compression, you will make less power with propane. The upside to propane is cheap fuel injection effectively through a mixer (no MPFI, computer, sensors necesary) and high octane rating for cheap fuel cost. You can run lots of compression to eek out more power for cheaper running cost.
One guy in my club runs on propane and his LQ4 sucks it up. He went through ~40 gallons of propane in his lighter K5 during a week of running the same obstacles as me while I went through about 25 gallons of 87 octane in my L31 and heavier rig.
He needs to bump the compression and adjust the timing more on the MSD.
1997 K1500 ECSB L31/80e/241/D60f/C14FF
2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
bggrnchvy is offline
Old 09-27-2008, 09:38 PM   #49
How high of compression can you run with propane? And I am still confused on what you use to put the gas in the engine. Carb?
Old 09-27-2008, 09:46 PM   #50
Cowboy From Hell
LPG PWRD's Avatar
its called a mixer
LPG PWRD is offline
Old 09-27-2008, 09:54 PM   #51
The gubment owns OnStar
Dubyagee's Avatar
Tank, filter/lock off that catches any trash and shuts off fuel supply when there is no vacuum present from the engine, converter that converts the liquefied gas into vapor and a mixer/carb that regulates the fuel mix based on demand from the engine.
We have forklifts that use injection systems but none are available for on the road use that I know of.
Dubyagee is offline
Old 09-28-2008, 10:36 AM   #52
Cowboy From Hell
LPG PWRD's Avatar
This weekend was kind of a waste since UPS screwed me and delayed a delivery and the guy setting up my gears has taken 3 weeks now But I did get the gear box tapped and put back together, and gave the tcase a bath and tore it apart. Also started tearing into the wiring harness to redo the wires.
LPG PWRD is offline
Old 09-28-2008, 10:41 AM   #53
Cowboy From Hell
LPG PWRD's Avatar
Also install the third and final option for headers. They are a set for 78-86ish straight axle trucks.
Driver side
Passenger side
So the conclusion is that I will be running the 3rg Gen Camaro headers.
LPG PWRD is offline
Old 09-28-2008, 10:43 AM   #54
I'm cranked.
ilikedirt's Avatar
this truck is going to be really cool! i cant wait until its completed
01 Sierra 5.3 with stuff.
Originally Posted by 01SilvyZ71 View Post
i challenge each of you to go to the grocery store, get a box of cinnamon chex cereal and not eat more than 1 bowl. that **** is like cocaine i just cant get enough!!
ilikedirt is offline
Old 09-28-2008, 11:18 AM   #55
Miget's Avatar
SHEE SHAW GANNA LUKE PREDY!!!
hella va project
cant wait till she is doen
I don't think of my truck as being OLD ...I think of it as having been more places than a NEW one
94 Chevy fullsize Blazer 6" lift front and back Old school 15 rims w/ 35/12.5/15 Yokohama Geolander Muds and YES a 'Heavy Drinking' 5.7L
Miget is offline
Old 09-28-2008, 03:49 PM   #56
BlackRockTrucks's Avatar
LPG looking good man keep up the good work!!! Why not go with shorty headers instead of the long tube?
1994 Chevy 1500 stepside SAS with 2.5 rocks
2000 Ford F350 10.5" lift on 37" SSR
1972 GMC Prostreet Truck (never ending)
Full tube monster truck frame in process
1971 Ford Torino
BlackRockTrucks is offline
Old 09-28-2008, 06:53 PM   #57
Cowboy From Hell
LPG PWRD's Avatar
I like headaches I am determined to run long tubes, dont know why.
LPG PWRD is offline
Old 09-29-2008, 02:18 PM   #58
Formerly 81chevyc10
Black90Sport's Avatar
cant believe i missed this, lookin really sweet, find any pics of the axle your sellin?
Sig by g9m3c
1990 K1500 Sport.
Under construction-Forever
www.JBCarWorks.com
Black90Sport is offline
Old 09-29-2008, 02:22 PM   #59
Cowboy From Hell
LPG PWRD's Avatar
Ha, I forgot
LPG PWRD is offline
Old 09-29-2008, 02:24 PM   #60
Formerly 81chevyc10
damn you i always wondered what lpg pwrd meant... now i know
Sig by g9m3c
1990 K1500 Sport.
www.JBCarWorks.com
