Old 09-29-2008, 12:29 AM   #1
americanmetal07
Professional Grade
americanmetal07's Avatar
Member ID: 42635
1984 K5 Resto/build
Decided I wanted to fix up the ole K5.
Guess I'll start with ripping the carpet out to bed line the floorboard.
As far as I got tonight:
Some nice rusty holes in the rear corners.
Rear was done Friday.
Pulled the front seats and carpet/insulation out Saturday.
No pictures of it yet.
Anyone have any experience with Rust Bullet? Thinking about covering the sections that the top covers with this ****.
2004 GMC Sierra 1500 ECSB Z71
1984 K5 Blazer
Old 09-29-2008, 01:13 PM   #2
hammermachine
hand grenade fight!
hammermachine's Avatar
Member ID: 77423
Re: 1984 K5 Resto/build
Not bad so far, what does the rest look like.
http://warmachinechronicles.blogspot.com
1985 K5 350, 208, 10B front& rear(locked) Old and mean!
Old 09-29-2008, 11:00 PM   #3
hick
Big Dreamer, Small Bank
Member ID: 64756
if those wheel wells are anything like the ones on my suburban, make sur eyou got a wire wheel and grinder and do it out side with a good mask... they glued that **** on with the intention of it never coming off
2004 2WD Silverado, Ext. Cab, Fully Loaded, White, 5.3L Stock, daily driver
1980 "Avalanche", 4x4, "Custom 3 Tone Paint", 350ci, highschool shop project...
Click For Build thread
Old 09-29-2008, 11:39 PM   #4
americanmetal07
Professional Grade
Member ID: 42635
I'll get some more picture tomorrow after class.
lol Thanks for the advice.
1984 K5 Blazer
Old 09-30-2008, 12:37 PM   #5
americanmetal07
Professional Grade
Member ID: 42635
Has about 1" or so of Cali
Due to sagging rear springs.
1984 K5 Blazer
Old 09-30-2008, 12:54 PM   #6
americanmetal07
Professional Grade
Member ID: 42635
1984 K5 Blazer
Old 09-30-2008, 09:56 PM   #7
modular93fox
be punished
Member ID: 65701
if you decide you dont want that panel on your tailgate, il gladly take it off of your hands and put some green in your hand!
1987 5.3 4l60e Silverado - new daily driver with A/C - also for sale @ $7,200
A poor man buy's it twice
1993 4.6 t-45 Mustang GT for sale 5,000
Old 10-28-2008, 03:33 PM   #8
americanmetal07
Professional Grade
Member ID: 42635
Thing is completely stripped in the inside now.
Got all the holes in the cab area covered in bondo. Tomorrow I will sand them down, clean the floor good and bed line it (hopefully)
Then move on to the 2 rear rotted sections.
1984 K5 Blazer
Old 10-28-2008, 03:45 PM   #9
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
you're not covering the holes in the floor with bondo are you? once you do that, and then put the liner over it, it will just rot the metal out under the liner. those holes need to be cut out and patched in before you line it.
Old 10-28-2008, 03:53 PM   #10
americanmetal07
Professional Grade
Member ID: 42635
I ground all the rust off, coated the bare metal with rust bullet, and I'm bondoing over that.
1984 K5 Blazer
Old 10-29-2008, 12:50 AM   #11
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
yeah... that's not gonna work. bondo is a filler, not a metal patch. you need metal.
Old 10-29-2008, 03:36 PM   #12
hotrodchevy
hotrodchevy's Avatar
Member ID: 71413
yea man i would not just use filler because that will not do trust me i done the same thing and i ended up taking the filler back off and taking a screw driver and poking the floor where it was not solid and it made holes so since your floor is mostly solid just take some sheet metal and weld it in and for your kick panels get new kick panels or you can go all new metal with the link below
http://www.lmctruck.com/icatalog/bzc/full.aspx?Page=23
Old 10-29-2008, 04:03 PM   #13
americanmetal07
Professional Grade
Member ID: 42635
Like I said the bondo isn't on any rust.
+ I can't weld worth a ****
1984 K5 Blazer
Old 10-29-2008, 04:22 PM   #14
hotrodchevy
Member ID: 71413
well i am 25 and in high school i welded with a stick welder and i have not welded since but now i have this truck and i am going to weld new rocker panels new kick panels one cab corner with a mig welder and you could weld with a mig it is easy but if you say that the filler is not on any rust ok cool do you have any pics of the progress?
Old 10-29-2008, 04:26 PM   #15
americanmetal07
Professional Grade
Member ID: 42635
Nope sorry. I'll try to snap some later
1984 K5 Blazer
Old 10-29-2008, 04:37 PM   #16
hotrodchevy
Member ID: 71413
ok cool man
Old 10-29-2008, 04:44 PM   #17
Citizen Rider
Member ID: 9224
What all plans you got for this bad boy? i need to get back to work on mine, been sitting for 2 years right after i did the one tons.
True that. That glue is still on mine, along with some from under the drivers carpet by the pedals. I gave up and moved along to putting my corbeau seats in.
Old 10-29-2008, 05:05 PM   #18
americanmetal07
Professional Grade
Member ID: 42635
There wasn't much glue on the wheel wells under the insulation, a bit but not much.
Eventually I need to get some new springs all around.
Probably a RC 4" kit on some 33-35's
I also need to find me some vortec heads, and ditch the quadrajet.
1984 K5 Blazer
Old 10-29-2008, 05:44 PM   #19
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
doesnt matter if its on any rust or not. the way you just described it, there is a hole in the floor, and you put some rust stop paint on it, and are now filling the hole with bondo. wont work, as bondo is a cosmetic filler only, it wont hold anything structurally. if you're going to do it that way anyways, do yourself a favor. take some duct tape and cover the holes with that then spray the bedliner over it. either way, you're going to end up with a big hole under the liner, and it will rot everything else around it. might as well save yourself the time and effort of applying the bondo.
Old 10-29-2008, 05:45 PM   #20
GreaseDog
King Of The Hill
GreaseDog's Avatar
Member ID: 21917
what kind of EFI are you going with?
