Old 03-29-2009, 02:47 PM   #21
slowsexyside
james_8997's Avatar
Re: the long awaited build thread for my 93...
damn, thats a nice project greasedog, nice work dude
1997 K1500 Built vortec 355
Originally Posted by StreetFreak View Post
A good number of parts on my truck are ziptied on, simply because bolts are too heavy
imo
james_8997 is offline
Old 03-29-2009, 03:02 PM   #22
crossy's son's Avatar
Nice! I like the plan
pics of the OOBS dually???
91 RCSB|350|5 speed|3.42 G80|400k miles+|stock...15.67 @84
^ 89k 350,tbimods,Spacers,headers,Southbend clutch,AFPR...soon to be dropped in.:)
Dad's-87 SWB 2wd|305tbi
stuff-4 cummins powered dodge rams
& 81 C10 swb 13.54-1/4 ET,5/8 drop
94 K1500 ECSB 4x4,5.0L,4L60E,3.73's,Magnaflow
crossy's son is offline
Old 03-29-2009, 08:13 PM   #23
DUH! Big Red Truck!
GreaseDog's Avatar
Originally Posted by ryanroo
this idea has been rattling around in my head for years. one day i am going to cut up two perfect 60f's just to have my high pinion p-drop front axle. just not sure if it needs to go in the 72 chev, or the army truck. both of them have 60s up front now, so i just need to stumble on that 78-79 ford front deal. the army truck would have a sweet front driveline angle with HP. it would be almost flat.
truck is looking good. need some action pics.
you still have a spare 454 TBI set up you need rid of?
Ryan
who knows, i may start with a stock housing, if i cant find one cheap enough, i may break down and buy a RockJock centersection. i guess time will tell.
as for the BBC TBI setup, i may, if my 87 small block harness will adapt to the dash harness from the 90 pretty easily. i've thought about just pulling the motor and trans out of the truck and selling it to my buddy (who sold it to the guy i bought it from ). either way, i'll at least have an extra BBC TB. i know you mentioned looking for one back when i was working on the garage and saw the shelf labeled 454 TBI, so i'll definitely keep you in mind when that stuff starts coming off of the 90. if the dash harness isnt nearly plug and play, there are a bunch of 87 SBC TBI trucks at the local Pick N Pull with complete dashes, i'll just scab one from one of them.
thinking about scabbing the missing/broken pieces of the front end from a Burb at Pick N Pull and swapping the '80's stock front clip to one like the '90. planning on doing a step by step writeup for the classic section when i do. wont be a pretty setup at all, because it will be completely out of junkyard parts, and aesthetics arent a huge concern since its just a work truck, but it'll give you guys an idea of what it takes to do it.
GreaseDog is offline
Old 03-31-2009, 12:22 AM   #24
I hate the way they tried to make the OOBS look like OBS, I prefer the 87 and older look myself.
Originally Posted by mudbuddy
only reason to get rid of EFI is because your afraid of what you don't know.
'98 K1500 ECSB 5.7/4L60E, LT's w/3" Magnaflow, EFI Live.
speedracer326 is offline
Old 03-31-2009, 02:26 PM   #25
I love the 98-91 OOBS front ends... exspecially the GMC front end!. The core supports are totally different then 88 OOBS and back.
Old 04-01-2009, 10:06 AM   #26
Gearhead!
BIGGMC's Avatar
Awesome looking truck man! Subscribed. What size lift is it?
6 inch pro comp lift, 3 inch PA body lift, 38x15.50R20 Nitto Mud Grapplers
Custom quick disconnect plexi mudflaps, Front sway bar quick disconnects
Build Thread
BIGGMC is offline
Old 04-01-2009, 12:07 PM   #27
DUH! Big Red Truck!
GreaseDog's Avatar
3" brackets in the front, 4" springs. rear is 4" shackle flip with 3" springs. probably going to end up with an EZ Inch front and rear.
Old 04-01-2009, 12:17 PM   #28
FSC FOR LIFE!
PHATSPEED7X's Avatar
Looks good.
1991 K1500 Silverado RCLB aka "The UFO"
1993 K1500 W/T RCLB aka "The beater"
PHATSPEED7X is online now
Old 04-01-2009, 12:39 PM   #29
Gearhead!
BIGGMC's Avatar
cool, thanks man. i want to do a sas with a total of 11" front and 10" in the rear.
Build Thread
BIGGMC is offline
Old 04-01-2009, 01:25 PM   #30
Loving The 3 Speed
ryan_thompson87's Avatar
Looks good, was wondering when we were gonna see this thing.
355ci-9.6:1 Compression-TBI mods-Vortec Heads-GMPP TBI Intake-Melling Cam-Roller Rockers-Flowtech Headers-MSD Ignition-Super 40's-TB Spacer-AFPR-6" Superlift-36"TSLs-Built Turbo 350
ryan_thompson87 is offline
Old 04-01-2009, 01:49 PM   #31
going for broke
camo99Z's Avatar
Nice projcet man! I got lost trying to keep track of what part is going to what truck
camo99Z is offline
Old 04-01-2009, 02:12 PM   #32
DUH! Big Red Truck!
GreaseDog's Avatar
Velcro motor mounts are on the drawing board.
of the trucks that i am keeping... the 77, 80, 93 and 94.
my 80 is getting the 350 from my 92, and the TBI system i have in the garage.
the 93 is getting the 454 from the 90, and the 94 454 TBI stuff that i saved off of the white truck.
and the 94 already has the motor from the 93 in it.
i have to pull the intake and see if the block out of the 94 is a roller block or not. if it is, its probably getting a mild rebuild, along with the 60e that came out of the 94, and the original wiring harenss out of the 93. the idea is 4.10 gears + OD + 33" tires + torquey 350 (maybe a 383) = nice driver.
Old 04-01-2009, 02:18 PM   #33
bikes cars trucks women
vic_V8's Avatar
I'm starting to think my 6" brackets and 6" springs are going to be too much. Where in IN do you live? I have a chip burner for TBI trucks.....I'd trade you even up chips for random parts....
91 GMC 350 5 speed, SAS started, HP 60/14 bolt
91 camaro, bolt ons, 454 started on rebuild, waiting on wieland 8-71 blower
'00 ZX9R, 150 RWHP
'84 K10, 6" Tuff Country, 35s. soon to have 1 ton swap and 383 TPI
'63 CJ5
TUFF COUNTRY LIFT FOR SALE $450, EAGLE WHEELS AND 35" BFGs $1200
vic_V8 is offline
Old 04-01-2009, 02:34 PM   #34
bigger is better
thank god at first when i saw the hood i thought u were gonna drop her lift em high fat chicks cant jump [><]
liftedchevy79 is offline
Old 04-01-2009, 02:48 PM   #35
DUH! Big Red Truck!
GreaseDog's Avatar
i'm in Elkhart, just east of South Bend on 80/90. i've already got a burner, just not enough time to use it yet. my 94 needs a tune in a BAD way.
what size tires are you planning on running? i'm not real sure my 7" and 37"s are going to play nice together. started out with a set of Sky brackets, and 4" springs for the front, which would've been 10" and no problem.
Old 04-01-2009, 03:01 PM   #36
DUH! Big Red Truck!
GreaseDog's Avatar
first modification to it after i caught it on fire was to scraped off the Mr Horsepower sticker that was previously in the back window on the passenger side and replace it with this...
then i cut out the front suspension... 2 years later, i still havent bought a new alternator, which is what caused the fire to being with.
Old 04-01-2009, 03:17 PM   #37
vic_V8's Avatar
42" TSL IIs on 20x10 MT classic IIs
'00 ZX9R, 150 RWHP
'63 CJ5
vic_V8 is offline
Old 04-01-2009, 05:23 PM   #38
bigger is better
love the sticker gotta git one for mine
Old 04-01-2009, 07:10 PM   #39
Newbie
silver98Z71's Avatar
Ryan
Why do you need a '77-'79 D60? If all you are going to use is the reverse cut housing get a late model Ford D60. They are probably going to be cheaper. If you plan on using the factory shafts, I am doing this with my driver drop 10bolt, you will need a '77-'79 for the correct length tubes. Although, if you could find some seals to work without machining the inside of the tube you could just get some 3 1/2x 1/2" DOM and re-tube it however wide you want/need. OR, you could press the short tube out, get some 3 1/2x 1/2" DOM and re-tube the driver side (the new long side), then grind the passenger C off and cut the long tube down to length for you to use the factory short shaft. Then, you will need to address the spring pad, it will be on the opposite side of the center section... Just some of the many thoughts when retubing an axle.
[/Hijack]
Jeremy, the truck looks one hundred times better with the new grill and headlights.
-Daniel
Some people are just educated beyond their intelligence.
-Jerry Clower
silver98Z71 is offline
Old 04-01-2009, 07:17 PM   #40
DUH! Big Red Truck!
GreaseDog's Avatar
yeah... i'm gonna have to buy another new grille and headlights as well as the hood. they got stolen for the DD.
thinking about doing black chrome lights this time around.
