Old 04-01-2009, 08:36 PM   #41
No room for my brilliance
mybigwarwagon's Avatar
Re: the long awaited build thread for my 93...
Looks good now get out there and finish it.
William
Read My Mind
Click Here
mybigwarwagon is online now
Old 04-01-2009, 08:55 PM   #42
Ricer.
g9m3c's Avatar
Lookin good man! It must be nice to have an OOBS/OBS scrap yard in your backyard.
-Grant
Cardomain 260Z Build Thread
g9m3c is offline
Old 04-02-2009, 09:25 PM   #43
CENTEXOFFROAD
I may visit you, I need lots of parts.
***Current***
'97 ecsb z71,SAS parts gathering in progress
***Totalled***
'03 2wd SCSB
Originally Posted by HawgWyld
The difference between a 4x4 and a penis is that with a 4x4, you actually go look for bigger holes to put it in.
LiftedVictory is offline
Old 04-03-2009, 01:51 AM   #44
DUH! Big Red Truck!
GreaseDog's Avatar
actually its kind of a pain. nice when you need something, but with a 24x24 garage and a small shed, its VERY easy to run out of room. need get rid of some more stuff, but first have to figure out what i need and dont need. i have 9 engines, 6 trucks, and 2 of those trucks are going away without engines, leaving me with 5 extra engines. there's a 700R4, a burned up 60E, a TH400, and an SM465 kicking around the garage too.
GreaseDog is offline
Old 04-03-2009, 05:29 AM   #45
crossy's son's Avatar
Sounds like my house, a 22x22 garage with 11 trucks out back, small blocks under tarps everywhere, 2 th350's, 2 th400's, a 700r4, 3 munsie m21's.
ahhhh! progress is looking good, hows the weather there?
91 RCSB|350|5 speed|3.42 G80|400k miles+|stock...15.67 @84
^ 89k 350,tbimods,Spacers,headers,Southbend clutch,AFPR...soon to be dropped in.:)
Dad's-87 SWB 2wd|305tbi
stuff-4 cummins powered dodge rams
& 81 C10 swb 13.54-1/4 ET,5/8 drop
94 K1500 ECSB 4x4,5.0L,4L60E,3.73's,Magnaflow
crossy's son is offline
Old 04-05-2009, 02:54 AM   #46
Drinking Sailor Jerry's
Pewter-Q's Avatar
You can send the 60E to me if you'd like...
On with the build!
Originally Posted by StreetFreak View Post
I have to blow while driving.
Pewter-Q is offline
Old 04-05-2009, 05:02 PM   #47
DUH! Big Red Truck!
GreaseDog's Avatar
i have plans for the 60E, kinda. either going to the 77 with an NP241 behind it, or a Bravada transfer case put behind it, and dumped into a 2 dr S10 Blazer 4x4 (think Typhoon) powered by a roller cammed, Vortec headed 302 ci TBI motor, maybe dual TBs (since i'm just dreaming anyways)
pulled the motor and tranny out of the 92 last night, took a pic of the tranny, and the 4wd 700R4 and posted them on craigslist. i sold them this morning. that'll fund the 14SF swap for the 94.
Old 04-12-2009, 01:06 AM   #48
DUH! Big Red Truck!
GreaseDog's Avatar
started assembling the front hubs and installing the front axleshafts today... got the drivers side shaft spindle and backing plate on. and found a couple of problems. 1. the grease fitting on my upper ball joints hits the shaft. looks like i'm in for sealed upper ball joints. no big deal, i should be able to grease them just fine with the needle greaser.
problem number 2 is a bit bigger issue. started installing the passenger side shaft, and was havin a hard time getting it to seat into the splines on the spider gear, or so i thought... wrong, it goes in... WAY too easy... i guess i found out the hard way that i have 31 spline spiders and 28 spline shafts. i'll be damned if it didnt get worse after that. went to pull the cross shaft out of the diff and figured out why the guy i got the carrier and gears from sent the open diff too. damn cross pin hits the ring gear. so i have to pull the carrier and ring gear to get my spider gears out to swap them to a set of 28 spline spiders.
Old 04-12-2009, 09:16 PM   #49
DUH! Big Red Truck!
GreaseDog's Avatar
yay! more issues... started installing new races in the front hubs, and wouldnt you know, i got the wrong bearings and races. i guess that's what i get for not looking the parts up myself and trusting the jackass at Napa. ended up with a Dana 60 outer bearing and race instead of a 10 bolt/Dana 44 inner bearing. and of course, i cant find my reciept.
Old 04-22-2009, 10:08 PM   #50
Hows it going Jeremy?
Old 04-22-2009, 10:41 PM   #51
DUH! Big Red Truck!
GreaseDog's Avatar
SLOW! had a full weekend, then wasnt feeling good Monday night, Tuesday and Wednesday were terrible. hopefully Saturday i can make it back out to Pick N Pull and get the axle shafts they have. i did manage to score a 89-91 Burb grille on Saturday when i was there to go on the 80. would've got the axle shaft then, but forgot the snap ring pliers and the spindle nut socket, i couldnt get the snap rings out of the hubs, so no axle shafts. that's the only major holdup right now.
Old 04-23-2009, 10:03 AM   #52
don't you need the core support/lights from a 89-91 chevy or GMC to put it on an earlier truck? you can put that on an 80?
Old 04-23-2009, 10:35 AM   #53
DUH! Big Red Truck!
GreaseDog's Avatar
yes, i will need an 89+ core support, but the misc pieces are what are hard to find, i can score a new core support for about $80-90 locally, the other stuff would nickle and dime the project to death.
Old 04-23-2009, 10:46 AM   #54
Loving The 3 Speed
ryan_thompson87's Avatar
Gah you lucky bastard. I've been aching to try and find a Burb clip.
355ci-9.6:1 Compression-TBI mods-Vortec Heads-GMPP TBI Intake-Melling Cam-Roller Rockers-Flowtech Headers-MSD Ignition-Super 40's-TB Spacer-AFPR-6" Superlift-36"TSLs-Built Turbo 350
ryan_thompson87 is offline
Old 04-23-2009, 10:48 AM   #55
DUH! Big Red Truck!
GreaseDog's Avatar
actually had 2 setups, both complete, and i took bits and pieces out of both to make the best setup.
Old 04-23-2009, 11:05 AM   #56
My dad's got like 3 sets of the lights. dbcrossy@verizon.net if you need them, there just kicking around. Just parted a 90 burb with a chickenwire grille and a 89 blazer a long time ago.
Also have the headlight surround peices in like mint shape, No grille though
THESE--
its a shame your so far away ryan, I know in a U pull yard down here theres a 90 suburban with a MINT GMC front end on it. I like the 89-91 GMC front end then the chevy, just swap billet grille in it and its so nice looking.
Old 05-12-2009, 09:03 PM   #57
DUH! Big Red Truck!
GreaseDog's Avatar
actually scored a free GMC grille and bezels from my buddy. went to pick up some cinder blocks from him, and they were laying by the road in the trash. SCORE!
Old 05-12-2009, 09:41 PM   #58
Metal Head^^
blowngp99's Avatar
Cool build dude! Will be checking in on this quite often.
KN Intake, Magnaflow Muffler, NGK Plugs, Tinted Tails, 95 Seats, Demolded, Debaged, Chrome Rockers, Some other stuff
Soon to come- Built 4L60E
blowngp99 is offline
Old 05-13-2009, 08:29 PM   #59
dude this is a sweet build, sounds like you have 30 projects going on in your life
97rada is offline
Old 05-14-2009, 12:58 AM   #60
DUH! Big Red Truck!
GreaseDog's Avatar
i seriously need to figure out how to add 8 hours to every day. this whole working thing is getting in the way of playing trucks.
